Old 12-10-2016, 07:37 AM   #1
lt1wrangler
1988 Crew Cab shortbed overhaul
Hey guys, Im new to the board but lurked on here for years. I have wanted a crew cab for years and just never found the right truck to restore. I pulled the trigger a few weeks ago and bout this truck. Its a 1988 7.4L, turbo 400 truck with dana 60's. The structure of the truck is very solid and all the cab and bed mounts a re in really good shape. One rocker has some rust and it needs a little mechanical work but runs out ok. I think the truck was restored once before and someone put a later front clip on it. I gave $6200(hope that was a decent deal). I drove it back 4 hrs from middle ohio.
The plan is to short bed, 4l80e, and do a frame off in some fashion. I don't know the in's and out's of the square bodies so feel free to correct me if I post dumb info, its just because I don't know the difference. I have already asked carboncrew a ton of questions and I really appreciate his helpfulness.
lt1wrangler is offline   Reply With Quote
Old 12-10-2016, 07:44 AM   #2
lt1wrangler
Re: 1988 Crew Cab shortbed overhaul
I did add some 35's and wheels I had on my quigley just to give it a different look for short term. These are not permanent. The bed, front fenders, and front bumper are all for sale also.
I drove a couple hours away on thursday and bought a clean short bed, four power doors with clean panels and a wiring harness from a suburban since mine has aftermarket power windows. I also picked up a late model column and instrument cluster.
Old 12-10-2016, 07:51 PM   #3
74project
nice find and a good deal IMO..
74project is offline   Reply With Quote
Old 12-12-2016, 10:30 AM   #4
carboncrew
carboncrew's Avatar
Ha!...no problem man, glad I can help a little. Nice truck. Good luck on the project!
________________
My very own build
My tailgating ambulance
carboncrew is offline   Reply With Quote
Old 12-12-2016, 02:05 PM   #5
daddyjeep
daddyjeep's Avatar
Looks like a real nice truck to start out with. Good call on selling off that front bumper.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 12-12-2016, 08:53 PM   #6
lt1wrangler
We pulled the bed, bumpers, front fenders, and all 4 doors today. Someone glued the carpet padding down so thats taking some time.
Old 12-12-2016, 08:55 PM   #7
lt1wrangler
The rear springs already had an Off-road Design shackle flip kit. The truck sits a little to high for me, I may contact deavers for springs. I'm trying to have frame at sand blasting by end of week
Old 12-12-2016, 10:52 PM   #8
MTCK
MTCK's Avatar
Sweet truck and seems like a fair deal to me. Probably has a 14 bolt rear. I'll be watching.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 12-13-2016, 07:12 AM   #9
lt1wrangler
Question-Whats the fuel injected 454 worth? Motor runs good, has new distributor and only has 120K miles. Im going to swap to LS 6.0L
Old 12-13-2016, 11:48 AM   #10
MTCK
MTCK's Avatar
Not trying to be a smart ass but whatever someone will give you for it. TBI peanut port head isn't really a motor people seek out for swaps. Your market is probably someone replacing a like-kind motor. Around here I would guess $800-1200.
-Marcus
Project Plow Truck
Old 12-13-2016, 06:13 PM   #11
lt1wrangler
Yep, it's getting serious!
Old 12-13-2016, 06:23 PM   #12
NastyBuzzard
NastyBuzzard's Avatar
Its an eerie feeling when you make that first cut!!
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 12-13-2016, 07:19 PM   #13
396ci
396ci's Avatar
is this type of cut stronger when completed? i know some that have 'step cut' the frame but also heard that a horizontal weld on a frame isnt desirable. just curious, cool build. i have a lowered ccsb but mine was already cut down when i got it. good luck with the project!
Brian
XNGH ECV Chapter 58
1972 Jimmy / Blazer Project 2wd
1974 Chevy Crew Cab Shorty
396ci is offline   Reply With Quote
Old 12-13-2016, 07:29 PM   #14
HunterRotten
HunterRotten's Avatar
I'm interested in that 454, my dad and I are in Richmond quite a bit. I'm not looking for a high dollar motor though.
HunterRotten is offline   Reply With Quote
Old 12-13-2016, 10:54 PM   #15
daddyjeep
daddyjeep's Avatar
For a minute I thought you took a picture from my build. My frame had the same mark in the same white crayon a couple months ago. I did a ton of reading on different forums and articles about the best cut and from what I gathered the 45 is the way to go.
04 1500 crew cab
Old 12-13-2016, 11:52 PM   #16
Jaysonb
Jaysonb's Avatar
Looks like a nice solid truck!
Jaysonb is offline   Reply With Quote
Old 12-14-2016, 06:32 AM   #17
lt1wrangler
Haha, I did read your build thread and we agreed at my shop that the 45 was the way to go also. Once you weld and fish plate it on the inside , its solid and Im comfortable with the fab work.
Just for guys looking to cut the frame, it is exactly 14" in the front. The front two bed holes need to 10 3/8" apart. The holes were originally 24 3/8" apart.
Old 12-14-2016, 06:33 AM   #18
lt1wrangler
Id sell it complete for $800. i just listed it locally yesterday and should have it out today. I own a transmission shop and Im using the TH400 for an off road desert truck build for a local customer.
Old 12-14-2016, 10:51 PM   #19
lt1wrangler
Front clip off, drivetrain tomorrow.
Old 12-14-2016, 10:54 PM   #20
lt1wrangler
I'm really surprised how clean the floor was after we got the padding removed. I'm gonna start dynamatting Monday.
Old 12-15-2016, 08:53 AM   #21
NastyBuzzard
Keep us posted on how much dynamat it is going to take. I plan to do my crew cab soon.
Old 12-20-2016, 07:49 AM   #22
lt1wrangler
We got the cab off yesterday then pulled drivetrain. Frame is going to sandblasting on Thursday.
Old 12-20-2016, 12:10 PM   #23
MTCK
MTCK's Avatar
100 sf will get all the floor, most of the roof and a good bit inside each door.
-Marcus
Project Plow Truck
Old 12-20-2016, 06:27 PM   #24
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice truck to start with! You're making some killer progress on it too.
Ryan
1969 Chevy milk truck
Old 12-21-2016, 06:41 AM   #25
lt1wrangler
We got it down to the frame now. I'm gonna keep the axles under it till he can sandblast it next week. I'm surprised how at how clean the frame was around the body mounts.
