Old 07-05-2011, 09:00 PM   #76
m6z
m6z's Avatar
Re: 72 Cheyenne Super First Project
nice build
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 07-05-2011, 09:38 PM   #77
RCbowtie69
RCbowtie69's Avatar
I'll have to say it's looking great,your progress is coming along pretty quick,& the parts for your build is adding up.Keep the pictures of your progress coming & keep on truckin''
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 07-05-2011, 09:41 PM   #78
jasonhall
jasonhall's Avatar
nice work!
jasonhall is offline   Reply With Quote
Old 07-05-2011, 09:57 PM   #79
Graham57a
Graham57a's Avatar
Originally Posted by m6z View Post
nice build
Originally Posted by jasonhall View Post
nice work!
Thanks guys, my goal is to have the truck in primer, mostly put together on the frame by the end of August before I leave for school. Wish me luck and I will do my best keep this thing updated
I am also going to CA on monday where my graduation present (1968 ss396 camaro) resides. I will take some pictures of her while I am out there so you guys can see my next project. Yes I am only 17 years old and I already have multiple projects
ANDREW
1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072
1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827
1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315
1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788
1972 Chevy SWB Highlander OLIVE Build thread coming
Graham57a is offline   Reply With Quote
Old 07-06-2011, 08:40 AM   #80
gcburdic
Restoration Virgin!
gcburdic's Avatar
Originally Posted by Graham57a View Post
Thanks, once we put a gear in it we might have to shave part of the crossmember which kinda sucks cause everything just got powder coated. I might just leave it for now tho and see how low the back is once everything is together.
Yeah...I was thinking the pumpkin would possibly interfere with that x-member, but heck once ya get tires on it, there may not be an issue.....
BTW....I think it's awesome you're headed to college....where ya going and what are ya gonna be studying??
OH...while you're out there don't forget to bring that shortbed back for me
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-06-2011, 07:51 PM   #81
Graham57a
Graham57a's Avatar
Yea, hopefully it will be low enough (if there is such a thing) once it all gets put together. And I am going to Appalachian up in Boone, not sure what I am gonna study yet tho. Probably snowboarding and girls for the first year I will be sure to take some pictures of the wood floor bed for you when I am out there
Here is the update for the day. I almost finished mounting the bags. I have to go to the parts house tomorrow and get straight valves, rather then the 90 degree ones, so I can run the line straight through the hole in the bottom of the frame and then they are complete. I also took a stab at some of the remaining patch work on the cab. I have to say, it is very frustrating welding such thin material but I eventually got it. I am taking the last extra pieces up to the powder coater tomorrow and that is probably going to be it before I leave for a week. Once I get back I will be able to bolt on the upper and lower a arms and the bed should be done at the body shop and I can give them the cab!! She is moving along slowly but surely
ANDREW
Old 07-08-2011, 07:20 PM   #82
Graham57a
Graham57a's Avatar
Got a little work done today on the truck. Finished mounting the bags, got the brake lines sorted out and made all of the lines (first time). I also threw a gear in the rear end to see how it would clear the cross member. Worked out pretty sweet, the housing slopes straight down right where it would hit the crossmember. I just need to flare the ends of the brake lines and put all of my fittings in. I am going in tomorrow to work on making the track bar mount and that will be it before I head out for a week to go to CA.
ANDREW
Old 07-08-2011, 07:23 PM   #83
Graham57a
Graham57a's Avatar
A few more pictures
ANDREW
Old 07-08-2011, 08:14 PM   #84
gcburdic
Restoration Virgin!
gcburdic's Avatar
That looks nice Graham....what gear ya gonna run??...Also, probably missed it earlier, but what drivetrain too??.....you probably know this, but I assume you'll protect your air lines so they don't rub the frame....
Geoff with a G
Old 07-08-2011, 09:45 PM   #85
RCbowtie69
RCbowtie69's Avatar
Nice!!!!!!!!!!!!!!
Old 07-08-2011, 09:48 PM   #86
Graham57a
Graham57a's Avatar
Nice!!!!!!!!!!!!!!
Thanks guys. I am gonna run somewhere between a 3:30 to a 3:50 for a gear and I haven't decided on the drivetrain yet. And I didn't know about protecting the air lines from the frame?? How do I do that?
