Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 02-23-2020, 03:43 PM   #1
muddstir
muddstir's Avatar
How many miles is too many?
I found a 2012 chevy truck for sale, it's a long bed crew cab 2500 6.0 4x4.
Has 199,xxx.x miles for $7999.00. Looks fairly clean for something around my area (rust wise) but has a few dings and dents. If I had to guess I'd say it was and old service truck.
I prefer long bed trucks so that's my draw to it, crew cab I could do without but it's not a turnoff either. I drive 4 miles one way to work and put maybe 50 extra miles on that week going elsewhere. So must of my vehicles die becouse of rust and not mileage.
So my question is - does that truck have tomany miles for the price Or for the life expectancy of drivetrain?
Any input at all is appreciated. Thanks
P.s. I also take trips throughout the summer driving around 5 to 7 hrs one way (sometimes pulling a small trailer too).
muddstir is offline   Reply With Quote
Old 02-23-2020, 03:56 PM   #2
notsolo
notsolo's Avatar
Re: How many miles is too many?
Maintenance on the truck would be most important. Have a mechanic look at it. I have seen some of these trucks that have 300k and still run good. Is it local, not salted too bad?
notsolo is offline   Reply With Quote
Old 02-23-2020, 04:01 PM   #3
67swb72klb
67swb72klb's Avatar
The miles are a little high for my liking but the body's are the downfall on the 07-13 trucks IMO
Here in my area most are rusting pretty good already
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 02-23-2020, 05:44 PM   #4
burnin oil
The milage is high but not really high. For a 7 year old truck I would assume that is alot of interstate milage. Make sure that you have a good grand onhand for stuff that needs fixed. Oil changes for the driveline, belts, hoses, brakes and tune up add up quick. That's not mentioning any other items found worn. Old service trucks usually have alot of idle time so add that in. See if you can pull up the hour meter and see the run hours. I am not sure if you can do that on a 2012 Chevy or not.
burnin oil is offline   Reply With Quote
Old 02-23-2020, 06:52 PM   #5
truckster
truckster's Avatar
I might see things a little differently from others. I've bought a lot of used vehicles and I'm not too scared of miles. I look at cost per mile first and go from there.
I figure most modern trucks are good for around 250,000 miles, so I subtract the odometer mileage from that and divide the cost by the miles remaining.
After doing that, I look at what currently needs to be fixed and probable maintenance costs. After doing all of that, I consider things like appearance and convenience items.
If, after going through all of that, I feel the deal is good enough, I feel pretty good about buying.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 02-24-2020, 11:43 AM   #6
blazer2007
I have 312,000 K on my 89 jeep cherokee and met a guy at the grocery store and he had 600,000 on his. I,m starting to get worried thou, always what,s that noise.
blazer2007 is offline   Reply With Quote
Old 02-24-2020, 11:45 AM   #7
Deer_hunter_088
Deer_hunter_088's Avatar
my 94 k1500 has 250k miles. still running strong
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2005 Silverado 2500hd(tow pig)
Made in the USA, just like my trucks
Deer_hunter_088 is offline   Reply With Quote
Old 02-24-2020, 12:10 PM   #8
1976gmc20
Our 88 xj has less than 100K, but it has lots of weird noises. I think the fix is earplugs or a loud radio
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 02-24-2020, 12:24 PM   #9
cornerstone
cornerstone's Avatar
[quote=muddstir;8683163]I found a 2012 chevy truck for sale, it's a long bed crew cab 2500 6.0 4x4.
Do you have to have a 2500? Often times they get worked much harder than a 1500. A quick search found this one with less than half the miles.
Runs like new
130k miles
4x4
Clean title
Financing and warranty available
10500 cash or 2000 down to finance
Call or text me 8178410327
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 02-24-2020, 12:30 PM   #10
hairball
As others have posted, good maintenance is the key factor in a high mileage vehicle. Be sure to obtain all service and repair records from the owner. If they can't produce them I'd walk away. Spend a few dollars and have the truck inspected by a certified mechanic before you buy it. A well maintained high mileage truck could have a lot of life left in it. Also consider doing a Carfax on it.
hairball is offline   Reply With Quote
Old 02-24-2020, 01:46 PM   #11
FirstOwner69
FirstOwner69's Avatar
That truck should have an hour meter that you can access. The number of hours can can tell you a lot about how the truck was used. Anything over an average speed of about 32 MPH is not bad. The 2006 I bought new and sold in 2015 had an average speed of 48 MPH and that was virtually all Interstate highway miles pulling a 5th wheel at 68-70 MPH. Very few city miles.
Jim
FirstOwner69 is offline   Reply With Quote
