11-09-2016, 11:24 AM | #1 |
Can this be fixed without filler?
It is possible to get behind this dent and push it back out? I really do not want to use filler in this area as I think it would not hold. Any advice would be appreciated. TIA.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Coming soon: EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 |
11-09-2016, 04:04 PM | #2 |
Re: Can this be fixed without filler?
i assume you mean the gap in the jamb? pic not clear to me. if so i would pull it.
11-09-2016, 04:10 PM | #3 |
Yes, the jamb. The leading edge has been pushed in about a 1/4". I was going to remove the seat and tank and see if I could get behind there, but I am not sure I can.
11-09-2016, 07:10 PM | #4 |
You can use a spot gun. You could metal finish it if you have the skill and time. It would be easier to work out as much as you can with a spot gun/hammer/dolly then do a skim pass of filler.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
11-09-2016, 09:46 PM | #5 |
lf you don't have a spot gun like suggested above, you could weld [tack weld] a strip of scrap on there and pull it with a come-a-long and it should pull pretty easy. Also You need not worry about filler there if prepped right you will be fine.
11-10-2016, 07:28 AM | #6 |
You could also weld some tig filler rod on there to fill the void and then grind smooth, so the actual edge is at least steel
11-30-2016, 03:43 AM | #7 |
I welded along that area evening up the door gaps, and I think I angered some deep down 40 year old rust that was hanging out between the spot welds. That's the only place that has started to rust on my truck.
I would be cautious welding in that area. Lynn |
11-30-2016, 11:41 AM | #8 |
I am planning on using a hammer and dolly, but if I have to weld it, then that is what I will do. I do not have any welding equipment so I will have to hire it done.
11-30-2016, 06:01 PM | #9 |
Our local Rent tool place has welders you can rent. Otherwise I hired a portable welder to do some work once it wasn't to high of a price
12-18-2016, 07:44 AM | #10 |
Use a straight edge to determine how much of the jam needs to come forward ,
Using your cut off wheel cut 1"in from the edge to 1/2" past the length you want to move forward using a stud gun pin ang pull forward from the door jam that section lightly until your happy with the fit . Tack weld patch panel in place and work as usual. Most all doors have a distortion in that area from the manufactor processing of the door panel , you can add multiple tacks to build up the area or tack some rod in place and grind to fit , this area gets overlooked many time even on high end truck builds . Have fun , but remember it's only metal ... |
01-08-2017, 01:22 PM | #11 |
Yes, get some round stock, got mine at lowes... think it was 1/8th thick, welded in, oshpo then painted...well not painted yet... weld stuff dont use that bondo as less as you can, ish cracks and ruins everything
01-08-2017, 01:23 PM | #12 |
Keep us posted on how it turned out!
01-08-2017, 03:15 PM | #13 |
elf, it will be a while before I get to this, but I will post the results and the method of repair.
