Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-20-2010, 11:44 PM   #101
redhead69
fugedaboutit
redhead69's Avatar
Re: post latest 1/4 and 1/8 mile times and 60ft.
13.73 with my basically stock 400 sb. 60 mile round trip drive.. cant find my slips but I think they were like 1.88 60ft and 95mph.. Hoping for 12s this year, money allowing
Currently truckless
redhead69 is offline   Reply With Quote
Old 12-20-2010, 11:48 PM   #102
redhead69
fugedaboutit
redhead69's Avatar
Dougminton- nice times, Id like to see what it would run with like a 28" tire and those 4.11s! Man I would think 12.6s-12.8s no problem!
Currently truckless
Old 12-21-2010, 01:34 AM   #103
Super73
Super73's Avatar
Originally Posted by dougminton View Post
It spun just a little. I think my trailing arms being a foot shorter than stock helps it plant the tires (used to be a longbed leaf spring truck)
You shortened the trailing arms?
Are they in the factory location (front eyelet) regarding both height and location on the frame?
I was unaware the long beds and shortbeds having different control arm lengths.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 12-21-2010, 01:36 AM   #104
3r!c84
Badass
3r!c84's Avatar
im taking out my c10 with a hot 400 sbc out in a few days to the track. ill post my times
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-21-2010, 08:37 AM   #105
dougminton
dougminton's Avatar
I left the crossmember in the longbed location when I shortened the frame to make it a shortbed. So I designed my own suspension loosely based on the stock stuff. Pic is with everything just tacked together to check the fit.
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline   Reply With Quote
Old 12-21-2010, 03:52 PM   #106
Super73
Super73's Avatar
That looks like the stock location for the shortbed as well. I notice you made the front mounting point adjustable, good idea.
Springs appear to be furtner back towards the axle than on a shortbed. That will put less leverage on the spring, meaning you can run a lighter spring rate than a similar weighted truck with stock location. There are pros and cons for this.
My guess on why you are not getting much tire spin at the track would be directly related to gearing and converter. You have a TH400 which has a 2.48 fist gear and a 3.08 rear gear with a 32" tire. Not sure about verter. That combo's means you have an amazingly lazy first gear and you are not hitting the tires very hard at all.
For comparison sake:
TH400 + 3.08 + 32" + 6,000 in first = 71mph
TH350 + 2.73 + 35" + 6,000 in first = 71mph
Powerglide + 3.73 + 28" + 6,000 in first = 72mph
Old 12-21-2010, 03:56 PM   #107
dougminton
dougminton's Avatar
shortbed factory location is 12" forward of where mine is. They had just VHTed the track. It'll turn em into smoke at 30 MPH on the street.converter will go 4000 on the foot brake.
1972 GMC SWB
454 oval ports
TH400
13.05 @ 104
Old 12-21-2010, 07:43 PM   #108
Super73
Super73's Avatar
If that is the case, then the shorter arm coupled with the geometry change will put more angle in it effectively increasing antisquat numbers forcing the tire in to the ground. Did the rear feel like it raised at all under launch? Or does it stay level or even squat?
A well preped street im most cases is not as good as a non preped track If they just VHTed it and is hadn't gone away, that could be a major factor.
That's a good size verter, but it is still like a TH350 with a 35" tire and a 2.73 gear. Here is another comparison TH350 + 4.10 + 53" tire = your current gearing. The 4.10's are really going to wake that thing up!!! TQ Multiplication is going to be huge, 29% difference in gearing alone!! Can't wait to see your improvements. Just make sure you have a tire on it that will stick it because I think you are going to need it.
Old 12-21-2010, 10:09 PM   #109
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Dang you must have some good brakes to hold that rpm.
I can barely get mine to hold 3400 before it pushes through.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 12-22-2010, 07:40 PM   #110
dougminton
dougminton's Avatar
super 73 The back actually lifts about the same amount as the front. C 10 kid In my old race car with hydroboost brakes that convertor went 5200 on the foot brake. Its an 8 inch
1972 GMC SWB
454 oval ports
TH400
13.05 @ 104
Old 12-22-2010, 07:54 PM   #111
Super73
Super73's Avatar
You are definately inducing 100% + antisquat then.. Move control arm to the top hole and you will induce even more. When I had mine above 100% antisquat, traction on the unprepped airport track that I was racing was hard to come by as it would shock the tires too hard if I stood on it. Simply lowering the mounting point made a huge difference for the unprepped airstrip. The lower you go, the less hit, the higher you go the more hit. That place hooked as bad as a bad street.. Just food for thought.
