Old 10-13-2011, 07:41 PM   #1
Richardwa
Junkyard find
Went to one of the local wrecking yards yesterday looking for parts for my 71 GMC. Didn't find much in the line of parts but this did follow me home: 71 GMC, 350/th350, don't know about the engine or trans yet although it does turn over.
It has an aftermarket electronic ignition that I need info on, it has a box on the fender that says Hays. ( see pics)
The only things I saw missing (so far) are power steering pump, brackets and hoses, the tailgate ashtray and the keys.
I think I got a pretty good deal at $750.00, if I'm lucky it may even run!
Richardwa is online now   Reply With Quote
Old 10-13-2011, 07:46 PM   #2
str8axle55
Re: Junkyard find
Nice truck, I love it when cool stuff follows you home.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 10-13-2011, 07:54 PM   #3
rsavage
rsavage's Avatar
Re: Junkyard find
If it is solid as it looks in the photos, it was a good deal. Congrats.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 10-13-2011, 08:00 PM   #4
Rochlow
Re: Junkyard find
Nice find. There was a guy that was sell a running 69 for the price of scrap up here yesterday. Said if it didnt sell it was going to the crusher today.
Rochlow is offline   Reply With Quote
Old 10-13-2011, 08:05 PM   #5
Richardwa
Re: Junkyard find
No rust in the cab at all, some minor rust in the right fender and a little surface rust here and there
Old 10-13-2011, 08:49 PM   #6
Jerry Jones
Happy Camper
Jerry Jones's Avatar
Re: Junkyard find
That is great! NICE!
RIP El Jay! Love you brother!
Jerry Jones is offline   Reply With Quote
Old 10-13-2011, 08:55 PM   #7
sjarrett71
sjarrett71's Avatar
Re: Junkyard find
The Hays box is more than likely an electronic trailer brake controller.
Congrats on the find! It looks solid!!
-Scott-
sjarrett71 is offline   Reply With Quote
Old 10-13-2011, 09:02 PM   #8
hugger6933
Re: Junkyard find
All is good when they follow you home, thing turn bad when they pass you on the way home!!!! real nice find there good luck and have some fun
hugger6933 is offline   Reply With Quote
Old 10-13-2011, 09:12 PM   #9
71swb4x4
71swb4x4's Avatar
Re: Junkyard find
The Hays box is ignition. Here is an old Stinger catalog: http://rides.webshots.com/photo/2852...10270329bSZNYg
From what I have gathered Bill Hays sold his clutch business and started this electronic ignition company. He had to drop the Hays name right away because of his previous sales contract, so your Hays box is probably an early model. You will notice the boxes on the catalog look the same except they say Stinger rather than Hays.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-13-2011, 11:04 PM   #10
LockDoc
The Older Generation
LockDoc's Avatar
Re: Junkyard find
There are two ways you can remedy the no keys situation. For a temp fix you can find an ignition switch that has the keys, unplug the connector from the back of the existing switch and plug the replacement one in and let it hang down under the dash. For a more permanent fix take the passengers door lock out and there should be a code number stamped on it (see pic below for sample) If there is and you take it to a full service locksmith he can cut you a key from the code number and it should fit the ignition. This only applies if none of the locks have been changed. Worth a try.
LockDoc
Leon
Old 10-14-2011, 12:58 AM   #11
OARNGESI
OARNGESI's Avatar
Re: Junkyard find
Not a bad buy that truck would bring around 600 if you crush it you cant go wrong
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 10-14-2011, 12:13 PM   #12
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Re: Junkyard find
Very nice score!! I wish the yards around here would sell complete vehicles.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 10-14-2011, 08:10 PM   #13
lil hoodlum
lil hoodlum's Avatar
Re: Junkyard find
I'm not sure about the engine being from a 1971 or at least the heads. Cylinder heads before 1969 did not come with accesory holes in them.
But I agree with everyone else, a couple of nice finds. I would love to have a new project like that 1971 GMC to work with.
Congrats!
Keith
lil hoodlum is offline   Reply With Quote
Old 10-14-2011, 09:49 PM   #14
bollybib
bollybib's Avatar
Re: Junkyard find
Well said.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 10-14-2011, 10:21 PM   #15
Richardwa
Re: Junkyard find
Congrats!
Keith
The blue valve covers are what I noticed, also that they are on backwards, also the thermostat housing has a sending unit in it
Old 10-14-2011, 10:39 PM   #16
Richardwa
Thumbs up Re: Junkyard find
Well heres an update on the truck:
Battery had about 50% charge, pulled the plug off back of ignition switch and used a couple of jumper wires.
Engine started and ran rough, #1 and 6 plug wires were reversed, fixed that after a little backfire that blew a hole in the exhaust pipe.
Running smoother now, no oil smoke
Burning really rich, no black smoke but can smell fuel, tried adjusting carb, didn't help much
ran it for a couple hours while messing with it, good oil pressure, no over heating or anything too bad.
The worst thing on the truck I found is no reverse, trans goes into forward gear fine and doesn't seem to slip, but nothing in reverse
The really bad thing is now my wife thinks I should sell my 92 GMC!
I tried telling Her I have more into the running gear and wheels then I could get for it but She doesn't seem to sympathetic.........
Old 10-14-2011, 11:15 PM   #17
lil hoodlum
Re: Junkyard find
Hey man! That's great you got the motor running! I've got a simple fix for the reverse not working. Never park it in front of something again!!! Use the pull through method.
But yeah, you might want to hold off on selling your 92 GMC for a little while.
Again congrats on your new project!
Keith
Old 10-14-2011, 11:16 PM   #18
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Junkyard find
For the fuel issue-adj floats to spec (if u need help i find instructions/specs)
Still not right after that check/regulate your fuel pressure OR buy the edelbrock $100 fuel pump
Stock pump will put too much out and push the needle/seat apart and make it flood.
Start with float level/drop/clean carb then test fuel pressure with a good guage
John
1999 Toyota Tacoma 4x4
Old 10-14-2011, 11:58 PM   #19
rsavage
rsavage's Avatar
Re: Junkyard find
By the look of the casting mark on the front of them I think the heads are 58 and up 283 power pack heads. 1.72 intake, 1.5 exhaust with 59 cc chambers. Those heads were also used on 57-60 FI engines.
1961 C1 Corvette
2021 Durango RT 5.7
Old 10-15-2011, 12:55 AM   #20
FleetsidePaul
R.I.P. E.S.L.L.
FleetsidePaul's Avatar
Re: Junkyard find
Nice score!
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350.
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Every day is a gift from God.
FleetsidePaul is offline   Reply With Quote
Old 10-15-2011, 08:07 PM   #21
Richardwa
Re: Junkyard find
Thanks for that info, I will give it a try. If you could find the info that would help a lot, (never been into one of these carbs before).
If all else fails I have a double pumper on a wore out 305 around here somewhere.....might be a little too much carb though
Old 10-15-2011, 08:52 PM   #22
Rob H.
Rob H.'s Avatar
Re: Junkyard find
Well now if we hooked your truck and my 67 together we'd be fine, mine won't go in forward gears, but does great in reverse!
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline   Reply With Quote
