05-28-2015, 03:35 PM | #1 |
Re: My 52 GMC Build
Today I got my inter-cooler in and hooked up.
First pic is looking where the rad should be. Second pic is the intake hat that I made. Third pic the 3" hose I'm using. It should work it's rated at 230* and 30 psi. I don't think it looks to bad.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
05-28-2015, 04:28 PM | #2 | |
Re: My 52 GMC Build
Just my unsolicited opinion, but I don't like the flexi hose for the turbo outlet to the intercooler is a good idea. Since you're planning on cranking up the boost, your turbo outlet temperature could end up very close to the 230°C limit of that hose, but you may also get extra heat transfer from the engine bay to the air in the hose. I guess my point is, do you want to take the risk of melting the hose and feeding dirty air into the engine? I think solid plumbing would not only work better, but would be safer and perform better. Just one opinion. |
05-28-2015, 05:07 PM | #3 | |
Re: My 52 GMC Build
05-28-2015, 05:17 PM | #4 | |
Re: My 52 GMC Build
05-28-2015, 05:44 PM | #5 | |
Re: My 52 GMC Build
Tags |
bagged, build, diesel, gmc, hot rod |