Old 12-22-2010, 09:39 PM   #112
68 C-10 KID
Mean Green
The hydro boost is genius. I never thought of that for a race application only off road.
That would allow a motor that's boosting a huge advantage.
AKA MEAN GREEN.
Old 12-23-2010, 01:41 AM   #113
3r!c84
Badass
3r!c84's Avatar
14.1 !!!!! (:
-00 Saturn 5spd
1/4:13:90
Old 12-23-2010, 02:12 AM   #114
KQQL IT
At the body shop.
KQQL IT's Avatar
Originally Posted by 3r!c84 View Post
14.1 !!!!! (:
mph??
KQQL IT is online now   Reply With Quote
Old 12-23-2010, 02:34 AM   #115
3r!c84
Badass
3r!c84's Avatar
Originally Posted by KQQL IT View Post
mph??
r/t .129
60: 2.100
1/4 14.173
mph:94.84
pepd up 400/th350 3:42gear posi. 28tall tire.
first run. 92chevy1500. built 355 alum heads the works. built 700r4. pulled him to the end. we passed the line. he blew a headgakest
good ol' 400sbc
-00 Saturn 5spd
1/4:13:90
Old 12-23-2010, 02:49 AM   #116
KQQL IT
At the body shop.
KQQL IT's Avatar
My truck made the most gains in the 60 ft. Tight converter and 3.08s 2.20 60 fts.
10'' verter ,cal trac bars and a 325/50 Hoosier drag radial 1.671 60fts. started at 13.50s down to 12.19s
Old 12-23-2010, 02:54 AM   #117
3r!c84
Badass
3r!c84's Avatar
yup thats my next thing. vertter. and sticky tires
-00 Saturn 5spd
1/4:13:90
Old 12-23-2010, 09:36 AM   #118
69trk
69trk's Avatar
hey doug, that thing is going to move when you change those gears. Let me know next time you take it out, can't wait to see what it picks up.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 12-23-2010, 12:55 PM   #119
3r!c84
Badass
3r!c84's Avatar
-00 Saturn 5spd
1/4:13:90
Old 12-27-2010, 01:37 PM   #120
cooter472
cooter472's Avatar
I'm new here, my question is what kind of rear suspension set up are you guys running. I have a 71 lwb with a 472cid buick. Like to find a way to quit blowing the tires off.
thanks
cooter472 is offline   Reply With Quote
Old 12-30-2010, 06:16 PM   #121
3r!c84
Badass
3r!c84's Avatar
first run in the 13s!! 13.999 fastest run so far is a 13.98!
-00 Saturn 5spd
1/4:13:90
Old 01-20-2011, 10:27 PM   #122
bcdeutsch731
bcdeutsch731's Avatar
11.20@120mph.
1.59 60ft
you can watch the run here. The guy i lined up next to was a street racer so he didnt want the time up on the board.
http://www.youtube.com/watch?feature...&v=SCa8-X_wWKs
1969 C10, 2005 LLY Duramax, Wagler Competition built motor, Bullseye Power triple Turbo's, Rossler th400, Neal Chance Racing Converter, Danville Performance tunning.
8.3@168mph 1700+ HP
bcdeutsch731 is offline   Reply With Quote
Old 01-20-2011, 11:18 PM   #123
69trk
69trk's Avatar
need to post up some pictures and a build thread, bad a--
1.58- 60'
11.37- 1/4 @115.81
Old 03-18-2011, 11:28 PM   #124
drag80
1980 longbox
10.94@119mph
1.48 sixty foot
iron headed 468 with th400
33.5 x 15 slick
i will get some pics up later
drag80 is offline   Reply With Quote
Old 03-20-2011, 06:19 PM   #125
drag80
here's couple of pics
