05-24-2018, 05:51 PM | #1 |
2WD Lowered - Shock Mount Relocation Needed?
I have a 4/6 drop - standard stuff. Spindles, springs, and drop shocks. I'm rebuilding all my suspension and wonder if I should fabricate some shock relocation mounts. I really don't like the flimsy 2-bolt brackets that bolt to the top (flat part) of the frame. I want something much stronger that bolts both to the top of the frame, and the sides. No one makes a bolt-on kit like this, although they do make them for the 67-72 guys. Anyone done something like that this that can post or text me pictures?
77 C10 Silverado SWB - LS Swap, mechanical resto-mod 05 Z71 Silverado RCSB - 5.3L LM7, 76mm turbo, 4L80e |
05-24-2018, 09:04 PM | #2 |
Happy to be here
Re: 2WD Lowered - Shock Mount Relocation Needed?
RideTech makes them. I have installed several sets
05-25-2018, 08:37 AM | #3 |
You shouldn't need it. I have stock replacement KYB shocks on my truck and it sits the a-arms 1/4" off the ground when aired out. I had a setup like you have pictured and it was constantly tearing up the washers that go over the bushings. It also wasn't allowing it to go all the way down. It rides a littler better now with the stock setup.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
05-25-2018, 11:49 AM | #4 | |
Not all front shocks for 73-87's have the exact same dimensions. Add in different drop variations (how much spindle drop; how much spring drop) plus each individuals ride quality preference & the statement "you shouldn't need it" is probably a little broad.
05-25-2018, 12:56 PM | #5 |
Happy to be here
Scoti is being politically correct bluex. I feel that shock extenders should be part of any front suspension drop that includes short springs. If you reduce the shock travel by 1,2, or 3 inches a shorter shock will not offer a better ride. No matter what combo of fluid, gas, or valving a shock uses for damping, it needs travel to be effective. The shorter the travel, the less effective it is.
After trying several shorter or "drop" shocks I discovered that would not improve travel. Now, I "always" add upper shock mounts in front with longer shocks.
05-25-2018, 03:09 PM | #6 |
If you're not cutting down the bump stops why wouldn't stock length shocks work fine ?
81 short step. |
05-25-2018, 07:33 PM | #7 |
driving is in my blood
My 78 uses 2" springs up from with stock shocks. If I lowered it more i would finally get drop shocks but I wouldn't even think about moving the mount for the shock, oem one works just fine.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
05-25-2018, 09:57 PM | #8 | |
I tried to add those brackets that go on the top of the frame. No way they would have worked with a stock length shock for me. I would have gotten about 1" of up travel over my ride height. Stock location and stock replacement style ones worked best for me an give 11" of travel. I couldn't get that with the stud style shocks and I personally felt they were too soft as well. Everyone has their own preferences. I'd suggest to everyone, break out a tape measure an look up the specs of the shock you want to run and see if it will work before spending money on a relocation bracket.
05-28-2018, 01:30 AM | #9 |
Heres ones I made for mine
https://www.facebook.com/photo.php?f...&theater&ifg=1 They have a tab on top of the frame and a backer plate inside the frame. 6" travel AFCO shocks. |
05-28-2018, 08:41 AM | #10 |
do you have other pic,I don,t use facebook
05-28-2018, 10:36 PM | #11 |
