Old 03-21-2017, 06:53 PM   #1
stans65
Installing a new wood bed on a 65 c10
Have a question. Just purchased new red oak planks (not a kit that would be a much easier job) to replace my old bed wood. My question is, is it OK to remove the old wood and drive the truck while I am working on it? How much stability does the bed provide? Or does it need to be a one day job? Any thoughts would be appreciated.
stans65 is offline   Reply With Quote
Old 03-21-2017, 08:57 PM   #2
PGSigns
PGSigns's Avatar
Re: Installing a new wood bed on a 65 c10
Go to The Mar-K web site and look at the tech section. very good info on doing the wood. The wood is what ties it all together with out it there is not much holding the bed on the truck. There are all the sizes and details for cutting the boards out there so you can prep them all ahead of time. You can split it up over a couple of days you will have a better time with it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-21-2017, 11:41 PM   #3
rvrfoot
I drive mine every day.Name:  DSCN0755.jpg
rvrfoot is offline   Reply With Quote
Old 03-22-2017, 12:44 AM   #4
stans65
Jimmy
Thanks for info. Found website quite informative. Will probably take out just one board to double check measurements before taking them all out.
Old 03-22-2017, 12:45 AM   #5
stans65
rvrfoot
Thanks to you too
Old 03-22-2017, 06:48 AM   #6
PGSigns
PGSigns's Avatar
I used The info from GMC Pauls to make mine and they fit perfect. Here is the link. http://www.gmcpauls.com/47-72_BedWood_Info.htm Make them based on these measurements and you will be good to go. I would order all new bolts to back with. Makes it a lot easier and a good bit of mine broke. A cordless impact will be your new best friend doing this. There are a lot of bolts to pull.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-22-2017, 08:33 AM   #7
Clyde65
Clyde65's Avatar
100% agree with Jimmy above, used the GMC Paul's info and also the Mar-k information for painting black as well.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-16-2017, 04:21 PM   #8
stans65
just a note top all, once all boards are removed, there is nothing left to hold the bed to the frame. You must either strap the bed to the frame using a few bed boards to strap to or use some of the long bolts that go through two of the boards and leave two boards. Which if i looked carefully at RVRFOOT's pic, I would have noticed.
Old 04-16-2017, 09:36 PM   #9
vince1
I thought I did mine according to those dimensions but they are too narrow. If I were to do them again I think I'd do them a few at a time and get them tighter. But that is after they have been done once and I wouldn't have to prep all the stuff underneath or the strips again.
vince1 is offline   Reply With Quote
Old 04-19-2017, 12:25 PM   #10
reed62
reed62's Avatar
Jimmy
I am not a fan of GMC Pauls info page. I took down all the measurements they suggest for board widths and lengths. That part works great. The problem is if you follow the shoulder cut they recommend for the strips to recess into you will find yourself cutting too much wood out. They recommend a total of 3/4" on each plank edge. That adds up to a total of 1 1/2" plus you have to add in the width of your anchor bolt and you end up with close to 2 inches. The stainless strips are about 1 1/4" wide. This leaves you with more gap on each side than was original from the factory. Instead of my strips riding up against the recesses, there is an additional 1/4"-3/8" gap on each side. If I had to do it over again I would only route out 1/2" or maybe 3/8" to keep the strips tighter in the recesses. It doesn't look too bad, but a tighter fit would be closer to what came from the factory. Now it may also depend on who you get your stainless strips from. I got mine from NSane Hot Rodz during their special promotion. I;m not sure if any other companies make different widths of strips or not, but I now have a larger gap on each plank than I'd like to have. Just an FYI before you start cutting your planks and routing out the grooves.
reed62 is offline   Reply With Quote
Old 04-19-2017, 01:28 PM   #11
The Rocknrod
Moderator
The Rocknrod's Avatar
Originally Posted by reed62 View Post
I am not a fan of GMC Pauls info page. I took down all the measurements they suggest for board widths and lengths. That part works great. The problem is if you follow the shoulder cut they recommend for the strips to recess into you will find yourself cutting too much wood out. They recommend a total of 3/4" on each plank edge. That adds up to a total of 1 1/2" plus you have to add in the width of your anchor bolt and you end up with close to 2 inches. The stainless strips are about 1 1/4" wide. This leaves you with more gap on each side than was original from the factory. Instead of my strips riding up against the recesses, there is an additional 1/4"-3/8" gap on each side. If I had to do it over again I would only route out 1/2" or maybe 3/8" to keep the strips tighter in the recesses. It doesn't look too bad, but a tighter fit would be closer to what came from the factory. Now it may also depend on who you get your stainless strips from. ... Just an FYI before you start cutting your planks and routing out the grooves.
Wow good info.
Old 04-19-2017, 02:11 PM   #12
vince1
Reed62 you put it much better words than I could.
Bottom line, the template needs modification.
Old 04-19-2017, 07:04 PM   #13
jayoldschool
Moderator
Their dimensions worked fine for me...
jayoldschool is offline   Reply With Quote
Old 04-19-2017, 08:26 PM   #14
1966shortwide
Dimension c is 1/4 inch that you router out . The only 3/4 inch mentioned is the board thickness.You come in a 1/2 inch from edge then router the 1/4 inch from there for the depth.
1966shortwide is offline   Reply With Quote
