Old 01-13-2018, 02:34 PM   #1
ekneen
Identify this: Accelerator controls off of ???
Tearing down my mutt of a 1969 K10 to deal with a flimsy accelerator pedal*. It's definitely not stock, nor in great shape. Anyone know what this is off of? Cross checking LMC catalog it doesn't appear to be off of a Chevy pickup between 1967-1989, but the drawings could be misinterpreted. It is accelerator cable, not rod.
*Pedal was attached to rod by a bent roofing nail, Rod support mount cover plate is plastic and very cracked/cut.
ekneen is offline   Reply With Quote
Old 01-13-2018, 02:37 PM   #2
ekneen
Re: Identify this: Accelerator controls off of ???
And the images...
Old 01-13-2018, 03:51 PM   #3
DaHos
DaHos's Avatar
Looks like someone attempted to install the later (71-72) cable style pedal in a early "rod" style truck.......
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 01-13-2018, 04:28 PM   #4
projectking
projectking's Avatar
71 Chevy/GMC
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 01-13-2018, 04:52 PM   #5
ekneen
Thanks all! Does anyone have a pic of one installed? The diagram in LMC truck looks different to me.
Old 01-14-2018, 06:22 PM   #6
ekneen
So, the mount bracket attachment points are all spaced 2" on center (equilateral triangle).
Old 01-14-2018, 09:21 PM   #7
projectking
67 Chevy C10 LWB
90 Mustang Gt
Old 01-14-2018, 09:21 PM   #8
projectking
Sorry for the huge pic
67 Chevy C10 LWB
90 Mustang Gt
Old 01-14-2018, 10:25 PM   #9
ekneen
Thank you for it! Are there any return springs hidden in there or just up at the carburetor?
It's looking like I have the pedal, shaft, and cable off of a 71-72, but it's mounted using the traditional 67-70 bracket.
Old 01-14-2018, 10:52 PM   #10
Boog
laying low
Boog's Avatar
Here.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-15-2018, 12:21 AM   #11
cr1hotrod
cr1hotrod's Avatar
Looks like my '67 pedal before the rod broke in half inside the "mounting plate". I replaced it with a Lokar pedal & cable setup.
1967 Longbed 4/6 static
2007 Silverado Z71 Crew
cr1hotrod is offline   Reply With Quote
Old 01-27-2018, 06:23 PM   #12
ekneen
Going to attempt the quick fix: http://67-72chevytrucks.com/vboard/s...00#post1383300
Old 01-27-2018, 08:13 PM   #13
notsolo
notsolo's Avatar
Thumbs up Re: Identify this: Accelerator controls off of ???
What year did they change the hindge floor mounting, to firewall only? Are there any bolt holes in the floor under pedal?
notsolo is offline   Reply With Quote
Old 01-27-2018, 08:15 PM   #14
ekneen
The 69 was a hinged floor originally. Alas, the floor pan had long since disappeared--along with it the pivot points.
Old 01-28-2018, 10:44 AM   #15
ls1nova71
ls1nova71's Avatar
They went to a cable throttle in 1971. The earlier trucks did have a nutplate under the floor that the ball studs screwed into that the pedal snapped onto. 71-2's still have the flat spot in the floor for them, but no holes or nutplate of course.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
1969 k10, accelerator, accelerator cable, accelerator pedal, k10
