Old 07-20-2008, 04:53 PM   #1
TR65
TR65's Avatar
Hydraulic Clutch Conversion 1965C10
Hey guys,
Here is one way to add a hydraulic clutch master cylinder to a 65C10.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 07-20-2008, 05:05 PM   #2
TR65
TR65's Avatar
Re: Hydraulic Clutch Conversion 1965C10
Here are the last two pics.
TR
1965 C10 SWB Fleet
Two owner
Old 07-20-2008, 05:25 PM   #3
BobS
BobS's Avatar
Nice setup!
Bob
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 07-20-2008, 05:36 PM   #4
kevindtimm
I'm wondering how that would work out for the 62 trucks (so that I wouldn't have to spend $500 on a dual MC for power brakes and my clutch)
Do you have sourcing, part numbers, pricing, etc. on these pieces?
Very nice BTW, very very nice.
kevindtimm is offline   Reply With Quote
Old 07-20-2008, 07:49 PM   #5
TR65
TR65's Avatar
Kevin,
The Wilwood master cylinder is 260-3374 Summit Racing $66.88 shown in the picture.
The heim joint is 6072K165 5/16dia. 5/16-24 thread RH 3200# capacity $5.47 McMaster Carr
The shoulder bolt is 91259A578 5/16dia. 1/2" long, 1/4-20 thread $1.09 McMaster Carr
That was all there was to buy except the bar stock, bolts and nuts, and of course the hydraulic line to the slave.
Pretty inexpensive solution.
TR
1965 C10 SWB Fleet
Two owner
Old 07-20-2008, 11:00 PM   #6
qksilver
No problems with the firewall flexing?
qksilver is offline   Reply With Quote
Old 07-21-2008, 10:07 AM   #7
Yukon Jack
Yukon Jack's Avatar
How does the slave mount? Very nice install. I'm using a 1989 1 ton's hydraulic clutch setup on my 69 K20.
How does the effort needed to work the clutch compare with the stock setup? A boardmember with a bad knee was asking about that issue so this will be informative to him.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-21-2008, 11:19 AM   #8
kevindtimm
TR, thanks very much. That is some very nice work.
Old 07-21-2008, 02:56 PM   #9
TR65
TR65's Avatar
Thanks for the kind comments men.
Jack,
I haven't actually installed the transmission yet, just getting ready while keeping the truck on the road. I expect clutch effort to be pretty light since it should be the same or less than a current Vette, GTO manual clutch and the clutch pedal is a little longer on the truck.
The slave is a current stock T56 center pull mounted in the bell housing around the main shaft.
Quicksilver,
The firewall is quite rigid in that area due to the re-inforcing channel to the right and the contour to the left. No visible flexing.
TR
1965 C10 SWB Fleet
Two owner
Old 07-22-2008, 11:50 PM   #10
Captainfab
60-66 Nut
Very nicely done TR65
Old 07-23-2008, 07:52 PM   #11
79gmcsierragrande
Manual Transmission Club
79gmcsierragrande's Avatar
Thanks for that. I'm looking to put a NV4500 in my 79 sierra, I'll have to save this post for when I'm ready.
79 GMC Sierra Grande, SWB, Heavy Half
If I wanted easy I would just buy a NEW truck!
79gmcsierragrande is offline   Reply With Quote
Old 07-23-2008, 08:05 PM   #12
Anthony Fremont
Anthony Fremont's Avatar
Excellent job dude. Where'd you get those pressure gauges? What is the range?
'66 GMC Custom Fenderside LWB
'90 IROC - L98
'97 1200C Sportster
Anthony Fremont is offline   Reply With Quote
Old 07-23-2008, 09:09 PM   #13
TR65
TR65's Avatar
Anthony,
The gages and adjustable proportioning valve are from SSBC (Stainless Steel Brake Corp). The range is 0-2000psi. I want to see the split between front and rear brake pressure (4 wheel disc). I set it at one number for unloaded so both axles lock up at the same time, less split for loaded. Oh, and I like gages.
TR
1965 C10 SWB Fleet
Two owner
Old 07-23-2008, 09:18 PM   #14
TP from Cntl PA
TP from Cntl PA's Avatar
Interesting.............Would like an update on how it works!
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 07-23-2008, 09:41 PM   #15
Anthony Fremont
Cool, looks trick to me, but then I like gauges too. Did you have to flare the end of those lines, or are those compression fittings? Sorry, I'm nosy like that. :-)
'90 IROC - L98
'97 1200C Sportster
Old 07-24-2008, 03:30 PM   #16
TR65
TR65's Avatar
Anthony,
The lines use inverted flare fittings.
