Old 02-12-2011, 12:46 PM   #51
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Bolt in steering rack
I'm not so sure about that.
250 and 292 P/S brackets and pulleys are getting harder and harder to come by.
How hard would it be to make a set? Could a more common pulley be used if someone stepped up and fabbed the brackets?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-12-2011, 01:00 PM   #52
robnolimit
robnolimit's Avatar
Originally Posted by dwcsr View Post
Its does have some ugly on it, But it was a first attempt and has been refined greatly since then. The out come was to have a truck suspension under a truck that was driven daily and not have to turn the wheel 5 turns from lock to lock. As far as looks unless I planned on having the guys over to stare at my rack for the afternoon and not the gril next stores rack then I would have done a C5 or something
I'm interested, Have you drivin with this set-up? We looked at the mustang/T-Bird R/P, but it seemed to have limited movement. 5.18" total stroke, compared to 7.36" stroke lock-to-lock on the stock steering stops. Do you get full turning? Sounds like a good aproach.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 02-12-2011, 01:08 PM   #53
lolife99
67-72 parts collector,…
lolife99's Avatar
You got my hint! Ha.
A cool serpentine set-up would be cool also.
Keith
Convert to disc brakes.
Old 02-12-2011, 01:11 PM   #54
Custom 68
Custom 68's Avatar
well guys this is interesting and I will keep watching this.
so far I have built and installed an ls motor did this before it was popular so i built my own mounts so it is in a different spot than all else. I have also cut and built coil over setup for mine.
the rack and pinion would be a welcome addition however with what was said about teh engine mounts I am wondering if this will work for me? I will watch wish i was closer to california, well no I dont lol i wish u guys were closer to Missouri...
Thanks and keep us updated as you are.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 02-12-2011, 06:44 PM   #55
dwcsr
Hollister Road Co.
dwcsr's Avatar
I haven't done any hiway driving, only around the block driving. It seemed to turn ok but I really didn't pay a whole lot of attenion to the radius. I have since pulled the truck apart so I haven't driven it for a long time. I can check the lock to lock angles at the outside of the wheels and let you know just what it comes out to be.
Old 02-22-2011, 01:18 PM   #56
Custom 68
Custom 68's Avatar
bring this back up as I am interested to see what will be available and when. Like I said before my setup is way different than most as I have built what I needed to make my truck what it is but this looks like a neat option.
Dave
Dave
Old 02-23-2011, 12:29 AM   #57
robnolimit
robnolimit's Avatar
don't worry, I'm still working on it.
Old 03-03-2011, 08:00 AM   #58
rob32472
update?
rob32472 is offline   Reply With Quote
Old 03-03-2011, 04:36 PM   #59
robnolimit
robnolimit's Avatar
We are now driving, and testing. Also, we have to work with a rack manufacturer, to get them the way we want, so that is still in negotiations. I should know more next week.
Old 03-03-2011, 05:25 PM   #60
Mechanic77
Just out of curiosity, how is the clearance between the engine and the rack? I've got my engine set as low and as far back as I could get it without major cutting and there is barely an 1/8" of clearance between my crank pulley and my center drag link.
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627
Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948
Mechanic77 is offline   Reply With Quote
Old 03-03-2011, 08:19 PM   #61
robnolimit
robnolimit's Avatar
I think it will be OK, top of the rack body is 3/8" lower than the top of the stock drag link
Old 03-04-2011, 11:59 AM   #62
Mechanic77
Cool, any ballpark guesses when you'll have it ready for market?
Old 03-04-2011, 04:18 PM   #63
robnolimit
robnolimit's Avatar
Well, in typical No Limit style, it may take a few months. I'd say July is a safe bet. I can't, in good conscious, sell a new part that we have'nt beat on for at least 5k miles, then dis-assembled and tested. After all, these are steering parts, and we would hate to kill someone. , but i will keep everyone up to date. Thanks for the interest.
Old 03-10-2011, 05:04 PM   #64
rob32472
Any pics?
Old 03-26-2011, 11:49 AM   #65
robnolimit
robnolimit's Avatar
Here's a few spy shots. The new mounting does not require any cutting or welding to the crossmember. Just drill five mounting holes. A small notch is needed to clear the steering. This unit is mounted on the JT, and will be in Del-Mar next week. We are now moving into the production phase.
Old 03-26-2011, 12:02 PM   #66
rob32472
Put me down for the first unit! This falls into what I have been going for on project cod fish! Old school look with modern technology. I am very excited to see this come about thanks for all you guys do to make our trucks better!
Old 03-26-2011, 01:19 PM   #67
chapster
chapster's Avatar
Hey Rob,
Any pics of the driver side motor mount/rack clearance?
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler
1968 Chevy c10 shorty Stepper (Patina LS project)
1967 gmc custom Long Box (Farm Truck Project)
chapster is offline   Reply With Quote
Old 03-26-2011, 02:58 PM   #68
Mechanic77
Looks good Rob Just curious, is it set up for optimum bumpsteer with stock caster, or is it set up for arms with increased caster?
Old 03-26-2011, 03:10 PM   #69
Tmend
Tmend's Avatar
Let's us know when they are available for purchase ill take one. Thanks for keep us posted
Tmend is offline   Reply With Quote
Old 03-26-2011, 07:54 PM   #70
robnolimit
robnolimit's Avatar
Mech77, It is a tunable set up. The new tie rod end sits under the steering arm using a high-misalignment rod end. With stock arms, (and 2 or 3 deg of caster) use no spacers, then add 1/8" spacer for each 3* of increased caster.
Old 03-26-2011, 08:29 PM   #71
killerpickup
Hey Rob, Ive been following your threads with drool running, You once stated the lower and further back the better, sooo. How about ten inches back and four inches lower. Ill have some pictures later.
killerpickup is offline   Reply With Quote
Old 03-26-2011, 10:26 PM   #72
robnolimit
robnolimit's Avatar
I guess that's not with a stock firewall , Is oil pan clearance an issue? Love to see it.
Old 03-26-2011, 11:35 PM   #73
Mechanic77
Awesome....still looking at $600-$700 for the kit? Also, any closer guess on when it will be available?
Old 03-28-2011, 06:59 PM   #74
Custom 68
Custom 68's Avatar
I like the spy pics. glad this is commong along. thanks for the updates:
Dave
Old 03-28-2011, 07:28 PM   #75
SBTork
Garage wrench
SBTork's Avatar
I assume this set-up will work with the 73-87 GM trucks, maybe with a different outer tie rod end? Or, does it use the stock outer tie rod end?
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
