Old 09-11-2010, 09:40 AM   #1
vjjack04
vjjack04's Avatar
IFS in my 55 project-start
Took the front end off last weekend and this weekend I will be getting the front suspension out of the way. I have ordered a Scotts IFS; should be here next week. This is my first time doing this, so if you have experience and tips, they are welcome.
Johnny Jackson
Hereford, AZ
vjjack04 is offline   Reply With Quote
Old 09-11-2010, 06:41 PM   #2
46deluxe
46deluxe's Avatar
Re: IFS in my 55 project-start
Is the rear suspension at your desired ride height?
Cover the windshield up where the sparks don't ruin it.
Brace the frame with a bar welded across it.
Have fun grinding, cutting or drilling all those rivits that want to stay.
At some point when you are getting PO's get the torch or sawzall out and cut the crossmember into little pieces.
Save the front shocks, If you lower the rear they are shorter and are a cheap solution.
If your going lower the truck make sure you have the wheels centered in the wheel well. I see this as biggest problem on most of the 55-57 I've seen. You can tack the new IFS crossmember in, mock it up, set the fenders on to check it. If its wrong its easy to adjust and tack it again. Have fun.
46deluxe is offline   Reply With Quote
Old 09-11-2010, 07:25 PM   #3
vjjack04
vjjack04's Avatar
Thanks. Why will the crossmember be a problem?
Old 09-11-2010, 07:40 PM   #4
46deluxe
46deluxe's Avatar
All rivets are not created equal. I just took out the crossmember behind the cab and the bottom four ground down easy but they wouldn't come out until I cut CM in two and that 10 lb sledge knocked both sides out easy.
Old 09-11-2010, 09:55 PM   #5
waybad
waybad's Avatar
looks like a sweet truck you have there!! keep posting!!
waybad is offline   Reply With Quote
Old 09-11-2010, 10:20 PM   #6
vjjack04
vjjack04's Avatar
Thanks, I will.
Old 09-11-2010, 10:21 PM   #7
vjjack04
vjjack04's Avatar
I understand. But as for the front crossmember, I plan to keep that in place....We are going to box the frame behind it then fit the cross member for the IFS....I know it is easier said than done...
Old 09-11-2010, 10:41 PM   #8
GRIMSS
GRIMSS's Avatar
The crossmember will have to go or be chopped up big time to fit the rack.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 09-11-2010, 10:53 PM   #9
vjjack04
vjjack04's Avatar
Hum, well I can well a brace up front and cut out the front crossmember, but I was hoping to keep it......not a big deal....considering the bigger picture.
Old 09-12-2010, 07:13 AM   #10
GRIMSS
GRIMSS's Avatar
Check out the pic on the bottom of page 5 in my build, and you can see how close the new goes to the old.
2001 GMC SIERRA
1968 Camaro
Jared
Old 09-12-2010, 08:28 AM   #11
5264chevytrucks
There is so much useful information! When I get back from Afghanistan, I am planning on doing the same to my 52 c-10.
5264chevytrucks is offline   Reply With Quote
Old 09-12-2010, 09:37 AM   #12
vjjack04
vjjack04's Avatar
I looked at you pictures and I see.....Looks like I will be cutting the cross-member out.
Old 09-18-2010, 05:57 PM   #13
vjjack04
vjjack04's Avatar
I got my kit from Scott's Hot Rods this week. Looks very good. I have not gotten as far as I would have liked due to some other chores....I should have everything cut off next week.
Old 09-19-2010, 06:24 AM   #14
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice looking truck! Good luck and keep the updates coming!
ChuckDriver is offline   Reply With Quote
Old 09-19-2010, 08:49 AM   #15
candyx
candyx's Avatar
Nice clear photos please keep posting them during the install.I'm about to do mine , so what do you think about that kit is it heavy duty well contructed?Did the engine mounts come with the kit?
candyx is offline   Reply With Quote
Old 09-19-2010, 09:06 AM   #16
52 Rat
52 Rat's Avatar
Nice ride! You will like the IFS. I have installed a few IFS kits over several different projects.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 09-19-2010, 12:52 PM   #17
candyx
candyx's Avatar
Johnny are you running the stock rear and suspension or did you change it? If its stock will it have alot of rake after you install the new front end?
Old 09-21-2010, 11:54 PM   #18
vjjack04
vjjack04's Avatar
I do have a stock leaf spring set up in the rear......so it will be more "rake" than I want.....Justin at Scotts told me the front would be about a 4 inch drop...I hope to do the rear not long after the front.....
Old 09-21-2010, 11:58 PM   #19
vjjack04
vjjack04's Avatar
It is high quality....I like it but this is my first experience with this....once installed the ride quality should tell the tell.....though this seem really positive...motor mounts were extra....
Old 09-22-2010, 12:08 AM   #20
ratty 46
I'm in on this build up .... nice truck. Nice project.
Ratty 46
ratty 46 is offline   Reply With Quote
Old 09-22-2010, 12:09 AM   #21
Scottshotrods
John,
You should tell them what you paid for the ifs and motor mounts
Justin
www.scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 09-22-2010, 03:17 AM   #22
55dude
55dude's Avatar
subscribed!
55dude is offline   Reply With Quote
Old 09-22-2010, 06:16 AM   #23
ChuckDriver
Should the rear be set the planned ride height before you install the front crossmember? I just think it will change the A-Arm angles/anti-dive angle if you install the front without taking into consideration the overall down slope of the frame.
Old 09-22-2010, 07:51 PM   #24
Panelman55
Panelman55's Avatar
I like the looks of the Scotts IFS, and I noticed if you cut out the crossmember you will have to weld in engine brackets. Are you installing a V8 or inline 6. Will that set up work for a 6 cyl? Nice looking truck keep up the good work.
In God We trust!!!
Panelman55 is offline   Reply With Quote
Old 09-22-2010, 09:39 PM   #25
Scottshotrods
Our frontends will work with a 6 cyl.
Justin
