09-22-2020, 04:19 PM | #1 |
Photoshop my 1968 to 2 tone please
Hi all, my truck has been completed in its present state for just over 10 years. I am really liking the 2 tone anniversary 1968 color scheme. This is obviously a bright yellow compared to the standard gold.
Would somebody mind adding the lower and upper cab off white scheme to my truck? I like it the way it is but I do need to do some touch up on the lower part area anyway and thought I might change it up at some point. This is a pearl paint so i am afraid a touchup might not work so well. Thanks for your thoughts and input. Dave Also if this is a bad angle I can get another or 2.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
09-22-2020, 04:24 PM | #2 |
Re: Photoshop my 1968 to 2 tone please
A second one. if it helps.
Dave
09-23-2020, 01:02 PM | #3 |
laying low
Hi Dave
I can't help with the photoshopping but I think your truck looks good as is although a white top and bottom would help to tone down the brightness of all that yellow. It'll look great either way.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
09-23-2020, 02:37 PM | #4 |
I really like the white+?? two-tone trucks, except for one problem. White shows road grunge and mud splatters way too easy.
Of course, your truck probably doesn't have that problem in the same way that daily driver 4wd's do!
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
09-23-2020, 03:19 PM | #5 |
Thanks guys, I do like this yellow I picked out. It is kinda hard to tell much from the pictures but it is a very bright yellow (no kidding) with some sunset pearl in the clear coat. A few years back (10 years) the yellows weren't quite a prevalent. Now I see a few more. I can do this myself so I am giving it some thought.
I do drive this truck quite a bit. I enjoy taking it on the longer trips and all so it does see its fair share of grit and grime. I wasn't sure how the lighter color would show the dirt it seemed like white is a little less likely to show the dirt. For me to pick the color will be a little tougher if I decide to go for it. the brighter white wouldn't look right so it will take some sort of different color. Champagne? I am not sure. Thanks for looking guys. It is a continual project for me... as I suppose most are. Dave
09-24-2020, 06:51 PM | #6 | |
Also, there are other manufacturers that have nice 'classic' whites (Fords Wimbledon or Ermine White; Chryslers Cool Vanilla; Porsches Chalk White).
09-24-2020, 10:19 PM | #7 | |
Any car shows coming up around you?
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
09-25-2020, 12:10 PM | #8 |
Scotti I have not ruled out any of the other makers for the paint. But I think a bright white against the bright yellow would be a bit stark. The base color for my truck is millennium yellow as I was looking the other day I saw a "speedway white" as a corvette option in that same time frame. I may look a little more at that as well thinking it might compliment this.
Other Larry, I hate to hear that about your 55, but I am glad you got it back. It shouldn't be that hard to get something done. As far as carshows I have not heard much. I don't seem to be in the "loop" here. I have stumbled onto a couple recently but nothing I knew about. I know people are ready to get out and about and go to the shows. I may poke around and see if I find anything. Its getting to be a nice time of year to get out. Good luck on your 55. Dave
09-25-2020, 04:11 PM | #9 |
Moderator
Took me all afternoon.
09-25-2020, 08:37 PM | #10 |
Thank you Master Chief. That’s the basic of it for sure. My attempt looked similar
I do like that combo Dave
09-25-2020, 11:18 PM | #11 |
The price you charged is reflected in the quality I see.
I love the concept though.
09-25-2020, 11:21 PM | #12 |
Dave, there is a car show in Carthage tomorrow, Sept, 23, 2020. Starts at 10. I saw it on FB, C10 Club Arkansas.
09-26-2020, 07:50 AM | #13 |
Moderator
You know I laughed a whole lot after I posted that. Thought for sure someone would take me serious.
09-26-2020, 08:19 AM | #14 |
Ha ha.
And I didn't want to sound ungrateful... Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" Last edited by Custom 68; 09-26-2020 at 08:51 AM. |
09-26-2020, 08:19 AM | #15 |
Thanks other Larry
09-26-2020, 01:17 PM | #16 |
I can't do that stuff even that good, so I lookedin my stash and found these. Maybe they are close enough to give you idea.
09-28-2020, 02:38 PM | #17 |
I have a tailgate in a very similar color that has white on it as well. I will take a pic tonight when I get home and post it.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Coming soon: EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 |
09-28-2020, 03:08 PM | #18 |
Thanks guys, I think like most of the anniversary paint schemes it would look pretty good. Here is one I saw a while back and peaked my interest. Its not the true factory colors but I liked it.
09-28-2020, 04:22 PM | #19 |
Found a couple examples on the Web... The second photo is CPP's Week to Wicked C10 so if you want to look a lil closer you should be able to find it out there Online. Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold Last edited by weq92f; 09-28-2020 at 04:28 PM. |
09-28-2020, 09:47 PM | #20 |
I love the first photo with the 1 piece windows and late model mirrors that fill the corners, nice wheels and perfect stance also.
09-29-2020, 07:14 AM | #21 |
the two tone solidifies the nature of these trucks as timeless, some solid colors dependent of wheel can really date the look.
i am not at this point a fan of one piece windows...i have seen a few that are acceptable, but the later model mirror just does not work for me...to modern and too out of place. |
09-29-2020, 07:42 AM | #22 |
Tailgate pic, a little late to the party...
09-29-2020, 09:09 AM | #23 |
Thank you all for your input and pictures. This is helping me decide the direction.
Dave
05-27-2021, 12:42 PM | #24 |
Did you ever get someone to photoshop your truck. If not, is this what you had in mind?
05-27-2021, 02:35 PM | #25 |
Unclebrad, that is exactly it. Thank you very much. I had given my hand at one of the online programs but didn't get it anywhere near that.
I appreciate it. I had almost decided to just go with it and give it a shot to change things up since it has been painted around 12 years. I just haven't had anytime to start but that will be what it would look like for sure. again thanks, Dave
