03-02-2010, 05:03 PM | #1 |
Dash Speakers
What can ya'll using for dash speakers? I saw a post somewhere where a 4 inch will fit in the corners where a 3 1/2 in is from the factory but can't seem to locate it now. Are any of you running a 4x10 in the center or did you fab it up to put something else in there? Not looking for awesome sound, but the 28 year old factory speakers are sounding a little fried so figured I'd replace them when I take the dash pad off to install a cover.
03-02-2010, 05:59 PM | #2 | |
Re: Dash Speakers
Mike
The Fleet........ 68' Camaro - 1st car (restored & still have it) 09' VW Tiguan (Wife's Daily Driver) 14' VW Passat SE TSI (my personal) 14' Ford Edge Sport (Daily Work Vehicle) 73' SWB Stepside - 77K org. miles 74' LWB 454/TH400 - drive train transplant for my (Sold) 98' SWB C1500 W/T - shop truck (Sold) 90' GMC Sierra SLE short step - aka " Jezabelle " (Sold) |
03-02-2010, 07:45 PM | #3 |
Re: Dash Speakers
Here is my setup, I have 4" mb quartz all the way across. When I ordered the speakers they came with an mount for 2-4" to fit in the middle. The 4" does fit in the side holes but does not fit flush like stock but you still have room under the dash pad where they do not hit. you could make them fit flush but will have to cut the dash, I opted not to. This is not the best picture but you can see where mine are, I cut holes and installed the covers b/c the factory dash is covered with leather. I don't have a pic of the speakers with the cover off but it will be coming off in a few days and can get one then if you would like.
03-02-2010, 10:58 PM | #4 |
Re: Dash Speakers
This is what i did. they fit fine, however like ecu pirate said my dash does slightly bulge on the passenger side. That may be partly because it is a reproduction
http://67-72chevytrucks.com/vboard/s...d.php?t=344303 |
03-02-2010, 11:03 PM | #5 |
Re: Dash Speakers
For my '88 I just used 3.5's in the factory brackets. It's OK, but I would like to ditch them in favor of something larger in the kick panels. For my '77, I mounted dual 4's in the center opening. The frames were large enough that I could bolt the two together and then mount them to the dash. I like that setup.
03-02-2010, 11:43 PM | #6 |
Re: Dash Speakers
I'm going to get a dash overlay, and the factory speaker grill areas in the dash pad are absolutely trashed (cracked, split, disintegrating). I'll probably put 4" in there and wallow out the dash pad to get it to sit down like it should. Anyone see a problem doing that?
03-03-2010, 12:43 AM | #7 |
Squarebody Aficionado
Re: Dash Speakers
i did 4" kickers all the way across i had to make a bracket out of some abs for the middle but the sides fit fine. I did have the glass out when i did it though. i think it will be really difficult to do it with a windshield in the way
03-03-2010, 01:26 AM | #8 |
GM Addicted
Re: Dash Speakers
i have a kenwood 4x10 under my dash thing sounds good man. If you want to go with a stock look. Its a 3 way 400 watt i believe if i remember right.
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
03-03-2010, 01:59 AM | #9 |
Re: Dash Speakers
03-03-2010, 11:46 AM | #10 |
Re: Dash Speakers
what i did to mine is flip the bracket upside and instead of puting them on top of the dash like factory i put them under the dash. it's hard to explain but if you can picture it in your head its not hard to do. it only took about 45 min to do. what it will do it will give you about 1/2 to 3/4 inches more clearance.
also i used the factory 3 1/2" speaker. Last edited by jklonowski; 03-03-2010 at 11:47 AM. |
03-03-2010, 03:51 PM | #11 |
18 Till I Die
Re: Dash Speakers
If anyone has any pics of 4" vs 3.5" front corner speakers installed that would be great. Im just about to buy front ones cause mine are toast. I would like to go 4" but not if I Have to mod alot or it makes the dash sit higher?
