Old 01-21-2024, 07:05 PM   #1
mongo4298
Help identify rear axle
Hello, original owner of 1970 Chevy K20. I had the specs for the running gear but they have been misplaced. Before I place the truck on the market I want to address a few items that need attention. Pinion seal and differential cover gasket to start. The RPO code label on the glove box says G86 No Spin Rear Axle. The casting number on the differential is 3934665. I cannot find any numbers on the axle tubes. The Cover is 10 bolt. Approx. 13 inch width. The no- spin is a Eaton HO52. It has a 4 speed muncie SM 465 transmission. The front differential is a Dana 44. The transfer case is a NP 205 small cover/3bolts.
There is no tag on the rear cover thanks to the last time I had the gear oil changed.
Our local dealer is of no help so I would appreciate whatever help I can get. Thanks
mongo4298 is offline   Reply With Quote
Old 01-21-2024, 07:09 PM   #2
oneshotkyle
Active Member
Re: Help identify rear axle
Pics?
oneshotkyle is online now   Reply With Quote
Old 01-21-2024, 07:11 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I think you answered your own question when you mentioned the no-spin. Sounds like your axle is an HO52, common on K20s of that vintage. My '72 K20 has an Eaton HO52, and the cover does have 10 bolts. HTH
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 01-21-2024, 09:59 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
As far as the ratio, you might look on the passengers side axle tube and see if there is anything stamped there. (See pictures) If so use the first two or three letters and look them up on these charts.
https://www.67-72chevytrucks.com/vbo...d.php?t=578793
Leon
Old 01-21-2024, 10:14 PM   #5
Sicklajoie
The Niner
Sicklajoie's Avatar
Well an HO52 rear is either a 4.11 or 4.56 correct?
Spin the tire once and see how many times the driveshaft spins.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 01-22-2024, 12:33 AM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Since you'll have the diff cover off to replace the gasket, you can count the R&P teeth to get the exact ratio.
- Mike -
RIP El Jay
Old 01-22-2024, 01:07 PM   #7
MJN
MJN's Avatar
For the H0 axles the stamped code on top of the third member will tell you the build date and ratio.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 01-26-2024, 07:03 PM   #8
mongo4298
Thanks to everyone for your help. I'm having problems trying to locate the correct pinion seal. Local parts stores show pinion seals but there are several choices and each one is different. I contacted National Seals but they don't list it. My Chevy manuals show the seal but no part number. Is there a possibility that a member has a parts identification manual with actual GM numbers. I did find and purchase the correct cover gasket. Thanks
Old 01-26-2024, 07:14 PM   #9
MJN
MJN's Avatar
So if you have an Eaton style H0 axle with the big round 10 bolt cover then these are the pinion seals you need. One is the seal and the other is the felt packing. If you were able to find the correct cover gasket what axle do you have, Im not sure you posted that.
'17 GMC Yukon XL
VCCA member #58596
