10-09-2019, 05:47 PM | #1 |
Placement Of In Bed Spare Tire Bracket
I'm in the process of adding my in bed spare tire carrier bracket. I've seen the pics of what bolts etc to use, just no info on how far from the front of the bed towards the rear wheel well on the drivers side. Any pics with measurements would be appreciated. Thanks
10-09-2019, 06:01 PM | #2 |
Re: Placement Of In Bed Spare Tire Bracket
Do you have the spare yet?
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
10-09-2019, 06:23 PM | #3 |
When I get home all get some pictures up with mesurments for ya.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
10-09-2019, 06:46 PM | #4 |
I found that the bed side had the square holes punched thru bottom angle for the spare bracket, 4 inches or so apart, but not in the bed floor, drill thru bed floor, and bolt on bracket...This was on a 71 long bed....your results may vary.
10-09-2019, 07:54 PM | #5 |
Here you go. The first is from the edge of the stake pocket. The far edge closest to the frount of box.
10-10-2019, 09:55 AM | #6 |
is this all factory original? I am curious can you guys post pics of all of this ?
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
10-10-2019, 11:01 AM | #7 |
10-10-2019, 11:03 AM | #8 |
Thank you for the pictures. Would these measurements vary depending on whether it is a long bed or short. It is going behind the driver in front of the wheel well. Thanks again.
10-10-2019, 02:45 PM | #9 | |
Pages of it! Mines in there somewhere too. http://67-72chevytrucks.com/vboard/s...re+tire+mounts Mike. |
10-10-2019, 03:55 PM | #10 | |
10-10-2019, 05:29 PM | #11 |
That's whare my factory one is be hide driver in frount of wheel well. My mesuements for a long bed. So I don't think it will be the same for a short bed. Maby the same distance from the wheel well but not same from stake pockets.
