Old 03-22-2018, 12:20 PM   #1
bob8619
Did I get the wrong axle seal?
The new seal is the one with red. Its what the parts store says is needed for my truck. Its a 12 bolt non posi. It looks like that silver ring thats still in the hub just needs to come out and the new seal will fit but I just want to make sure so that I don't ruin something.
1968 C10
bob8619 is offline   Reply With Quote
Old 03-22-2018, 12:34 PM   #2
KY_GMC
KY_GMC's Avatar
Re: Did I get the wrong axle seal?
No, that's the bearing outer race. That needs to be pushed in further and then the seal will fit into the axle bore.
1972 GMC 1500 Super Custom, 383 Stoker, TH350
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592157
Engine Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592233
KY_GMC is offline   Reply With Quote
Old 03-22-2018, 12:39 PM   #3
bob8619
I was just about to post that I was able to see the part number on there its this, which shows the seal inside there. https://www.napaonline.com/en/p/BRGR1559
1968 C10
Old 03-22-2018, 07:33 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Huh... never seen an outer axle bearing like that in a truck 12 bolt. There is no "race" that I've ever seen. The bearing and "race" is a single caged unit.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 03-22-2018, 08:05 PM   #5
Mike C
Mike C's Avatar
That looks like an axle-saver bearing. It is located outboard a little to run in a fresh location on the axle. You may need a different seal than the stock replacement.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-22-2018, 08:14 PM   #6
bob8619
Yeah it is, I found another locally and so far no more leak.
1968 C10
Old 03-22-2018, 08:38 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Looks to me like the seal should have come with that repair bearing as a unit.... I guess you would have to get a seal that will fit inside that bearing race.
LockDoc
Leon
Old 03-23-2018, 11:30 AM   #8
demian5
demian5's Avatar
If this is the case, it may be installed backwards... And yes most have a built-in seal.
Lets see the box it came in for a part number (bearing AND seal), then we can help you perfectly.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 03-23-2018, 11:49 AM   #9
bob8619
I already finished the job. Instead of trying to locate a seal that would fit into that axle saver bearing I Just bought a whole new axle saver bearing.
1968 C10
Old 03-23-2018, 08:07 PM   #10
Mike C
Mike C's Avatar
I assume it installed exactly the same way? Because of the step in the housing I wouldn't think it could go in the other way.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 03-23-2018, 08:43 PM   #11
bob8619
That is correct.
1968 C10
