Old 12-01-2018, 03:54 PM   #1
Rick Bollinger
700r4 lockup question
Swapping out 700r4 this winter and gathering parts. All that is left is the lockup kit. They all have there strong points. I am leaning towards the B&M kit with the speed control. But I don't believe there is a unlock for emergency braking or any kind of a "kickdown" feature to downshift at speeds. But I do like the ability to set the speed at which it will lock up. Can a brake switch and vacuum switch be hooked up to this unit to add these features?
Rick
Rick Bollinger is offline   Reply With Quote
Old 12-01-2018, 05:56 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 700r4 lockup question
Here is what you will install with the kit - https://www.jalopyjournal.com/forum/...#post-11787625
Old 12-01-2018, 06:17 PM   #3
jhrusk
I have the b&m and highly recommend it. It is wired thru brake switch so when you apply brakes it will unlock it.
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 12-02-2018, 12:34 AM   #4
Rick Bollinger
Thanks That is what I needed to hear. I am ready to pull the trigger on one. I have a bunch of money in this project and the lockup kit and the bowtie tv cable for the edelbrock carb are the last two items I need. Doing this swap and disc brake conversion this winter and paint next fall.
Old 12-02-2018, 01:44 PM   #5
kaycee
kaycee's Avatar
Why not get everything from Bowtie
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 12-02-2018, 04:23 PM   #6
Rick Bollinger
I do not have a problem with that at all. It would be easier actually. And does anyone know if the price of the TV cable includes the phone conversations about the trans pressures? Or is that extra?
Old 12-02-2018, 04:57 PM   #7
kaycee
kaycee's Avatar
I put mine on a few years ago and they were pretty good at helping, I just looked at them was thinking of 1 for my Impala ,holy Sh#$ they proud of them setups now I paid like $140 .
2005 FXDWG stage3
63 IMPALA 327
Old 12-10-2018, 06:42 PM   #8
First c10
First c10's Avatar
I used the Bowtie OD Kit attached. I did add a switch to lock up anytime like a tow/Haul button
700R4 Lockup kit
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 12-10-2018, 10:19 PM   #9
Rick Bollinger
I pulled the trigger on the tv kit and the B&M speed controlled lockup kits. I should now have everything needed for this swap. But I am into it about 1K more than I thought it would be. I sure hope it works out the way I hope. Had I of known I would have this much in it I would have considered the gear venders with my th400.
