11-18-2019, 10:49 AM | #1 |
Active Member
restoring old light lens gaskets
Anyone tried to soften up the old gaskets, which are far superior to thin re-pop gaskets?
11-18-2019, 11:08 AM | #2 |
Old member
Re: restoring old light lens gaskets
I haven't ever restored one but would be interested in if some one has.
I use Dow Corning 111 on them when I take them a part and put back together. Seems to work pretty good on keeping water out of them. Just idea: I haven't tried this though, You might try going to a hardware store and buying some rope that would fit in the gasket area and coat it with the DC 111 and it would soak up the water. I know rope type material was used years ago for gasket.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-18-2019, 03:49 PM | #3 |
Another idea is to go to a fabric store and look for the foam piping they use when they make trim, like what is used to make fender welt etc. They have it in different diameters and usually sell it by the foot. Jo- Ann Fabrics is a store in my area that handles the piping. Or you might try an upholstery shop.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
11-18-2019, 06:34 PM | #4 |
I have soaked window gaskets in dishwashing soap for a week with good results. It may work for those. WD-40 is good for vinyl's it may work too.
For a replacement I would try some PTFE Sealant cord. https://www.lowes.com/pd/danco-ptfe-...E&gclsrc=aw.ds
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-18-2019, 07:42 PM | #5 |
The Older Generation
Replace it with Rope Caulk: 3/16" https://www.acehardware.com/departme...E&gclsrc=aw.ds 1/4": https://www.menards.com/main/hardwar...2582940251.htm LockDoc
11-18-2019, 08:15 PM | #6 | |
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
11-18-2019, 08:44 PM | #7 | |
Moderator
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
11-18-2019, 09:23 PM | #8 |
I purchases Soft Seal 9342. Tail light lens gaskets and they were as thick as the original. Got mine from Jegs who say they are out of stock. But the Soft Seal sight said they have 2. SS-9342.
Smitty '71 Short Fleetside Spring Valley, Ca. |
