Old 03-14-2011, 04:27 PM   #1
argonaut
argonaut's Avatar
BBC into a 66 K10
I've been searching and searching to see if anyone has a build thread documenting this swap already. I've seen a few on 64-66 c10 trucks, and some on 67-72 K5/K10s but don't think I've seen one on a 60-66 K10.
I want to keep the drivetrain locations the same, so I need the motor mount brackets to accommodate this. it is unclear whether there are some factory brackets that I can make work for this, or if there are some aftermarket options. It doesn't look like the aftermarket late model tubular type mount brackets will bolt to the 4x4 crossmember.
Any thoughts, ideas, pictures?
Thanks.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 03-15-2011, 01:48 AM   #2
'63GENIII
'63GENIII's Avatar
Re: BBC into a 66 K10
The 396 in mine seems to have stock mounts. I think mine came with a 283 original. Not too sure though. Uses 1 large bolt to the frame through the motor mounts, no crossmember, firewall is not beat in and running an HEI with limited clearance. TH 400 and a rockwell T221. What kind of transmission / transfer case are you running?
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 03-15-2011, 10:21 AM   #3
argonaut
argonaut's Avatar
63GENIII,
that is interesting information. Do you have, or could you take some photos of the mounts?
This 66 has a sm420 transmission and Rockwell t221 transfer case. The transmission will remain in it's current location and serve as the datum for positioning the motor. Perhaps it will just drop in on the small block mount brackets... that would be sweet.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 03-15-2011, 10:24 AM   #4
'63GENIII
'63GENIII's Avatar
I will get them as soon as I can. It won't be till this weekend though. It actually looks semi factory as far as fit. The P.O. did a pretty sanitary job.
Chris
'63 k15 long step
Old 03-15-2011, 10:32 AM   #5
argonaut
argonaut's Avatar
That's what I'm hoping to do here. I'm a little anal retentive and would like to do it right the first time.
I certainly would appreciate seeing as many pics as possible when you have the chance to snap some. Thanks!
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
