11-08-2010, 01:49 PM | #1 |
NorCal Cruiser
Ok, so im starting a build thread.
First let me introduce myself. My name is Rich and I live in Rancho Cordova, (near Sacramento) CA. I have been lurking around this forum for a wile and trying to determine what direction I want to take my truck., I can’t believe the amount of information on here. I came upon this truck on Craigslist. It’s a California “black plate” 71 short/step with a L6 250c.i. and three speed manual column shift. This project will be a D/D typ build and I will be keeping the L6 motor. Plans are to install a static 4/6 drop, c-notch the frame, repair rust, rebuild motor and clean up the Saginaw. projected 10 month build time. Im looking forward to getting to know everybody and relying on your knowledge! I will be asking a lot of questions. Stay tuned...I will update as much as I can. Last edited by Rich916; 11-12-2010 at 08:31 AM. |
11-08-2010, 01:54 PM | #2 |
Re: NorCal Cruiser
Welcome to the site From Bakersfield,Ca.
Great start
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project) It's your ride build it the way you want !!!!!!!!!! |
11-08-2010, 02:00 PM | #3 |
Re: NorCal Cruiser
Getting Started...
11-08-2010, 02:07 PM | #4 |
Re: NorCal Cruiser
Moving along...
11-08-2010, 02:13 PM | #5 |
Re: NorCal Cruiser
Looking for rust!
This will be my first time doing rust repair/Rocker replacement. |
11-08-2010, 02:16 PM | #6 |
Re: NorCal Cruiser
looks clean..
11-08-2010, 02:17 PM | #7 |
Re: NorCal Cruiser
11-08-2010, 02:19 PM | #8 |
Re: NorCal Cruiser
Cant get more basic then this!!
11-08-2010, 02:26 PM | #9 |
Re: NorCal Cruiser
wow man all that in one day!! looks good. that is a base model fo sure. yeah i had a ten month plan over a year ago..
11-08-2010, 07:29 PM | #10 |
Re: NorCal Cruiser
Moving fast!!!!
69 chevy stepside (project) 2006 Silverado Z71 Ext. cab 2005 Saturn VUE (wifes dd) |
11-15-2010, 10:27 PM | #11 |
Re: NorCal Cruiser
Welcome from another Rancho Cordova guy.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
11-15-2010, 10:49 PM | #12 |
Re: NorCal Cruiser
Nice progress. Welcome from another Sacramento guy (I'm in Carmichael)
Eric 1967 C10 LWB SOLD.... 1995 Ford F-250 4x4 Powerstroke, 342k "Each generation goes further than the generation preceding it because it stands on the shoulders of that generation. You will have opportunities beyond anything we've ever known." -Ronald Reagan |
11-16-2010, 02:18 AM | #13 |
Re: NorCal Cruiser
Nice start..
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
11-16-2010, 01:18 PM | #14 |
Re: NorCal Cruiser
Hey thanks Jim & 67chevy. Nice to see some locals.
BTW, Amazing truck you got there SactoJim. |
11-16-2010, 01:34 PM | #15 |
Re: NorCal Cruiser
Had a little time this past week to get the cab up on a dolly.
Made the dolly out of some scrap 2x4's. Attached some casters and lagged screwed through the cab mount holes. The cab wasn’t as heavy as I expected. My self, my 17yr. Old son and a couple of the neighbor kids managed it. |
11-16-2010, 01:47 PM | #16 |
Re: NorCal Cruiser
I’m getting ready to tackle my rust. So far looks like Rocker, possible inner rocker, some floor patch and small amount on the firewall.
I wire wheeled my drip seals...Looks ok. Altogether happy with the lack of rust. |
11-23-2010, 11:18 AM | #17 |
Re: NorCal Cruiser
Ok, so now im venturing into some rust repair. Cutting out the rust and making a patch was not to much of a problem.
11-23-2010, 11:20 AM | #18 |
Re: NorCal Cruiser
nice job bud....I like the basic stuff.
11-23-2010, 11:31 AM | #19 |
Re: NorCal Cruiser
Now this is embarrassing!
I haven’t welded in a long time and my only experience with welding is arc. I really debated posting this but I decided to post up the good with the bad. I ended up pulling out the patch and starting over. I need some advice...I noticed on other post that most patch work is a multitude of spot welds as opposed to welding a continuance bead. What is the problem? Am I to close? To hot? Just need more practice? |
11-23-2010, 01:44 PM | #20 |
Re: NorCal Cruiser
To me it looks like you may still have weak metal on the cowl. Even though you cut out the rust holes there still could be thin/pitted metal behind what you see. If that is true it will cause the welder to burn thru very easily. You may need to cut the cowl out wider to get to solid metal. You could also have your welder turned up too high. I don't know a whole lot about welding so I am sure someone else will be able to help you much more than me.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends. '72 blazer 2wd build 67-72 Factory Big Block Registry Last edited by 1956cameo; 11-23-2010 at 01:45 PM. |
11-23-2010, 01:58 PM | #21 |
Re: NorCal Cruiser
Welcome to the board I am in orangevale.
11-23-2010, 02:08 PM | #22 |
Re: NorCal Cruiser
You didn’t say what type of welder you’re using? MIG with gas or shield core wire, what size wire. Most welders have a chart to set up the welder for different size metal that you’re welding, this just gets you in the ball park and may need minor adjustments in wire speed or power. If I remember right that area is 18 gauge metal.
One thing that I’ve found a great help is backing up the seam with a copper backing plate. You can find some at Eastwood (hand held or magnetic) or go to the hardware store and pick up some copper tubing flatten it in a vice and have someone hold it in place when welding (make sure to wear gloves when holding it, it gets hot) You might find some additional tips on my build thread (post # 76 and more thru out the build) http://67-72chevytrucks.com/vboard/s...=318544&page=4
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544 |
11-23-2010, 02:56 PM | #23 |
Re: NorCal Cruiser
Thank you Bruce and 1956cameo,
The welder is a Harbor freight purchase with shield core wire. I new when purchasing it wasn’t going to be the ideal set-up but im hoping it will get the job done. Looks like I need to read up on all the settings. Bruce, I will try the copper backing. Great idea! Thanks for the advice guys, ill let you know how the rest of the repairs turn out. |
11-23-2010, 02:58 PM | #24 |
Re: NorCal Cruiser
Im following/followed your build threads. Amazing work bro!
11-23-2010, 03:21 PM | #25 |
Re: NorCal Cruiser
should not have a problem with an inexpensive mig welder....use .024 wire and just spot weld it all the way around the seam.....JUST ALTERNATE EACH SPOT WELD TO THE OTHER SIDE....THIS WILL KEEP IT FROM WARPING THE METAL.
