Old 11-15-2016, 01:56 PM   #576
DeanTX
DeanTX's Avatar
Re: 49 ls1
Glad to see you back Chris. I've got a lot of help and ideas from your posts with my '51 S10 swap project.
DeanTX is offline   Reply With Quote
Old 11-15-2016, 08:08 PM   #577
rustytruck50
rustytruck50's Avatar
Re: 49 ls1
Welcome back! Hope all is well as can be!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 11-15-2016, 08:22 PM   #578
Advanced Design
Advanced Design's Avatar
Re: 49 ls1
Chris, good to see you back and posting!
Advanced Design is offline   Reply With Quote
Old 11-15-2016, 09:35 PM   #579
oossuuu754
oossuuu754's Avatar
Chris it was so good to hear your voice today. You truly made my day! Cecil is great and I promise someday I will bring him back to you and we will go drive him! God Bless you and thank you again for your service to our country!
oossuuu754 is offline   Reply With Quote
Old 11-17-2016, 12:19 PM   #580
skymangs
skymangs's Avatar
Re: 49 ls1
And a big thank you to Sean sparks for starting that gofundme page.
skymangs is offline   Reply With Quote
Old 11-17-2016, 03:48 PM   #581
Big Daddy Bear
Big Daddy Bear's Avatar
Re: 49 ls1
Welcome back!
No bolt or nut in the world will remain tight if you turn it to liquid!!!
Big Daddy Bear is offline   Reply With Quote
Old 11-17-2016, 07:18 PM   #582
MIKESAD50
Re: 49 ls1
Glad to see you getting back. Glad your doing better.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 11-18-2016, 02:58 PM   #583
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 49 ls1
MAN! Glad to se youre doing better. Sorry to hear about the mishap. Hope all is good with you.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 11-18-2016, 09:47 PM   #584
LEEVON
LEEVON's Avatar
Re: 49 ls1
Chris! Glad you're posting again. I saw you in Ottawa, glad you made it out. You haven't left our thoughts. Leevon
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 11-19-2016, 01:48 AM   #585
BC Toy chest
BC Toy chest's Avatar
Re: 49 ls1
Just been reading your thread and did not expect to see what happened as I came up on your last 2 pages. God bless you and your family Bro and wish you complete recovery.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 11-24-2016, 01:50 AM   #586
Robert Andrew
Re: 49 ls1
Originally Posted by skymangs View Post
So I wound up cutting the ends of the 55 dash off, then integrating them into the doors, so that when you close them the dash becomes wrap around. I think it looks kinda trick, but there's a helluva lot of metalwork left to do!
I bought a 59 pickup dash for my 51 today, because I was impressed with your adaptation, and I have a few questions. I love the AD pickups, but the dash doesn't really appeal to me, and I love the 55-59 dash, especially with the ends wrapped onto the doors.
It appears that you have welded the wrap around ends to the door panel, which then makes the window surround trim impossible to remove. How did you engineer that so the window surround can be removed?
Are you eliminating the rubber weather stripping that seals the inside of the door to the door jamb?
Thanks,
Robert Andrew is offline   Reply With Quote
Old 08-01-2017, 12:11 AM   #587
steve aleve
Re: 49 ls1
Hey Skymangs,
I wanted to check with you to see what the track width is on the front end of your frame. I have read that a camaro sub is about 2.5 inches wider than the stock track width and I wanted to see if you had to do anything different to get those wheels to fit. Thanks again for your help! You have always been amazing and willing to help everyone!
steve aleve is offline   Reply With Quote
Old 08-01-2017, 08:10 AM   #588
skymangs
skymangs's Avatar
Re: 49 ls1
Originally Posted by steve aleve View Post
Hey Skymangs,
not sure what the track width is, trucks in mo and i'm in ia. just don't make it to low and you'll be fine. no rub as long as the suspension is aired up. i run a 17x7 up front.
Old 08-01-2017, 08:27 AM   #589
skymangs
skymangs's Avatar
Re: 49 ls1
Thanks,
i welded the dash ends directly to the window trim, there is one sheet metal screw in the bottom half attaching it to the actual door. for exactly that reason. be advised this mod is not for the faint of heart, it's a whole lot of work but man does it look cool when finished.
Old 08-01-2017, 10:45 AM   #590
steve aleve
Re: 49 ls1
Thanks!!!
Old 11-10-2018, 05:27 PM   #591
Wyattdog2
Re: 49 ls1
So I decided to mock up the 5.3 in the engine bay to see where I was at, and where I'd have to cut. I mounted it about 2 inches higher than I would have for a 350, so I can use the stock pan. Since this truck will get bagged, I don't want anything hanging below that crossmember.
