Old 05-21-2016, 12:15 AM   #126
COS399
COS399's Avatar
Re: 1987 R20 Suburban LQ4 4L80E swap
Looks great. Good Job.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 05-21-2016, 12:46 AM   #127
MTCK
MTCK's Avatar
Nice work that looks awesome. What are those codes?
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 05-21-2016, 12:17 PM   #128
Nodnarb76
Nodnarb76's Avatar
Keep getting p0171 & p0174, too lean on banks 1 & 2.
Thanks for the kind words!
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 07-14-2016, 10:39 AM   #129
Marshy
Nice work. What are you getting for fuel mileage now? Did you move your filter and get the codes figured out?
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15
GM 4 bolt 880 roller block, 062 Vortec Heads
Comp Cams XR258HR-10, MSD Street Fighter HEI
Edelbrock: Performer Intake 2116, 1405 Carb
Long tube headers, 2.5" duals to Flow Master Super 40's
Vortec Engine Build
Marshy is offline   Reply With Quote
Old 07-14-2016, 10:53 AM   #130
Nodnarb76
Nodnarb76's Avatar
Thank you, I'm getting around 14mpg (mostly highway driving). I have clocked about 2000 miles on my tuck since the swap and everything seems to be going fine with no problems. I moved the fuel filter/Regulator down a little bit on my firewall with no issues. I did get the CK engine light figured out, turns out the people that did my exhaust left the bolts loose that connect the exhaust to the manifolds and that allowed air to get into the exhaust and past the o2 sensors creating a lean code.
Here is a recent pic of the motor after everything was done.
Old 07-14-2016, 10:57 AM   #131
Marshy
Very nice. I want to build a 6L myself even though I don't have anything to put it into besides my K10 right now.
How is the power?
Vortec Engine Build
Old 10-13-2016, 12:14 PM   #132
OutlawDrifter
Just read through your thread. Very nice setup! I would live to have an LS swapped 3/4t burb. Lice the two tone combo also!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 10-13-2016, 12:35 PM   #133
Nodnarb76
Nodnarb76's Avatar
Thank you for the kind words!
it was a lot of work and a lot of money, but in the end it was definitely worth it.
Old 11-07-2016, 06:40 AM   #134
l92powered77
Wow really nice burb.who tuned the ecm? I have the p0171 ans p0174 and cant get rid of them either. Bolts are tight. I need a serious retune i only have a stock tune from psi conversion. Who did your tuning? You have hgen 3 you can send it quick anywhere to want without having to take out tcm like ua hen 4 guys. Sounds good i have same mufflers on a 6.2. Did you end up shaving tabs off tranny for manifolds? I had to switch to ls3 manifolds. nice build! Do you tow anything?
l92powered77 is offline   Reply With Quote
Old 11-07-2016, 12:27 PM   #135
Nodnarb76
Nodnarb76's Avatar
I found an exhaust leak at the manifolds where they meet the exhaust. Got that taken care of and codes haven't come back. I would recommend running some seafoam through your motor, and see if you see any smoke/leaks.
My ECU came already tuned with my harness/motor from LSX4U.com. Good people to work with.
I did have to cut the tabs off the transmission with a sawsall for the exhaust to clear.
I don't tow anything but if I wanted to, I feel I could with no problem.
Good luck on your build, I hope you get those codes figured out.
Old 07-28-2017, 01:47 PM   #136
dwntwn
dwntwn's Avatar
Originally Posted by Nodnarb76 View Post
Got a lot more done today.
Got the TBI harness out.
Nodnarb, Awesome build! I've read this thread through a couple of times, had a couple of questions
How much of your stock wiring harness did you retain/reuse with the new harness?
Removing the TBI harness—that includes the ECM, right? Did you go off of a GM shop manual or did LSX4U give you the instructions on what to delete/what to keep on your '87?
1966 c10, short fleet, 402ci 700r4
1988 r20 Suburban 454ci tbi, th400 (12v Cummins soon)
1980 shovelhead, hardtail, open primary
1998 FXDWG
dwntwn is offline   Reply With Quote
Old 07-28-2017, 03:51 PM   #137
Nodnarb76
Nodnarb76's Avatar
when I did my swap I un-plugged the factory TBI harness from the motor. then found where the wires went into the firewall on the driver's side. I was very nervous but I cut the wires where they go into the firewall and left the TBI harness plugged into the stock connector with the cut wires coming off the connector. I did leave enough wire at the stock connector in case I had to re connect a wire I removed. I took the TBI harness home and took an entire Sunday afternoon and traced every wire on the factory harness and probed them with my multi-meter to make sure I knew what each wire did. I realized the majority of the wires were 12v switched on power for the various sensors on the motor, and of course some wires going to gauges, etc. I did remove the TBI ECU. After I removed the stock engine harness I had moment of truth, I reconnected the battery and wanted to make sure I didn't remove anything that needed to remain. I checked and all of my lights, wipers, turn signals, horn, blower motor, radio, windows etc all still worked. Thank goodness everything still worked, and I had not removed anything that I didn't need to.
The LSX4U harness was great to work with, just follow the instructions they send you, the hardest part was wiring the torque converter lockup relay.
I also made my own harness for the fuel pump/gauge sending unit and ran it back to the tank, and other end to the LSX harness and my new fuel gauge.
I figured I might as well have new wiring for everything at that point lol.
Good luck with your swap, let me know if you need anything else.
Old 07-28-2017, 03:58 PM   #138
Nodnarb76
Nodnarb76's Avatar
While I'm posting also wanted to show off my intake I painted.
Old 07-28-2017, 04:06 PM   #139
MTCK
MTCK's Avatar
Truck looks great. Have you been driving the wheels off of it? How's the performance and economy been?
-Marcus
Project Plow Truck
Old 07-28-2017, 04:16 PM   #140
Nodnarb76
Nodnarb76's Avatar
I have put about 7500 miles on it so far and it runs great.
I love this truck!
Old 07-31-2017, 08:58 AM   #141
aggie91
I'm just glad to be here!
aggie91's Avatar
This suburban would make a great tow pig for my son's '84 SWB. It has the same color combo!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-31-2017, 03:53 PM   #142
Dads79GMC
Dads79GMC's Avatar
How did I miss this one? Great stuff!
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 07-31-2017, 04:13 PM   #143
Dads79GMC
Dads79GMC's Avatar
I could be totally wrong, but could you have used the "Upper Radiator Mounting Panel" below to mount your radiator? It steps down a couple inches or so vs the SB mounting panel???? My radiator did the same thing and I put a 1"x 1" x 3" square tubing on the bottom of the radiator core support and put the mounting cushion on the tubing.
Just thinking out-loud.
Mike