ANDREW
Old 07-08-2011, 10:15 PM   #87
gcburdic
Restoration Virgin!
gcburdic's Avatar
find some rubber hose that has a large enough inner diameter to fit around the outer diameter of the air line, cut it like 3-4" long, cut it length-wise to split it, then wrap it around the line where it may rub...maybe use ties to secure it in place
Geoff with a G
Old 07-09-2011, 02:30 PM   #88
Graham57a
Graham57a's Avatar
Okay sweet, thanks for the tip. I'll be sure to do that
ANDREW
Old 07-19-2011, 10:31 PM   #89
Graham57a
Graham57a's Avatar
Back from California. No progress on the truck but I have some pictures of some of my stuff stashed out there, swb wood bed, grandpas 71 lwb, and my dad's 69 camaro drag car.
ANDREW
Old 07-19-2011, 10:37 PM   #90
Graham57a
Graham57a's Avatar
Here she is
ANDREW
Old 07-19-2011, 10:49 PM   #91
gcburdic
Restoration Virgin!
gcburdic's Avatar
Welcome back Graham...things looking good over there in Cali....now get back to work on your truck before you have to go to college
Thanks for the bed pictures....now stop teasing
Geoff with a G
Old 07-24-2011, 09:21 AM   #92
RCbowtie69
RCbowtie69's Avatar
There are some nice rides & projects you got,gald your back,so back to work on the truck.Keep the pictures coming & Keep on Truckin'
Old 07-24-2011, 09:54 AM   #93
Graham57a
Graham57a's Avatar
Thanks guys. Dad just lost his job on monday so things have been kinda stressful moving all of his stuff out of the shop and trying to find places to put all of it. My truck is gonna end up in the garage at the house so it'll be a little more challenging working on it. Should have some pictures of her in the new home either tonight or tomorrow.
ANDREW
Old 08-04-2011, 06:01 PM   #94
Graham57a
Graham57a's Avatar
Here is the update as of today. My frame got moved into the garage and all of the body is at the body shop getting worked on. I got the rear end that I am gonna run, minus the gear, and I got my disk brakes )))))) (alcon racing brakes off of a nationwide car!!) I am waiting on some parts to come in the mail so I can put the front suspension together and then the motor will be going in. Here are some pictures of the brakes, I'm kinda excited about them
ANDREW
Old 08-07-2011, 09:47 AM   #95
RCbowtie69
RCbowtie69's Avatar
Looking good,your progress is coming along.Keep up the work & pictures coming.Keep on Truckin'
Old 09-28-2011, 10:41 PM   #96
Graham57a
Graham57a's Avatar
Hey guys, I haven't update the forum for a while so I thought I would fill in everyone on the progress of the build. I moved off to school on August 18th and I have only been home once since. My truck has sadly been neglected and the last time I was home she was sitting in the garage covered in Christmas boxes and all of the other crap that gets thrown in the garage. The last time I was home, I went to the body shop and all of the body work was done and the truck was in primer. I paid them and depleted my savings account. I just talked to my dad on the phone today and he said that things are slow at the body shop so he is gonna have them paint the bottom of the bed, the inside, bottom and back of the cab, the firewall, and the front of the bed so we can bolt those onto the frame and not have to mess with that anymore. I am going home Friday so I can take some pictures of the progress. I should have the cab and bed on the frame Saturday night so keep posted for pictures.
ANDREW
Old 09-28-2011, 10:47 PM   #97
gcburdic
Restoration Virgin!
gcburdic's Avatar
What's up Graham!!!...Hope school is going well for ya buddy!!!...Look forward to those pictures
Geoff with a G
Old 10-02-2011, 03:40 PM   #98
Graham57a
Graham57a's Avatar
Got the truck from the body shop yesterday. Some spots turned out really nice and some not so much but for the price that they charged me I can't really complain. I have been trying to get as much little stuff done to her as I can seeing that I am leaving to go back to school this evening. Here are some pics of my progress thus far.
ANDREW
Old 10-02-2011, 03:44 PM   #99
Graham57a
Graham57a's Avatar
A few more
ANDREW
Old 10-15-2011, 04:19 PM   #100
Graham57a
Graham57a's Avatar
Here are some pictures of my progress. I have been home on break from school and I have been out in the garage every single night till at least midnight working on this girl. I am getting pretty excited but I still have a lot of work to go. As far as the interior goes I need to get my seat covered and installed, the steering column figured out, glove box door and ash tray painted, and the dash installed. That's about it for the interior. The only thing I have done to the exterior is run the tail light wiring harness and clean up the master cylinder and brake booster. I have about a billion pictures so here you go picture junkies
ANDREW
