11-09-2017, 02:18 PM | #1 |
Mixing Nitto tires
I’m ready to buy new tires for my truck and plan on going with 255-40-20 in the front and 295-40-20 in the rear but I just found out that for those sizes Nitto NT420S would be the front style and NT555 G2 for the rear has anyone had any issues running different tread designs on lowered trucks or should I look for another brand of tire??
11-09-2017, 03:08 PM | #2 |
Re: Mixing Nitto tires
I don't see how a tread design would affect anything on the road , other than maybe during rain or water hazards,
in my Poorer younger years I ran many different styles depending on what I could find in the junk yards, I just always tried to keep them all the same size (side wall size) but always ran bigger (wider) in the back
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
11-09-2017, 03:32 PM | #3 |
I would not do it. But I'm sort of anal about tires you see. My beef with this would be that the side wall might be slightly different visually due to the way the tread pattern tends to wrap around a bit there and/or the lip of the wheel integrates with the tire's edge ( whether or not there is a protective tire lip or groove ).
Not to mention having different tread patterns front to rear! That's just me though. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
11-09-2017, 03:45 PM | #4 |
I’m kinda starting to shy away from the Nitto and looking at Toyo tires I can get both sizes with the same tread.
11-09-2017, 07:51 PM | #5 | |
11-09-2017, 10:09 PM | #6 |
I'm too picky to have different tread front and rear, I'd go with the Toyo Proxes. They are available in both of those sizes. That's what I'm running on my truck in the same sizes you mentioned.
1970 SWB Build |
11-09-2017, 10:31 PM | #7 |
Toyo it is. Thanks for everyone’s advice it is always appreciated.
11-09-2017, 11:23 PM | #8 |
I run the same size on my trucks.. I love toyo tires