Initially I had about 3.5" of clearance between the wp pulley and the rad. I'm looking for about 5". Rather than buy a different accessory drive, I decided a 2" recessed firewall was a good option. So I made some rough cuts, bolted on the trans, and blocked it in position.
what radiator did you use? I have same combo but also want dual elect fans and not finding anything that I think will fit. my firewall is not cut but the motor is very close.
Wyattdog2 is offline   Reply With Quote
Old 11-10-2018, 06:55 PM   #592
skymangs
skymangs's Avatar
Re: 49 ls1
I used speedway’s 19x22 universal rad w/ pass inlet/outlet. For the fan I used a single hayden 16", that’s one thing I’ve learned, not to skimp on fans. I only use hayden 16" now.
Old 11-14-2018, 05:46 PM   #593
Wyattdog2
Re: 49 ls1
That dash is very cool! You said you useded a speedway universal 19 x 22 radiator? Those are 22 wide it looks like, I did not think that would fit. Did you remove the flange of the support on the inside to fit it?
Old 11-14-2018, 06:07 PM   #594
skymangs
skymangs's Avatar
Re: 49 ls1
It is 19" wide, you’ll have to trim the backside of the core support.
Old 11-15-2018, 07:01 PM   #595
joedoh
joedoh's Avatar
Re: 49 ls1
not to disagree, but the speedway rad is 22" wide and just barely fits in the (trimmed) core support. its listed at that width on speedways site.
one thing I dont like about the speedway rads is that they use the same end tanks as wider (32-40") rads, which on a wider rad needs the lower hose pointed at the water pump. but using it on a 22" rad, that angled hose fitting points at the harmonic balancer.
I used an aluminum rad on the last 41 I did and the 19x22 was just barely too wide for the 41 core support, searching on ebay I found a 19x21 rad, and another benefit was that the lower hose outlet was straight and not pointed at the lower pulley.
if you think you will run a stock mechanical fan, it will be very tough to get the rad in a good spot to do that, the way it mounted in mine the fan would have cut the lower hose in half. I used a 16" electric puller on that truck.
Old 04-02-2019, 10:41 AM   #596
skymangs
skymangs's Avatar
Re: 49 ls1
Originally Posted by w70442 View Post
You're welcome. Good luck on the compressor work around. I just broke down and bought their compressor. One less thing to deal with. I'm creating enough of my own issues with the ideas I have for my build.
Interesting that you wrapped the dash around on the doors. I believe you did it cause the dash you installed originally did it but I was thinking of extending the AD dash around onto the door like that just cause I think it would add a little more modern/custom look.
Rock on........
On the Compressor, my kids truck has been running an R4 pancake for 8 years and one of my other builds uses the stock denso compressor and a Vintage Air compac and he reports no issues in 5 years! I think that myth is definitely Busted! I think that’s just something Vintage Air says to sell Compressors.
Old 10-20-2019, 11:46 AM   #597
Jesse49chevy
Jesse49chevy's Avatar
Re: 49 ls1
I just wanted to share this, I found this beautiful steering column on ebay. I checked into the company before I bought. I just couldn't believe an aftermarket tilt column for $160. They are based in Iowa, 100% locally made, and had great ebay feedback, so I took a chance. Column arrived today, couldn't be more pleased with the fit and finish of the column. Tilt, brand new 4-way and turn signal switch, it even came with billet knobs on all the levers. Totally impressed, well worth not having to re-work junkyard columns!
What length is this column? What brand is it?
Great job by the way.. Love all that you have done...
Semper Fi
Check out my project:
http://67-72chevytrucks.com/vboard/s...d.php?t=559086
Jesse49chevy is offline   Reply With Quote
Old 10-21-2019, 11:18 AM   #598
skymangs
skymangs's Avatar
Re: 49 ls1
It’s a 30" Gearhead motors from eBay
Old 10-21-2019, 11:37 AM   #599
Gregski
Gregski's Avatar
Re: 49 ls1
I am back, and posting again. Thank you Sean for setting up the gofundme site. It really did help. Thank you again. I'll be calling later today. I hope you're still happy with your truck.
Soooo happy you're back bro.
Gregski is offline   Reply With Quote
Old 10-21-2019, 02:22 PM   #600
skymangs
skymangs's Avatar
Re: 49 ls1
Thank you, I’m so happy to be back! The alternative is unthinkable! Almost got me, but I managed to squeak by!
