Old 04-06-2021, 10:31 PM   #1
67 JW
67 JW's Avatar
barn door latch issues
My1967 Suburban barn doors latch is out of adjustment, one of the adjustment bolts broke off after replacing it I haven't been able to adjust the latch to close right I have to keep moving the latch catch on top of the door just to get it to close and then it does not close completely, I can use any help I can get guys
JW
67 JW is offline   Reply With Quote
Old 04-07-2021, 09:57 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: barn door latch issues
JW
Did you get the original bolt hole cleaned out or is it off center?
Not sure how it is not closing right but maybe you need to shim the striker down a little bit. I would have to look but you might be able to use shim plates from a side door striker plate on it.
LockDoc
Leon
Old 04-07-2021, 06:30 PM   #3
67 JW
67 JW's Avatar
I was able to get the broken bolt out without changing the threads, never had any problems before the the bolt backed out then broke off, I'm going to try loosing both bolts and go from there.
thanks for your help.
Old 04-07-2021, 08:25 PM   #4
LockDoc
LockDoc's Avatar
Let us know how it goes.
LockDoc
Leon
