Old 09-08-2013, 06:02 AM   #1
Nev68
Nev68's Avatar
SA 56 build
Thought I may as well put a build thread up for our 56 3100
We bought the 56 last year after a bit of a rest from our last build (68 Camaro)
Plans are for EFI, overdrive Auto trans, Air conditioning and get it sitting a bit lower
Before
After
We are converting the pickup to RH drive.
In South Australia if you want to do any mods to a US vehicle it has to be converted to RH drive. (Our Camaro is still LH drive so it has to be basically factory stock, right down to the radio!)
Here's a few shots of the dash conversion and Front end conversion (Thanks to Romano, Mick & Scott for your help)
Dash / interior before
Dash / interior now
Front end before
Front end now
Progress is a bit slow at the moment while I get some stuff finished around the house, but we'll get there.
Nev
Need a bigger garage so I can keep more cool cars alive
My build, a long way to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=595909
Nev68 is offline   Reply With Quote
Old 09-08-2013, 11:21 AM   #2
Kim57
Kim57's Avatar
Re: SA 56 build
Looks like a real clean truck to start with.
Keep the pics coming.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 09-08-2013, 11:47 AM   #3
_Ogre
_Ogre's Avatar
Re: SA 56 build
good to see you started a build thread.
very cool rh conversion, is that a rh drive dash?
it's black and doesn't look like a modded stock lh dash.
shop air compressor timer
Old 09-09-2013, 11:10 PM   #4
Nev68
Nev68's Avatar
Re: SA 56 build
Kim
Yep, it was a fairly tidy unit to start with, no show winner but more than good enough for waht we want.
Nev
Old 09-09-2013, 11:10 PM   #5
Nev68
Nev68's Avatar
Re: SA 56 build
double post
Nev
Old 09-09-2013, 11:12 PM   #6
Nev68
Nev68's Avatar
Re: SA 56 build
Thanks, hopefully some of the build will be intersting.
The dash is the original LH unit converted to RH by a very skilled friend of mine
Nev
Old 09-10-2013, 01:00 AM   #7
Coupeguy2001
Coupeguy2001's Avatar
Re: SA 56 build
nice progress on a really nice truck
Coupeguy2001 is offline   Reply With Quote
Old 09-30-2013, 06:46 AM   #8
Nev68
Nev68's Avatar
Re: SA 56 build
Started to fit the lowered rear springs but noticed a couple of the pins (that go through the spring eyes) had fractures in them.
Ordered some new ones, hopefully they get to me by the weekend.
Nev
Old 11-15-2013, 04:32 AM   #9
Nev68
Nev68's Avatar
Re: SA 56 build
Finally got around to fitting the lowered rear springs and fitting some hub caps.
Here's a before
....and after with caps
Nev
Old 11-15-2013, 11:31 AM   #10
Kim57
Kim57's Avatar
Re: SA 56 build
Looks good.
Kim
My build thread
Old 12-05-2013, 03:48 PM   #11
tpimuncie
tpimuncie's Avatar
Re: SA 56 build
Very Cool!
tpimuncie is offline   Reply With Quote
Old 12-06-2013, 11:09 PM   #12
Nev68
Nev68's Avatar
Re: SA 56 build
Thanks.
Got to get back into it.
Nev
Old 12-30-2013, 11:41 PM   #13
tpimuncie
tpimuncie's Avatar
Re: SA 56 build
WOW!! How hard was it to put speedo on pass side??
Old 12-31-2013, 01:10 AM   #14
Nev68
Nev68's Avatar
Re: SA 56 build
Well since I had the assistance of a skilled friend it was fairly easy
I can weld but I didn't trust myself on this one.
Actually took him a week or so with a lot of measuring before cutting started.
You can see that the angles of the dash are slightly different when comparing LH and RH sides.
Some filler panels were made up to make the gauge "pod" blend into the dash. (Is "blend" the right word?)
Some people make the dash out of fibreglass when converting from LH to RH, but I am lucky to have a skilled friend so my dash is all steel.
Nev
Old 12-31-2013, 02:13 PM   #15
tpimuncie
tpimuncie's Avatar
Re: SA 56 build
Ahh i see! Looks great man! I have a crazy idea been thinking about doing to my dash think gonna go thru with it Thanks!!
Old 03-29-2014, 04:58 PM   #16
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: SA 56 build
Any updates on this cool truck?
ChuckDriver is offline   Reply With Quote
Old 03-29-2014, 11:09 PM   #17
Nev68
Nev68's Avatar
Re: SA 56 build
Not too much happening due to some home renovation work.
Just started setting the fuel tank up and installing Vintage Air AC.
Nev
Old 03-30-2014, 03:19 PM   #18
_Ogre
_Ogre's Avatar
Re: SA 56 build
live gets in the way
was hoping to see progress on this build, my truk only took 8 yrs to finish
your still ahead of my game
Old 03-30-2014, 10:07 PM   #19
Nev68
Nev68's Avatar
Re: SA 56 build
I know what you mean, unfortunately(?) there's more to life than playing with cars.
I would like to see if I can get it going this year so me, the bride, and dogs can go for a spin when the warm weather returns.
Nev
Old 06-14-2014, 11:31 PM   #20
Nev68
Nev68's Avatar
Re: SA 56 build
Been a while since I've updated but home renovations have had priority and unfortunately I've just lost my job (33 years with the same company!) so my main priority now is to get another job
Anyway still hasn't stopped me getting wood
Just sanding for a nice finish
Putting on some stain
Just fitting the outside boards for the moment to support the bed on the chassis while I run new fuel lines and add a filler pipe
I've gone for a satin finsh on the timber instead of high gloss as there will be the odd bale of hay and other bits and pieces thrown in the back (occasionally)
Nev
Old 06-15-2014, 10:59 AM   #21
Kim57
Kim57's Avatar
Re: SA 56 build
Bed wood looks real nice.
Good luck on the job search.
Kim
My build thread
Old 06-15-2014, 11:03 PM   #22
Nev68
Nev68's Avatar
Re: SA 56 build
Kim
Thanks Kim
Nev
Old 06-15-2014, 11:16 PM   #23
Purcell69
Re: SA 56 build
That shade of gray is gorgeous and goes well with the finish you have chosen for the bed. I had been thinking of something in a darker shade of gray for my build, but decided since mine will be NAPCO-esque when done, I would stick with the original turquoise and white instead.
Keep up the good work!
-Joe
Purcell69 is offline   Reply With Quote
Old 06-16-2014, 05:21 AM   #24
Nev68
Nev68's Avatar
Re: SA 56 build
-Joe
Thanks Joe, do have a build thread?
Nev
Old 06-16-2014, 09:11 AM   #25
ChuckDriver
Re: SA 56 build
Nice color!
