03-28-2011, 04:56 PM | #1 |
59 6 bolt IFS?
Does anyone make a 6 bolt IFS for 59 apache 3100? I have looked at plenty of websites, and they all seem to be a 5 bolt pattern.
The wheels I have at present are 6 bolt so would like to stick with that if possible. OR would I be better off going to 5 bolt? Are the wheel choices better? BR |
03-28-2011, 05:07 PM | #2 |
Re: 59 6 bolt IFS?
TCI has a 6 bolt upgrade
55 2nd series Chevy Pickup 2019 Chevy Equinox(Daily driver) 2011 Chevy Malibu (Wife's car) MSRA Member I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose. -George Carlin |
03-28-2011, 05:17 PM | #3 |
Re: 59 6 bolt IFS?
Scotts Hotrods has a 6 lug upgrade as well and we have great forum deals for all of the great people on this great site.
Justin |
03-30-2011, 09:29 PM | #4 |
Re: 59 6 bolt IFS?
there is a place in Bedford, PA I think it's www.martzchassis.com
03-31-2011, 03:51 AM | #5 | |
Re: 59 6 bolt IFS?
From the looks of it, seems 5 bolt is the way to go, certainly more options there, and at a keener price than the 6 bolt, also sounds like a valid reason for new wheels! |
04-02-2011, 06:10 PM | #6 |
Re: 59 6 bolt IFS?
If you Camaro clip your truck you will struggle to find 6 lug rotors, I chose to keep mine because I wanted to run steelies & I think 6 lug have a little cool factor, but thats just my opinion. This is how I did mine.http://http://67-72chevytrucks.com/vboard/showthread.php?t=437842
04-02-2011, 08:11 PM | #7 |
Re: 59 6 bolt IFS?
You might also consider the IFS from a 63-70 C10. It will bolt right up to your frame with no modifications and the best part is that you can pick one up cheap! I used on from a 79 on my 3600 but had to have it narrowed to make it fit but you wont have that problem siince you have a wider frame.
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. Last edited by mobileortho; 04-02-2011 at 08:22 PM. |
04-02-2011, 10:27 PM | #8 |
Re: 59 6 bolt IFS?
do you have anymore pics of that swap you did? It actually bolted on? No welding or anything?
Chops |
04-02-2011, 11:45 PM | #9 | |
Re: 59 6 bolt IFS?
[quote=mobileortho1;4596057]You might also consider the IFS from a 63-70 C10. It will bolt right up to your frame with no modifications and the best part is that you can pick one up cheap! I used on from a 79 on my 3600 but had to have it narrowed to make it fit but you wont have that problem siince you have a wider frame.
Also Six lug is the way to go for wheels all the 02 and newer 2wd trucks are 6 lug I could be wrong about the year they started doing 6 lug on the 2wd for newer body style but a buddy of mine owns a wheel shop and never has a problem getting six lugs wheels almost any style
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project) It's your ride build it the way you want !!!!!!!!!! |
04-03-2011, 06:03 AM | #10 |
Re: 59 6 bolt IFS?
5 or 6?? decisions.
04-03-2011, 03:44 PM | #11 |
Re: 59 6 bolt IFS?
Well OK Ill go out and measure my 69 C-10 with the 74 front and get back to ya. I would measure the 58 but we got a coupla inches of snow and still snow/rain .OK ran out and measured I got 28" outside frame/outside frame this is allso confirmed through the service man.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 Last edited by kaycee; 04-03-2011 at 03:57 PM. |
04-03-2011, 05:57 PM | #12 | |
Re: 59 6 bolt IFS?
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
04-03-2011, 06:17 PM | #13 |
Re: 59 6 bolt IFS?
The six lugs were used through 70 & the five lug I know for sure through 87 but beyond that, I'm not sure but they are all bolt on.
04-03-2011, 07:01 PM | #14 |
Re: 59 6 bolt IFS?
I envy you guys having a larger reservoir of options than we have here, costs are also in your favour.
All good info, keep it coming. |
04-03-2011, 11:39 PM | #15 |
Re: 59 6 bolt IFS?
I been thinking of doing this swap myself,The AD frames are narrower than the TF trucks correct?If I remember correctly the TF frames are 34" wide
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
04-04-2011, 08:07 PM | #16 |
Re: 59 6 bolt IFS?
That's correct. It's a direct bolt on for the TF trucks.
04-06-2011, 09:37 PM | #17 |
Re: 59 6 bolt IFS?
OK how did you do it I measure my front end of 69 with front end from a 74 it measures 28 1/2" the 58 is 34".Not trying to be a di@# but just trying to find the answer
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 Last edited by kaycee; 04-06-2011 at 09:38 PM. |
04-07-2011, 12:25 PM | #18 |
Re: 59 6 bolt IFS?
You are correct. For my AD it was a bolt on affair but had been told by others that they did this swap on their TF. Did some research and came across this article detailing the steps to do the install the IFS on a TF.
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. Last edited by mobileortho; 04-08-2011 at 12:16 PM. |
