03-29-2016, 03:45 PM | #51 |
6>8 Plugless........
Re: 71' suburban 4x4
How did you mate the 46rh to the 4bt?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
03-29-2016, 05:16 PM | #52 |
My 46rh came out of a 93 W250 with a 5.9 Cummins so it had the adapter plate, TC, and flexplate/flywheel that I needed.
03-30-2016, 12:43 AM | #53 |
Does your valve body have a 3 pin or 2 pin connector? If it has 2 it is a a518. If it has 3 it is a 47rh. 46rh's were behind gas engines and have a smaller bell housing.
03-30-2016, 08:57 AM | #54 |
I have no idea what is because as from the begining, everyone has a different story. It does not have lockup but has OD and came from a 5.9 Cummins. I was told 47rh has lockup and 46rh does not ans is more stout.
03-30-2016, 10:19 PM | #55 | |
Sorry for hijacking your thread. Have any underhood pics of the beast?
03-31-2016, 12:10 AM | #56 | |
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
03-31-2016, 02:46 PM | #57 | |
03-31-2016, 04:21 PM | #58 |
Special thanks to Hawgee.com for the [BROKAGAIN] vinyl. If anyone has trouble seeing at night you've got to get these Cibie Z-beam fixtures and 90w low beam H4's. Last edited by infinite-foamies; 03-31-2016 at 04:26 PM. |
03-31-2016, 04:39 PM | #59 |
Do you have a link?
03-31-2016, 05:12 PM | #60 |
Link for what?
Here is the pic, for some reason I can't edit my own post? |
04-03-2016, 06:11 PM | #61 |
Had a good day wheeling at Rausch Creek with Steel Soldiers on Saturday:
Does anyone know the difference between the inside door handle mechanism from 67-71 and 72? |
04-03-2016, 11:03 PM | #62 |
The Older Generation
Sounds like a good time. The shafts on the '72 remote door handles and window regulators are longer because the door panels are thicker. LockDoc
04-04-2016, 08:40 AM | #63 |
04-04-2016, 11:25 AM | #64 |
Dynamat is not sound deadening, it is vibration dampening. Mass loaded vinyl is sound deadening. You only need about 50% coverage with vibration, sound you need 100% coverage, or as close as possible
04-04-2016, 04:17 PM | #65 | |
Either way do you know good cheap materials? |
04-05-2016, 09:33 AM | #66 |
Unfortunately, there isn't really a cheap way to do sound deadening. It's all really quite expensive, I am in around $1,000 in my Suburban, and I am not even done yet. You can buy that peel and seal from the hardware stores pretty inexpensive and get the vib dampening at least
04-05-2016, 02:04 PM | #67 |
a friend of mine recommended hvac duct insulation, not sure if thats the peel and seal you are referring to but he says it works great and is fairly inexpensive.
04-05-2016, 03:18 PM | #68 |
I think the 67-71 pieces will bolt on a 72 door. The wing windows have an extra bracket on the 72 models and there is an extra hole in the door shell to mount this extra bracket on the wing assy.
04-13-2016, 02:51 PM | #69 |
I am looking at modifying my Cobra 29 LX BT to have a remote mount face plate and then using a factory style dual speaker for the CB. Then use the other cone from the dual speaker for the HAM radio, but I don't know if these will need to be amplified. Anyone have experience with this? I will be making custom speaker enclosures for my actual speakers so this would be unused otherwise.
05-01-2016, 06:28 PM | #70 |
Got some shelving built for the tools and camping gear, model airplanes loaded up for the trip to South Carolina.
Got the second fuel tank mounted which needed a small amount of modifications to work with the trailer hitch and I had to modify the filler neck to deal with the cross member, pictures to come of this. Using a fuel valve out of an 86' Square body because I had it. This year valve uses a motor instead of a solenoid and retains its position until you tell it to switch. |
05-05-2016, 08:03 AM | #71 |
just curious, saw your post in the 4x4 trucks page and you said 32mpg, what speed were you going, what gears you got, and what tire size. I don't know much about the differant 5.9's but is yours computer controlled or mechanical
Thanks! |
05-05-2016, 11:15 AM | #72 |
If I said 32 it was a typo, meant 30. 30mpg is achieved at about 60mph with 3.73 gears, 235/85/16 tires on about 45psi of air. Running a Dodge A518 OD trans with an NP205 behind an 1985 fully mechanical 3.9(4BT).
05-05-2016, 11:36 AM | #73 |
just realized it was a 4 cylinder, pretty slick
