Old 02-05-2021, 12:19 PM   #51
dsraven
Re: ’48 GMC Build – Cummins 4BT, 47RH, IFS, 4-Link, Air
kinda hard to tell from the pics but it looks like the final turbo exhaust outlet is pretty close to the firewall or trans hump. did you need to cut into the cab for clearance at all?
nice innovations. keep designing stuff in your head while you rock the baby. congrats on that by the way.
Old 02-09-2021, 11:36 AM   #52
lower50's
lower50's's Avatar
Killer Job!!! I like where this is going, the compound setup should work really well and fits in there nice. Do you have an idea for HP and TQ numbers?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 02-10-2021, 06:50 AM   #53
reg3
I didn't have to cut in to the firewall to clear the downpipe, it does run about 1" away from the sheetmetal at its closest point, so i was planning to run some wrap there to keep the paint from blistering.
Using the old butt-dyno, I am hoping to land somewhere in the 250HP range with some garage/street tuning. Maybe someday ill get it to a real dyno and see what this setup can actually put out.
reg3 is offline   Reply With Quote
Old 02-10-2021, 09:52 AM   #54
dsraven
A heat shield between the body the exhaust would possibly help. Wouldn't wanna catch your flooring on fire or if no flooring melt your riders sneakers soles.
Old 02-11-2021, 09:03 AM   #55
lower50's
lower50's's Avatar
I think you should be good with wrapped exhaust 1" away, I have been running that with my exhaust for 5 years with no prob.
1951 MG TD
Old 02-14-2021, 09:53 AM   #56
reg3
Switched gears a bit and build a bracket for the transmission cooler (pun intended). I cut out some brackets and tabs and used a few spare pieces of 1x1 square tube I had in the shop. I welded the tabs to the frame and mounted it at a 45* angle so it doesn’t hang down too low. I also picked up some nifty vibration dampening studs from McMaster to mount the cooler to the bracket. Now I just need to pick up some tube end fittings to finish up the plumbing and she’ll be all done. On to the pics…
Old 02-14-2021, 10:21 AM   #57
8man
That is some really nice fab work.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
