04-13-2020, 12:53 AM | #1 |
Texas Big Wig
Spray-Bombs 67 C-30
Hey gang, I’m still around and I still love these trucks
Just picked up this C-30 today, not really sure what I’m gonna do with it, but it’s cool and needed a home First on the list is getting it running, was really hoping it would have a 292, but it has a small block (gotta run numbers and see what it is) It’s missing the fuel pump, dizzy cap, and alt Gonna see if I can rummage up some used parts tomorrow to try and get it popped off before I go buying anything Mmmmm C-30 Last edited by Spray-Bomb; 04-16-2020 at 08:29 PM. |
04-13-2020, 02:03 AM | #2 |
Re: I’m Baaaaack / 67 C-30
One tons rule.
That one sure has character!
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Project "Little Sister" (70 c10 blue original paint refresh) Project "C10 Fever" (68 factory black 396 swb) Project "Blue Bomb" (70 c30 blue original paint refresh) Project "Vitamin C" (71 c10 orange original paint refresh) |
04-13-2020, 06:25 AM | #3 |
I like it.
Glad you gave it a good home. .
04-15-2020, 09:52 AM | #4 |
I'm just glad to be here!
I saw that one on FB Market place or Craigslist just the other day, glad to see it found a home.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
04-15-2020, 06:14 PM | #5 |
04-15-2020, 10:40 PM | #6 |
Texas Big Wig
Well, I got it running
Started by installing a cap and rotor, a few plug wires, battery cables, and filling the bowl with fuel Once running I put a new fuel pump and water pump on, and an alternator Then I put a fuel tank and seat in it, went to start it to prime the fuel line and it lost spark So I wound up swapping the dizzy after changing the coil and ICM and couldn’t get the screw for the condenser out because the old dizzy had been full of rat crap Still no juice brakes, but the E-brake works for now Last edited by Spray-Bomb; 04-16-2020 at 08:31 PM. |
04-16-2020, 08:46 PM | #7 |
Texas Big Wig
Spray-Bombs 67 C-30
Well, dad and I went for a test drive yesterday
Forgot to take a pic of the seat installed tho Next on the list is getting the brakes working and rebuild the carb https://youtu.be/ZCqTqWZLxd4 |
04-17-2020, 12:33 PM | #8 |
FYI, when you work on the carb, it might be good to drop the float in a can of gas, see if it floats. IF you buy a new float, beware the newer made brass floats don't do too well. Plastic is good...
04-17-2020, 02:23 PM | #9 |
Welcome back!
What do you know about those wheels? I like the look. Wil
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
04-17-2020, 03:13 PM | #10 | |
Re: Spray-Bombs 67 C-30
If you need a name for it "Mater" will suit it perfect ;-)
------------------------------------------------------ ZUBZ - C10 "GUS" - JOHANNESBURG, South Africa My 1970 C10 Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542560 |
04-17-2020, 03:21 PM | #11 |
Texas Big Wig
68Gold/White, good to know about the new brass floats, I’ve still gotta get the part number off the carb so I can find a kit.
OldCreek, I really don’t know much about them. I’m pretty sure they’re older than the truck, but my 69 C-30 has them also... They’re a split ring wheel, 18” ZUBZ, thanks |
04-22-2020, 06:29 AM | #12 |
I have a radical idea!
Love it! I have those wheels on my dump truck and I’ve thought they look good.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
