02-22-2017, 09:55 PM | #151 |
Re: My tach install thread
Excellent! There are actually three SMD LEDs for illumination. I should be all set!
As a side note, the interior sure is messy. Lots of solder flux and even a layer of dust on large capacitors. I gently put the shop air to it and I'm sure I saw some debris flying off of it! |
02-22-2017, 09:58 PM | #152 |
BTW, how did you fabricate/form the mounting ring on your early prototype that the back of tach actually mounts to?
Ever find a clock? |
02-22-2017, 10:34 PM | #153 |
I currently have a 63 cluster I'm installing a tach in for a customer and i was going to use black RTV to seal the rubber gasket to the housing.
As far as the prototype, i cut the ring in the lathe and had the plate with the holes plasma cut. The reason i changed the process was because it was too consuming to make that small ring. Was easier to machine it from one pc of aluminum. |
02-22-2017, 10:39 PM | #154 |
I'm thinking your tach was assembled wrong. when you take those 2 nuts off the back, its supposed to separate. Thats how you wire it. So yours was totally crimped together?
02-22-2017, 10:42 PM | #155 |
I have not put any more time into finding a clock. I found a guy on ebay selling clusters with clocks and i asked him some questions about them...he said they were super special made and cost $300. I'm skeptical, but ok to each his own.
02-23-2017, 12:58 AM | #156 |
Yep, totally and permanently assembled. At least until I got a hold of it. I bought it from Amazon. I'm gonna see about getting the word out by giving a review that there may be a bad batch of them on the shelf.
03-03-2017, 11:16 AM | #157 |
Have you mounted the tach without the face plate on yet? Did you use the bracket from rideblue00?
03-03-2017, 06:40 PM | #158 | |
My plan was to upload a few pics but haven't gotten to it. Soon I hope. |
03-03-2017, 06:52 PM | #159 | |
03-03-2017, 08:55 PM | #160 |
Yes, I think it does look better. I also RTV'd the glass and rubber gasket on the housing just for more dust protection. The rubber also gives it a bit of cushion against the front of the cluster.
03-03-2017, 10:00 PM | #161 |
03-03-2017, 11:26 PM | #162 |
Here ya go...
03-03-2017, 11:28 PM | #163 |
03-03-2017, 11:38 PM | #164 |
Thanks. Kinda crude but it works quite well, I think. I'd love to have one like yours, Ride!
03-19-2017, 10:28 PM | #165 |
Working on a bracket for a 63 cluster
04-02-2017, 07:13 AM | #166 |
So here are a few more pics of the 63 bracket. Haven't worked out all the bugs yet. Only exception, I will have to have the original bracket off the customers cluster to machine the hole to fit the tach. Since the cluster bracket houses the fuel and the oil gauge, I'm not making a complete new bracket, just an addition bracket. unless someone knows cad and can come up with dimensions. Its a time consuming bracket, the 64-66 one i make is way easier.
04-11-2017, 10:42 AM | #167 |
Active Member
I bought your tach bracket 9/2016, have yet to do anything with it but I am thinking about buying one of the the Bosch FST8050 units. After reading the recent posts, I am not clear if my bracket is compatible with the Bosch FST8050?
04-11-2017, 11:46 AM | #168 |
The FST 8050 is what it is designed for.
04-11-2017, 03:37 PM | #169 |
Active Member
04-11-2017, 04:15 PM | #170 |
04-11-2017, 04:39 PM | #171 |
Active Member
06-27-2017, 08:19 PM | #172 |
Active Member
Would like to replicate the other cluster connections for the tach connections, any idea where I can get these terminals?
06-28-2017, 06:11 AM | #173 | |
Moderator
These guys pretend they have a web site: http://www.delmarwire.com/home/56-series-bodies/ Not sure if you can get them from here - http://www.mouser.com/ProductDetail/...jtz5p8b1U8Q%3d
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 06-28-2017 at 06:28 AM. |
06-30-2017, 06:54 AM | #174 | |
Active Member
07-04-2017, 12:25 AM | #175 |
I am interested in the 63 bracket. Let me know if you can sell me one.