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
03-03-2010, 05:08 PM | #12 | |
Re: Dash Speakers
yeah, I'm in the same boat. I would prefer to put a 4" in there, but I want it to look ok without having to do a bunch of modding on the dash. |
03-04-2010, 10:28 PM | #13 |
18 Till I Die
Re: Dash Speakers
I went to the local Pick-n-Pull after work today and scores a locking dipstick, heater control, sportbumper licence plate lamp, and 2 front speakers with brackets($22 Bucks). It was nice the dash was ripped off. Im going to see how the 3.5" compare to the 4" speakers for mounting. Under the bracket I noticed there is lots of room so opening the holes should not be an issue...
03-05-2010, 12:24 PM | #14 | |
Re: Dash Speakers
03-05-2010, 02:46 PM | #15 |
Re: Dash Speakers
Try DapperDan. He mounted 4" speakers in the factory location. It looked pretty clean. I would love to see some pics with those factory mounts flipped upside down and installed under the dash. This may solve my whole problem so I can use my Polk db351's that are just waiting..........................
06-20-2014, 07:32 PM | #16 |
Re: Dash Speakers
A bump only because I've just gone down this road, and wanted to show what I came up with for others who are searching for the same thing:
Ditched the original 4x10 single speaker for a pair of old JBL 5-1/4" two-ways I shelved from a car I cut up eight years ago. Adapter made from a dollar store cutting board.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
06-20-2014, 07:41 PM | #17 |
Re: Dash Speakers
I think you can also add spacers (nuts?) to the mounting areas to bring the speakers down a little and clear the dash pad.
I have 3.5" speakers in the kick panels - but just in a circular hole cut in the metal kick panel. The magnets are a close fit but they work fine. I made triangular wood speaker boxes for the rear speakers in the cab corners. Overall, my setup is OK, but I think if you can do the two speakers in the center that would be a nice stock touch. Being able to control the fade from front to rear speakers is nice, as well as left to right balance, especially on a long drive. |
06-20-2014, 08:40 PM | #18 |
78K & 79C Jimmys
Re: Dash Speakers
i used 2 newer stock 4X6,seems great compared to 1 speaker mono lol
i kept the 4X10s for "ashtray replacement" in the Jimmy
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
06-20-2014, 08:43 PM | #19 |
78K & 79C Jimmys
Re: Dash Speakers
used my 88 burb covers and they appear stock
06-20-2014, 10:58 PM | #20 |
Second Chance Program
Re: Dash Speakers
I did 4" in the outers and 3.5's in the inner. As stated, the 4" speakers i got were a pain to fit. I had to ditch the bracket on the driver side and cut the dash to get the speaker to drop in. The centers clear the dash pad just fine how they are in the picture. THe passenger side 4" hits the A/C duct but its manageable.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
06-22-2014, 03:23 PM | #21 |
Don't Crush em Restore em
Re: Dash Speakers
I bought this one from LMC, and sounds great, also bought some 4x10 3 ways for behind the seat from ebay for $30 with shipping.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=129 http://www.ebay.com/itm/2-NEW-BOSS-C...item51b60f0d5a
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually |
03-08-2019, 02:09 AM | #22 | |
Re: Dash Speakers
"Sweet Pea" 1975 Cheyenne 20 http://67-72chevytrucks.com/vboard/s...00#post8477900 "Bourbon" 1975 Suburban ScottsdaleSOLD https://67-72chevytrucks.com/vboard/...49#post8769049 ”Otis” 1970 C10 SWB -SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=762766 ”Chebby” 1962 Impala LS/TKO-500 http://www.pro-touring.com/threads/1...2-Impala-Build |
04-12-2019, 11:40 AM | #23 |
Re: Dash Speakers
How is everyone wiring 6 speakers (4 in the dash and two in the rear) with a standard 4 speaker wiring setup?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
04-12-2019, 02:58 PM | #24 |
Re: Dash Speakers
In my Suburban, the factory head was replaced with a unit that had four standard speaker outputs (which I ran two to the 3 1/2 in the dash, then two to feed two powered subwoofers under the bench seat). The new head also had four RCA out puts that was used on a 4 channel amp that was used to power 6.5 in the kick-panels and the 4x10's in the rear.
04-15-2019, 01:51 PM | #25 | |
Re: Dash Speakers
I figure eventually I'll add an amp, run them something like rideair said he's done. |
