Old 07-15-2018, 10:04 AM   #1
BdBoTie
Serpentine set up for early sbc
Putting sbc into an s10 with 1948 Chevy 5 window body. Wanting to put a serpentine belt set up in to save space. I know there are new fancy set ups for this but don’t want to spend 1k on them! Doing this project with my 12 year old son and trying to show him how to be resourceful in our build. Does anyone know what years of trucks/Yukon/Tahoe’s I could source the brackets, tensioner water pump etc from? Looking to add the complete set up if possible. Any advice or input is appreciated.
First post but have been a reader of the forum and helped me get the project started. Now is a ton of fun with my son. We have a rule....Dad only works on the truck when we both are in the shop so we can learn together.
BdBoTie is offline   Reply With Quote
Old 07-15-2018, 10:15 AM   #2
notsolo
notsolo's Avatar
Re: Serpentine set up for early sbc
Welcome, I used a 95 5.7...AKA 350.. Serpintine belt on my blazer, Your heads will need the bolt holes for the brackets...283 -327..did not have these holes. Find a donor and get all the brackets bolts etc, water pump runs reverse on a serpentine belt set up....Engine in photo is jegs...350.
notsolo is offline   Reply With Quote
Old 07-15-2018, 07:04 PM   #3
BdBoTie
Thank you for the info. Good news is I have a set of heads from another project that have accessory holes. I just need to find a vehicle. Thought I had one to use as a reference but when I got there it was missing everything so obviously struck out. Looks like I need to do some searching. Thanks again
Old 07-15-2018, 07:05 PM   #4
BdBoTie
Old 07-15-2018, 09:13 PM   #5
87Skier
87Skier's Avatar
I've got a complete serpentine setup that came off a 1997 Suburban. I ran it on my old engine.
It is a reverse rotation water pump/fan, uses the standard power steering pump, CS130D alternator (passenger side) and HT6 air conditioning compressor (driver side). It could be modified for a cleaner look by using a grooved pulley in place of the AC compressor and cutting the bracket.
I have the balancer and crank pulley for it too.
I don't want any money for it, just pay shipping or pick it up and it's yours.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 07-15-2018, 11:55 PM   #6
Captainfab
60-66 Nut
With that installation, isn't it better to run a short water pump, or is there room for the long water pump?
Old 07-17-2018, 11:07 AM   #7
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Need the long water pump to line up all of the pulleys, if using a GM serp. setup. Also I don't think they make a reverse rotation short pump.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-17-2018, 11:09 PM   #8
Captainfab
60-66 Nut
I believe the Corvette's ran a reverse rotation short pump with a serp drive for a few years
Old 07-18-2018, 01:00 PM   #9
chevy_mike
chevy_mike's Avatar
Possible but I can't ever recall anyone mentioning this over the years but hey, GM had done weirder stuff over the years.
Old 07-19-2018, 06:16 PM   #10
sixty4bigwindow
sixty4bigwindow's Avatar
I love to hear that you and the little one are building a project together! I wish Dad had waited and done some of the important stuff on Rocket with me. Now that he's gone, it's hard to figure out what I'm working with on some of the internals lol.. Good luck to you and the little man.
Been a crazy 2018. Moved twice, back HOME in Oregon. Now to put everything back together, including the truck...
My build thread for "Rocket" - http://67-72chevytrucks.com/vboard/s...d.php?t=753023
sixty4bigwindow is offline   Reply With Quote
Old 07-21-2018, 06:37 PM   #11
BdBoTie
87 skier....thank you for the offer but I found a 96 Tahoe and was able to get the brackets. They need some work to clean them up but I’m hoping they will work.
Notsolo...thanks for the picture and hope these brackets will clean up as nice as yours. The location of the Alternator and AC are reversed from yours but think I can get them to work.
Need to get a the engine back from being machined and will then start to fit these up. We have plenty of body mounting / fitup to get through yet and body work before we completely install but am trying to keep ahead by having parts when needed.
Thanks for the advice and help
Old 07-22-2018, 03:12 PM   #12
notsolo
notsolo's Avatar
My set up was cleaned, I painted it silver. Some foamy engine bright and stainless steel wool, or other cleaning products get it clean enough to paint. Opposite side brackets should work fine, good luck, post some photos as you go.
