Old 01-14-2018, 05:12 PM   #1
twp1
1972 Blazer Rear Disc Brakes
Has anyone removed the rear drum brakes and installed disc brakes? What kit did you use and any other info will help! Would like to install disc on the back of mine.
twp1 is offline   Reply With Quote
Old 01-14-2018, 05:34 PM   #2
hemi43
hemi43's Avatar
Re: 1972 Blazer Rear Disc Brakes
Why?
hemi43 is offline   Reply With Quote
Old 01-14-2018, 05:39 PM   #3
A1971Blazer
A1971Blazer's Avatar
There may be a few more but....here's a few considerations:
Unless you're going with bigger tires and more mods...spend the money on something else....the front disc brakes do 80% of the stopping......stock or near stock...drums are fine...but:
If you use the stock axle with a kit, You will have to address e-brake if you want one...... if you swap in a later model with the disc and e-brake already on it....it may not clear the factory wheels...
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 01-14-2018, 05:39 PM   #4
twp1
Why not?
Old 01-14-2018, 05:40 PM   #5
twp1
thanks for the info.
Old 01-14-2018, 05:48 PM   #6
twp1
LMC has a kit that will fit 15" wheels and has the e-brake cables! Has anyone used it?
Old 01-14-2018, 09:10 PM   #7
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
I used a kit from Wilwood, and they clear my 10x15” torque Thrusts, and they come with an emergency brake.
Tom Vogel is offline   Reply With Quote
Old 01-14-2018, 09:28 PM   #8
hemi43
hemi43's Avatar
Why not?
Rear drum brakes are more than sufficient, and will give you less problems than rear disc. The biggest issue with rear disc is the parking brake.
The only advantage I could see is that it might look better if you have aftermarket rims.
Old 01-17-2018, 10:11 PM   #9
scf100
scf100's Avatar
I have aftermarket rims so I’m interested in this thread........
1970 2WD Blazer 454
1972 C-10 Extended Cab 350 SBC
scf100 is offline   Reply With Quote
Old 01-17-2018, 10:26 PM   #10
twp1
GMC-YA68 installed rear disc and i would like him to post some pic's! And if anyone else has installed rear disc please let us know what kind and the pic's of process!!
Old 01-17-2018, 10:27 PM   #11
twp1
Tom,
can you post some pic's of yours being installed or installed?
Old 01-17-2018, 11:32 PM   #12
MikeCofield
Captain fab makes a nice set up
MikeCofield is offline   Reply With Quote
Old 01-18-2018, 01:13 AM   #13
GMC-YA68
GMC-YA68's Avatar
I will pull a wheel off on mine this weekend. They worked out perfectly. I used an adjustable brake proportioning valve from Hydratech and Captain Fabs brackets, along with the Toronado calipers and it's been working flawlessly. Capt sends all the info on which rotors (i forget what I used, but he can chime in, or I will go find me receipt) and calipers to use in his invoice or email. Easy Peasy....
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 01-18-2018, 09:24 PM   #14
elkniks
elkniks's Avatar
I used CPP Big Brake Kit and they work great (even with 11 inches of vacuum)! The kit comes very complete with parking brake cables and hoses. I would buy again. The only problem I found was the fit of their rotors on the axles, I had to make 0.015" shims to center rotor on axle. I also have a set of Captain Fab brackets unused if anyone is interested.
elkniks is offline   Reply With Quote
Old 01-19-2018, 12:51 AM   #15
stangtjk
At some point in my blazer's life someone swapped in an old 14 bolt. I was redoing the whole brake system and decided I wanted rear discs but also wanted to have the drum in hat parking brake... So i replaced the axle flanges for the drum brakes with ones I had machined to mount late model discs on. I used the brackets, calipers and rotors from a lated model dually. Had to turn down the hubs to get the rotors to slide on. Probably would have been easier just to swap axles.
stangtjk is offline   Reply With Quote
Old 01-19-2018, 04:27 AM   #16
mcmlxix
Collector of Projects
mcmlxix's Avatar
Grab a late model Tahoe/Yukon/Sierra/Silverado 6 lug disc brake rear off craigslist. Remove all brackets and weld on some DIY4X spring perches. Parts available at any auto parts store... price range $250-$450
Rich
1972 K5 Blazer CST Click HERE
Old 01-19-2018, 12:55 PM   #17
Hard Parker
Hard Parker's Avatar
If you want to part it together yourself you can use the rear calipers off a 77 Eldorado, they have a built in parking brake.
Hard Parker is offline   Reply With Quote
Old 01-19-2018, 07:46 PM   #18
mcmlxix
mcmlxix's Avatar
the Eldorado calipers are small and only use a lever to apply pressure. the Tahoe calipers are twin piston and use a drum in hat emergency brake... that would be my preference.
Rich
Old 01-19-2018, 11:04 PM   #19
simicrintz
Do not back up with the parking brake on if you do the drum in hat axle (don't ask me how I know!).
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 01-30-2018, 12:48 PM   #20
Hard Parker
What master cylinder and booster are you running with that set up?
Old 02-01-2018, 03:14 AM   #21
mcmlxix
mcmlxix's Avatar
So I have a unique setup. I have large twin piston calipers front and rear. I also upgraded to hydro-boost from the 2005 GMC 2500 that my rear axle came out of... I used a wildwood adjustable proportioning valve to be able to adjust as needed...
There is a lot of good information to read over here....
http://www.pirate4x4.com/tech/billavista/Brakes/
Rich
Old 02-01-2018, 02:27 PM   #22
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
I havent pulled the trigger on these yet but this is the option i was thinking
www.littleshopmfg.com
I talked to him and he said he can def get a setup that will work...
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 02-03-2018, 08:38 PM   #23
twp1
That kit looks like it would be worth trying!!!!!
Old 02-04-2018, 04:38 PM   #24
grillzy
https://www.littleshopmfg.com/gm-62-...-brakes-6-lug/
direct link. Price is right
grillzy is offline   Reply With Quote
Old 02-12-2018, 09:00 AM   #25
twp1
So I bought the Little Shop disc brake set up and the install went smooth and quick! Once I get the blazer back together I will let you know how they work!!
