Old 09-04-2009, 07:53 PM   #1
slepysal
slepysal's Avatar
60-63 Windshield install
How hard is it to install a 60-63 wrap around windshield? I have called some local shops and no one wants to do it. Any of you Bay Area members know of a shop that int installs them ?
I know John (ChiefRocka)needs his replace his too, any tips ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 09-04-2009, 08:30 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 60-63 Windshield install
It is the most difficult design I have ever encountered. I've installed dozens of windshields in vehicles from the 40's to the 60's, and my 1960 GMC was the only one I could not accomplish.
I painted the cab with all the glass out, and then figured I'd reinstall the original glass (it had a few chips) to see if I could do it at all, then pull it back out and install the new glass if it worked okay. Ultimately I fractured the original glass at one of the bigger chips, so I gave up and called a local glass outfit to install the new windshield. The first day they sent two guys, and after several hours of struggling, gave up and came back the next day with a third guy. They finally got it installed, and said they would never do another one "next time call somebody else".
For most installs on this style of glass (like a 56 Ford for example), the process is: 1. Mount the rubber on the glass. 2. Install rope/string/twine in the pinch weld cavity in the rubber. 3. Set the assembly on the lower pinch weld and start working the lip into the cab by pulling on the string, with someone else pushing on the outside.
The problem is, when you set the assembly on the lower pinch weld, the top of the glass/rubber gasket interferes with the lip of the roof, and you can't lay the glass back against the channel. This leaves the option of setting the glass & gasket against the face of the channel and attempting to pull the gasket lip over the pinch weld, when it's too far away to reach the pinch weld.
I was at work the days they did the installation, so I don't know how they finally got it done. I asked my wife to video tape the process but they refused to do the job if she did.
Perhaps if you can find an older established glass outfit that has someone with experience. Good luck.
Old 09-04-2009, 08:43 PM   #3
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: 60-63 Windshield install
They are kinda pain in a butt! You just have to becarefull.
Three people helping you is a plus! Two guys on each end and one fella inside the cab!
You have to use a rope though.
Check this out!
FREE WINDSHIELD INSTALLATION INSTRUCTIONS
http://www.route66restorations.com/1.html
Chevy Truck Windshield, Tinted, Shaded, 1960-1963
Replacement Windshield
$399.99 ea. (((( THE CHEAPEST ))))
http://www.ecklerstrucks.com/product...5&dept_id=1468
Chevy Truck Windshield Weatherstrip, Standard, 1960-1963 $44.99 EA.
Chevy Truck Windshield Weatherstrip, Deluxe, 1960-1963 $44.99 EA.
Some old post:
http://67-72chevytrucks.com/vboard/s....php?p=3126364
http://67-72chevytrucks.com/vboard/s...d.php?t=305155
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
Last edited by 1Bad62Pro/Street; 09-04-2009 at 08:48 PM. Reason: http://www.route66restorations.com/1.html
1Bad62Pro/Street is offline   Reply With Quote
Old 09-04-2009, 09:07 PM   #4
hd74
i took mine to shop.mine is extra hard to do because it has the stainless steel trim.they said that they have done lots of old cars and i check with some coustomers of his. he supplied the glass and i supplied the gasket . i went the cheaper route and got it from brothers. after 4 hours the gave up and said the gasket did not fit right. then i got rubber gasket steele rudder or it was soft seal..the next trip took about 4 hours useing four guys. they beat and framed on the windshield i just knew they were going to brake it,i watched both times.they said it was the hardest one they have ever done.the total cost was $290.00 plus the gasket.i got a deal.nothing like a new windshield.
hd74 is offline   Reply With Quote
Old 09-05-2009, 07:17 AM   #5
63 & 64 Bowties
and a few others
You might check with Safelite Glass if you have one close to you. They're a nationwide chain. Before I painted my 63 I was thinking of taking the windshield out to put in new rubber. Around the same time I had a windshield crack on my DD truck. Safelite came out and installed the new one and while the guy was here I showed him my 63 and asked him if they did these. He said they did, same price as newer cars ($125) if I supplied the rubber. One hitch was that if it wasn't a new glass bought from them, there was no guarantee it wouldn't break. That's why I didn't do it. But, this guy had done plenty of old vehicles and said it would most likely be no problem.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 09-05-2009, 10:16 AM   #6
63sbssbbw
UCA63
63sbssbbw's Avatar
I think another thing to watch for is making sure the rubber is installed facing the right way out
It will install backwards but mine started to develop spiral cracks radiating from the middle of the windshield
Didn't trust the quality of that one(unk brand) so sprung for a GM resto part,about 35$
I thought my search for new glass was going to be tough and expensive (with catalog $$ being 1000-1300 usd,no shipping,no install and I've heard rumor they don't fit very well).
My local shop found a pilkington in BC 650.00 I wasted no time"I'LL take it" it was kind of funny,He even checked twice 'cuase he thought it was a typo
Install took 2 guys about 2 hrs
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 09-05-2009, 10:54 AM   #7
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Yes....let me know what you find.
I want to retain the chrome strip for sure.....although, I want to remove the glass myself, and repair (if any) rust under the rubber...
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 09-05-2009, 07:02 PM   #8
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I thought that the rubber was supposed to be put on the glass, then put a rope in the pinch well side of the rubber, then as you pull the rope from the inside the rubber flips over the pinch well. I will have to photo the instructions out of my assembly manual, but I think that was the way it went.
Old 09-06-2009, 12:11 AM   #9
70 Suburban
Rods
this is how I did my 65. I did it with one other guy. neather of us had done it before
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 10-30-2018, 10:07 PM   #10
cnntnsxty@aol.com
Anyone find putty under the windshield seal? It did make it easier to remove as the putty caused the seal to get soft, but this is the first time I've seen that
cnntnsxty@aol.com is offline   Reply With Quote
Old 10-30-2018, 10:25 PM   #11
MusicMan70
MusicMan70's Avatar
A great thread from Corts60
http://67-72chevytrucks.com/vboard/s...d.php?t=568864
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 11-08-2018, 02:22 AM   #12
markeb01
Senior Enthusiast
markeb01's Avatar
My wife and I put a new windshield in my truck a couple of years ago with the 1960 stainless trim strip. We used tons of lubricant on the gasket and it fundamentally popped right into place.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 11-08-2018, 03:45 AM   #13
cnntnsxty@aol.com
Succesfully replaced the windshield yesterday. Took an hour and a half to get it seated in properly and another 2 hours to clean all the sealant up. Used 3m 08509, would have been a little quicker but started with the rope at the bottom and had to start over since the roof overhang gets in the way. I replaced the windshield because the one that was in there was delaminating just noticed today that it has no markings on it at all. The replacement is marked DOT AS1, $105.00 at the local glass dealer.
Thanks for the links and all
Old 11-09-2018, 12:58 AM   #14
Captainfab
60-66 Nut
You paid only $105 for a '60-'63 windshield?
Old 11-09-2018, 01:35 AM   #15
cnntnsxty@aol.com
Actually mine is a 65, didn't have my glasses on when I first posted to this thread but yes that is what it cost. I thought I'd be paying more from what I had seen online, only went to the local glass dealer because I live on a rural route and most freight trucks can't get up my road.
