01-17-2020, 04:47 PM | #1 |
Dash at windshield screws
Are there supposed to be 3 to 4 large screws where the dash and windshield pinch weld meet? Popped my windshield out and saw a few screws, thought it was supposed to be spot welded all the way.
01-17-2020, 05:56 PM | #2 |
Moderator
Re: Dash at windshield screws
On my 64 the only screw you can see once the rubber is removed is for the speaker bracket.
01-17-2020, 06:46 PM | #3 |
This is what I'm refering to.
http://67-72chevytrucks.com/vboard/a...1&d=1579301105 |
01-17-2020, 08:55 PM | #4 |
It's Better With Nitro
There should be 4 sheetmetal screws (2 on each side) that hold the front windshield defroster vents in place.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
01-17-2020, 10:53 PM | #5 |
60-66 Nut
This \/ \/. There should also be screws for the speaker mount as well.