TR
1965 C10 SWB Fleet
Two owner
Old 04-16-2009, 11:48 PM   #17
joe231
joe231's Avatar
very nice write up as usual TR!!
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-31-2010, 12:06 AM   #18
TR65
TR65's Avatar
Well guys, I finally got my new engine and transmission installed so I can update this thread.
The slave cylinder is a center pull late model (2005) with no bleed screw. I used my one man brake bleeder attached to the bleed screw on the master cylinder. I am using silicone fluid. All I had to do was the pump the clutch pedal for a few minutes until all the bubbles stopped coming out, done.
Since the master cylinder mounts level no bench bleeding was necessary.
Tip. The actuator rod should line up level with the master cylinder at the bottom of the stroke, not the top as in the above picture. So when it was pushed in all the way it was rubbing. So I had to elongate the hole in the pedal to fix that.
The pedal effort is fairly high, pretty much like the mechanical clutch that was in the truck. You could use a smaller bore master cylinder to reduce the effort if you wanted.
It will be a couple of months before I get the engine running so I can see how the release feels.
TR
1965 C10 SWB Fleet
Two owner
Old 01-31-2010, 03:28 PM   #19
Winola73
Well written and good pics, glad you brought that BTT, I'll be doing a '66 this Spring. Thanks!
Winola73 is offline   Reply With Quote
Old 02-05-2010, 01:24 PM   #20
dan468
dan468's Avatar
TR
what keeps the bolt in place with the elongated hole now? Can't it move around in such a big hole? Why did you choose to make a new hole in the first place? Wouldn't the factory hole give you the precise original throw?
thanks for the help, just got a T 56
- Dan
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 02-19-2010, 04:09 AM   #21
zammer
Addicted user
zammer's Avatar
This may seem like a goofy question but how/where do you get a slave cylinder on which you mount to the actual clutch?
(from what i have tried to read up on was the slave cylinder is called a hydraulic throwout bearing? ) Is that what the slave is??
I see you wrote you got a slave from an 2005 model something... some pics of that setup would be great as I would really like to put a hydraulic clutch on my older muncie transission...
thanks!
zammer is offline   Reply With Quote
Old 02-19-2010, 10:59 AM   #22
sdailey
The Few, The Proud
sdailey's Avatar
thanks!
I installed a hydraulic slave cylinder on SM465 4spd. There's a company called Novak that makes the kit.
Here's a link for the kit I'm using.
http://www.novak-adapt.com/catalog/kit_hcrc.htm
Here are a few pictures of what it looks like installed.
I hope this helps.
Shannon
sdailey is offline   Reply With Quote
Old 02-20-2010, 12:26 PM   #23
TR65
TR65's Avatar
- Dan
Hey Dan,
No problem with the elongated hole just tighten the bolt sufficiently. I had to elongate the hole due to my mistake so I hope somebody else can avoid that.
I am driving the clutch cylinder from the left side of the pedal. The factory mechanical clutch goes thru the pedal mount pivot and drives a lever arm on the right side of the pedal. So there is no factory hole for what I am doing.
By the way, the T56 shifter is way back and would come up under the bench seat of our trucks. If you have buckets it can work. You can move the shifter position which is what I did. (It is a major undertaking though)
http://67-72chevytrucks.com/vboard/s...d.php?t=300892
thanks!
Zammer,
The T56 uses a center push slave cylinder that mounts around the input shaft of the tranny. The transmission needs to be made for that.
Shannon's setup looks sweet for a traditional style clutch slave!!
I would think that you could also use the factory hydraulic slave setup that was used on the older trucks.
TR
1965 C10 SWB Fleet
Two owner
Old 02-20-2010, 08:13 PM   #24
zammer
Addicted user
zammer's Avatar
Thanks guys, thats exactly what is was wondering and looking for..
The only problem I have now is I can't really mount an external slave cylinder as I got a set of those Sanderson shorty headers from ECE and they don't fit around the stock Z bar AND... they dump right above the fork so its pretty hard to get a bend in there to clear the fork and linkage, an external slave to be almost impossible as they hug the block.
What kind of hydraulic internal / throwout bearing can i use??? Anyone use something on there manual trans instead of the stock fork??
My 4 speed is dated around 1977.. not sure if this matters or not.
Old 02-20-2010, 08:55 PM   #25
dan468
dan468's Avatar
Can you show pics of the Z bar interference? Can you mod or "dimple" the headers at all? I also asked FrizzleFry if the Patriot Clipsters might clear a Z bar on his BBC header thread.
68 C-10
Build thread
