12-20-2023, 11:59 AM | #1 |
Junior Member
Tremec T56 Magnum
Ive found a T56 magnum to buy across here in the UK for a reasonable price.
I'm wanting to change to manual from my TH350 mounted on a 305 on my C10 and it seems to be a good choice from the reading up I've done. I dont have much experience in transmission work so hoping you guys can give me any advice on it or questions I should be asking the seller about the T56 He also has a T10 very cheap but I cant find alot out about them Thanks as always |
12-20-2023, 12:13 PM | #2 |
Re: Tremec T56 Magnum
I have a T56 magnum in a car of mine, it's awesome. You'll need a different bellhousing set up, hydraulic throw out bearing/clutch master cylinder etc but I'm sure can't be too tricky to get it into the truck.
The magnum has two shifter locations, and a separate bellhousing making it a universal fit transmission versus the integral units found in production vehicles.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
12-21-2023, 10:13 AM | #3 | |
There are quite a few versions of the original T56, the T56 Magnum, and the TR-6060. Be sure you are getting what you are paying for. |
12-21-2023, 10:47 AM | #4 | |
The Older Generation
I don't know a lot about the T-56 but I'm just curious why you are saying he would need a hydraulic throw out bearing and master cylinder. Can't the trans be used with a stock Chevy manual bell housing and clutch setup? LockDoc
12-21-2023, 11:09 AM | #5 |
The T56 magnum needs an LS style bell housing. It can’t be used with a traditional Muncie style bell housing. I don’t think the transmission and clutch set up is compatible with manual linkage - but I could be wrong.
The t56 magnum is not a T56, the naming is confusing. It is a variant of the production TR6060 found in modern Camaros, challengers, etc. Just with a non integral bellhousing and two shifter locations. The TkX 5spd tremec came out with can be used with a Muncie style bellhousing which is why it’s been a good addition and fits a lot nicer than the giant t56 magnum. I really like the 6 spd though. I run 4.10’s and a shorter tire and still cruise 75 at 2200-ish rpm in 6th.
12-21-2023, 11:20 AM | #6 | |
OK, thanks. I thought the Magnum might be the same as the tremec. LockDoc
12-21-2023, 11:49 AM | #7 |
Still made by tremec but doesn’t share any similarities with the T56 found in older GM cars. Kind of confusing.
12-21-2023, 12:38 PM | #8 | |
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
12-21-2023, 12:41 PM | #9 | |
Thanks for the input. LockDoc
12-21-2023, 02:32 PM | #10 |
It is likely Quick Time, now owned by Holley, will have whatever combo, engine to trans, mechanical or hydrolic, you desire. I put a Jerico dog box behind a LS2 15 yrs ago using 7 inch quarter master clutch and flywheel and hydrolic clutch. Quick Time had the housing that set the Jerico in perfect position. Oh and it all slid right into a BMW Mcoupe. As for the T56 magnum. Great street box. Ok track box if you slow your gear change just a tiny bit.
12-29-2023, 11:42 AM | #11 | |
Active Member
Make sure you check the part number tag on the transmission and compare it to Tremec's catalog. There are a lot of variations over the years and they won't all work. |
12-29-2023, 02:17 PM | #12 | |
The 3rd gen Camaro's (82-92) had a T5 5 speed (except 82, last year of the 4 speed) They used a more typical bellhousing that had the same bolt pattern as a Muncie/Super T10. They had a oddball clutch setup where is was a mix of both mechanical and hydraulic. It was hydraulic on the pedal down to the bellhousing, but then there was a bracket cast onto the bellhousing that mounted a plunger that would then work a typical fork throwout bearing.
12-29-2023, 05:49 PM | #13 | |
Active Member
You can use the LT(SBC) T56 with an LS, but you need to change the bellhousing and input shaft. Input shafts were longer on the LS transmissions if I remember right. I seem to recall a difference in the front plates as well but I can't remember if you needed to change them or not. |
12-29-2023, 06:02 PM | #14 | |
12-29-2023, 08:08 PM | #15 |
Maybe, but the 2 LT1 stick F bodies (both 97's) I have worked on were full hydraulic. They could have been converted as they had alot of stuff replaced over the years other than the motor. Only other early 4th gens I have had/worked on were Auto's.
01-02-2024, 05:38 PM | #16 | |||
"I ain't nobody, dork."
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
