12-05-2011, 01:19 AM | #1 |
Restoration Virgin!
50 gal tank sender?
Hey guys,
I have joined the ranks of the rare 3 door burbs and one of the first things i need to do is get the fuel gauge working It reads in the 3 o'clock position and I think it maybe a grounding issue....I was thinking of dropping the tank anyway for cleaning and wondered what fuel sending unit a dealer installed 50 gal tank uses? Thanks for any help
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
12-05-2011, 02:53 PM | #2 |
What?
Re: 50 gal tank sender?
I've seen only a couple of the custom tanks personally, and the sender set up looked just like the one in the OEM smaller tanks.
I would think that if the depth of the 50 gal is the same as the 20 something gal tank, it would work just fine so all you would need to know is that you have twice the amount of fuel compared to a stock tank.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
12-05-2011, 06:23 PM | #3 |
Restoration Virgin!
I was kinda thinking this, but I guess I'll see when I pull it...0-90ohm I assume
12-05-2011, 06:52 PM | #4 |
i had one of those in mine at one time, even have pics in my build thread, then i took it out and gave it to a friend and swapped in a newer smaller (31 gallon square body) suburban tank, but the sending unit that was in that old big sheet metal tank was held in by i believe 5 screws, kind of like the universal ones you can buy through companies like jegs etc.
12-05-2011, 06:58 PM | #5 |
6>8 Plugless........
Does anyone reproduce the 50gal tank now?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-05-2011, 07:21 PM | #6 |
Don't know whether or not the 45 gallon tank is being made, but I have an "original." Pictures of sending unit that was in it are posted. Once it's out you can isolate the problem in either the gauge, sending unit or wiring. 90 Ohm is right on the side of the sending unit. Good luck.
