12-06-2011, 09:25 AM | #51 |
Re: Delco radio with aux. input added
As an FYI, Dual still makes a shaft mount unit with front aux in and pre-amp outputs, for less than $40 on Amazon...
-Don- '66 C10 w/factory A/C '77 Cheyenne K5 350/465/205 '80 Custom Deluxe K20 350/465/205 '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf |
12-06-2011, 01:26 PM | #52 | |
Though I really like the look of having the original stereo. Throw in that when complete I will have under $5 out of pocket into it. (plus a few hours ). Also resale of this mod is great. These modded units often go for $100 on ebay. |
12-06-2011, 01:42 PM | #53 |
Dual XC4100
Pre-amp out is a huge plus. Just say'n. Posted via Mobile Device
12-06-2011, 04:37 PM | #54 |
MOVE OVER
subscribed to this post for future reference once I get my truck running again
No matter where you are..... There you are... Buckaroo Banzi |
12-06-2011, 11:27 PM | #55 | |
If I was driving the truck all the time I would go that route, or probably spend a little more for lot more features. But my son is driving it, and I have more time than money. With all the parts in the garage, I will be out under $5 for Ipod connection with high/low pass filters and a 10" Sub. If I was spending money your suggestion would get serious consideration. Edit: btw I already have a Line Output Converter (LOC) to get the preamp signal. But if I was having to buy that or other parts I would really be looking at the alternatives mentioned. |
12-06-2011, 11:39 PM | #56 |
you could go aux to pre amp or amp.. not direct to the spk.. i am not as up to date as the op but aux is 0 db so you need to bump that up
12-07-2011, 01:03 AM | #57 |
It's always something
I am trying to track down a radio out of a caddy because I thought they had a power antenna that is activated when you turn on the radio. This source could be used to also turn on the amp, but I can't find any schematics for it so I am just going to wing it. Anybody have any info on this.
12-08-2011, 09:50 AM | #58 | |
I opened mine up and the red wire that goes to the amp board from the back connectors, right next the the orange/green wires that carry each channel, is the power. You can easily see it in the 4th pic in post #1 coming from the back of the radio up to the same area the spliced aux input wires are at. I just spliced a single wire insulated connector into that and dangled the connector out one of the holes in the back of the case. That way I have a quick disconnect at the back for the remote wire. |
12-09-2011, 08:44 PM | #59 |
Just here to tinker
Hey guys, if this helps, I drew this while I am doing the mod to my stereo:
(This is for the switchable 1/8" aux jack)
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
12-31-2011, 07:59 PM | #60 |
Nice mod. How about adding a blue tooth audio receiver so songs can be played from a smartphone.
Amazon.com: Britelink Bluetooth Audio Receiver:... |
01-31-2012, 01:43 AM | #61 |
Chevy Enthusiast
Anything new Crammit? I need to go hunt down a stock style radio so I can do this. Did you try out the caddy power antenna to amp idea? That would be really cool to do while im in there, im just not good enough at this kind of stuff to figure it out on my own.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
01-02-2013, 11:15 PM | #62 |
My radio looks and is wired like Telecasterjoey how did you wire your aux up I looked at it and can't figure it out
Posted via Mobile Device |
05-07-2014, 11:03 PM | #63 |
Reviving this thread
I want to try this Also want to use one or two amps Is there a way to install pre amp outputs in here ? To bypass the amp board ? I have to do that to use Amps right ? |
08-01-2014, 01:29 AM | #64 |
Really good mod very helpfull post subscribed for when my truck gets reassembled
09-18-2014, 11:57 PM | #65 |
Subscribed so I can find this again...
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
09-19-2016, 09:35 PM | #66 |
I know I'm bringing this post back from the dead, but it's for good reason. Well, for me anyway.
My question is, why can't you do this on AM radio? Is it because I only have one speaker in the center of the dash? If that's the reason why then I think I might be able to still do it. The center white plug on the back of my radio currently has two wires running out for my one speaker, but there's another set of open ports in the plug for another speaker and they work. So if I wire up the other ports for another speaker I would no longer be mono, but stereo. Right? Or am I way off. Posted via Mobile Device |
12-19-2016, 09:52 PM | #67 |
03-30-2019, 12:57 PM | #68 |
I know this thread is over 3 years gone but im fixing to do this to mine. I've been wondering if someone had done this to a 80's unit.
03-30-2019, 04:18 PM | #69 |
Did this to the radio in my 85 C10.
Worked great.
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
03-30-2019, 09:53 PM | #70 |
Call Rickwood Radio in Birmingham, Ala and speak with Tim in Service. They used to be GM's warrenty repair. From way he talked hes been there for years. Im going to send my radio out of my 86 to them in a couple weeks to be checked. 250-942-5595.
03-31-2019, 03:16 AM | #71 | |
Harley03joe
1931 Ford Like New And For Sale 2004 Harley Davidson Heritage Classic 1987 Chevy R 10 Silverado 2007 Azera 2011 Cadillac CTS Premium |
03-31-2019, 10:31 PM | #72 |
03-31-2019, 10:34 PM | #73 |
04-02-2019, 01:59 AM | #74 | |
Basically, instead of having to pull the stereo out and have it modified, I just added a Bluetooth Amplifier. Your phone or ipod will connect to the amp wirelessly to play all your music, but then you wire the stock radio to the amp as well so you still get your factory AM/FM radio. Also it sounds way better because its running through the amp to your speakers. cheers
"Sweet Pea" 1975 Cheyenne 20 http://67-72chevytrucks.com/vboard/s...00#post8477900 "Bourbon" 1975 Suburban ScottsdaleSOLD https://67-72chevytrucks.com/vboard/...49#post8769049 ”Otis” 1970 C10 SWB -SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=762766 ”Chebby” 1962 Impala LS/TKO-500 http://www.pro-touring.com/threads/1...2-Impala-Build |
