03-01-2018, 12:33 PM | #1 |
Scratch buildng a stainless steel gas tank
The aftermarket is loaded with tank builders. You can buy a gas tank from hundreds of builders.
The fly in the ointment is when you narrow it down to a specific size/shape and stainless steel construction, the options narrow up and when it comes to full custom,...the proverbial brick wall hits you in the teeth. Not to walk away from a problem, We decided to just build one our self. requirements; maximum volume (25 gallons, Min.) Custom shape/size needs to fit in our custom frame and clear exhaust, bed floor. Stainless steel. (Out here in California we are forced to use fuel with Ethanol in it. This stuff with its benzine additive literally dissolves aluminum.) So with these guidelines in place and just enough skill to get into trouble we took on this project. First step was to build a profile buck out of plywood. once we had this we rolled some steel and had a friend use his CNC plasma cutter to cut out the ends and inner baffles to our pattern. |
03-01-2018, 12:36 PM | #2 |
Re: Scratch buildng a stainless steel gas tank
This is as of today.
03-01-2018, 02:09 PM | #3 |
It's Better With Nitro
Nice!
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
03-01-2018, 02:20 PM | #4 |
Very nice
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
03-01-2018, 02:21 PM | #5 |
Wow. That's cool and a large tank. I bought the 17 gallon tank from LMC and thought it was about as big as could fit.
03-02-2018, 06:24 AM | #6 |
Wow nice tank. Quality work. Plain old steel worked great for tanks until ethanol was added under Clean Air requirements. Benzene is a natural component in gasoline & additional benzene can be added sometimes to increase octane ratings. Ethanol is the pollutant in gasoline. As ethanol binds to water, this corrosive mix destroys steel, softer metals and some rubber types.
03-02-2018, 08:59 AM | #7 |
Nice! I had to make a custom tank for my panel truck in order to keep it in the factory location. Went full stainless as well
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721 Instagram: jaked937 |
03-02-2018, 12:37 PM | #8 |
Awesome! How may gallons did you end up getting out of the new tank? I ended up going with the stock side saddle tank from the panel, until I can get a second rear tank figured. I calculate I’ll have about 17 gallons of diesel to work with, not ideal as my stock Dodge tank had 30 gallons
03-02-2018, 12:48 PM | #9 |
1962 C-10
WOW!!! Great work!!
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
03-05-2018, 11:29 AM | #10 |
