Old 09-29-2017, 05:49 PM   #1
profe56
Building an engine
Hi folks:good afternoon.
Firstable, thank you so much for help me to understand how to upload photos, finally looks that I can do it.
Ok: last december I bought an engine with the idea of look for someone to help me rebuild it.
Finally is here.
So far was assembly with
Forjed flat pistons.
Crower Baja Beast Hidraulic Cam.
And this heads.
to continue, I would like to know what would be the correct intake perfect for this engine. now I have installed an intake like this in the engine of my truckName:  IMG_1151.jpg
but I don't know if this will work good?
thank you so much for all of your help,
profe56 is offline   Reply With Quote
Old 09-29-2017, 10:43 PM   #2
bautino95
Active Member
Re: Building an engine
I would use the edelbrock rpm intake. Hard to tell without more info, like what your trying to achieve ( towing, street/drag, ect...). But I think the RPM is a good all around intake.
bautino95 is offline   Reply With Quote
Old 09-30-2017, 02:24 AM   #3
profe56
Street
Old 09-30-2017, 02:28 AM   #4
profe56
Originally Posted by profe56 View Post
Street
Right now I've a 305 engine but there's no power
Old 09-30-2017, 07:24 AM   #5
rockyrivermark
So the truck has a 305 now and your replacing the engine?
If so what block are you installing.
If your rebuilding the old 305 personally I wouldn't bother.
305s are dogs and not worth putting that kind of cash into.
It just won't get near the performance as a 350 with similar upgrades.
rockyrivermark is offline   Reply With Quote
Old 09-30-2017, 10:02 AM   #6
profe56
Que
Old 09-30-2017, 10:04 AM   #7
profe56
Que
Yes the rebuild it is 350
Old 09-30-2017, 10:06 AM   #8
rockyrivermark
Got ya.
Old 10-25-2017, 10:53 AM   #9
profe56
Hi folks good morning.
The water neck on the edelbrock intake leaks water coolant. I’ve been trying to stop the leak with different gaskets and still leaking, but I’m not sure if besides the gasket it also needs an o ring or if there is an special gasket.
Thank you
Old 10-25-2017, 11:24 AM   #10
geezer#99
geezer#99's Avatar
You can buy o-ring type gaskets.
No gaurentee you'll stop the leak. Sometimes it's a better idea to get a better thermo housing.
http://www.autozone.com/cooling-heat...41_69327_15298
geezer#99 is online now   Reply With Quote
Old 10-25-2017, 12:07 PM   #11
profe56
Old 10-25-2017, 12:09 PM   #12
profe56
Thank you , I think I’ve been setting the wrong gasket.
Old 10-25-2017, 09:22 PM   #13
57taskforce
All about them K’s
57taskforce's Avatar
A little Permatex the right stuff gasket maker on both sides of the gasket and it won’t leak. Doesn’t take much. Those thermostat housings can be fun to get to seal.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 11-23-2017, 07:53 PM   #14
profe56
Hi folks good afternoon: from San Diego I wish you a HAPPY THANKSGIVING!!!
Enjoy your Dinner!!!
I need your help.
I bought this air filter at a car show but now I can't find the replacement.
long 14 1\2 in
wide 8 1/4 in
thick 2 in
thanks for you help
Old 11-23-2017, 07:57 PM   #15
profe56
Here is the air filter container
Old 11-23-2017, 08:46 PM   #16
LockDoc
The Older Generation
LockDoc's Avatar
Not sure if this will work or not....
https://www.oreillyauto.com/detail/k.../e3515/4394052
Or maybe this one....
https://www.speedwaymotors.com/Singl...ment,4472.html
LockDoc
Leon
Old 11-23-2017, 10:17 PM   #17
roboticjunky
$11 https://www.summitracing.com/parts/sum-g284e/overview/
$27 https://www.summitracing.com/parts/sum-g284e2/overview/
roboticjunky is offline   Reply With Quote
Old 11-24-2017, 12:44 PM   #18
profe56
Old 11-25-2017, 10:52 AM   #19
profe56
Thank you both LOCK &. ROBOT
Old 11-25-2017, 02:03 PM   #20
LockDoc
LockDoc's Avatar
No problem. Post up which one works for you if you have time.
LockDoc
Leon
Old 12-01-2017, 03:14 PM   #21
profe56
LockDoc
Air filter just arrive, now I”ll polishing the container
Old 12-01-2017, 03:15 PM   #22
profe56
Thank you again
