09-11-2014, 12:39 PM | #1 |
1967 squirrel cage
is a 67 c10 squirrel-cage different from the others in this era? I pulled off my heater housing from the firewall and discovered a huge mouses nest in all cavities. Its all cleaned up but now I need to replace the squirrel cage as the mouse was chewing on it and ate it all up. This one seems to be a little bit smaller though. It measures 2 and three quarter inches top to bottom
1967custom |
09-11-2014, 03:16 PM | #2 |
Re: 1967 squirrel cage
I don't know if the squirrel cages were common across other GM models. I only know what's original to my 69 with A/C. If a mouse damaged yours by chewing on it, I'd say it's incorrect since mine is made of steel. As I recall, it's also much more than 2-3/4" diameter... more like 5"or 6". It just fits through the hole in the box.
09-11-2014, 03:29 PM | #3 |
The Older Generation
From what I have seen '67-'72 non A/C are all the same size. Most of them are plastic but I have seen a few metal ones. Not familiar with the A/C ones.... LockDoc
09-12-2014, 02:01 PM | #4 |
Its plastic. I foind the same exact one on a 68 yesrerday.
Did you gus know the motors have date of manufacture on them?
1967custom |
09-12-2014, 02:14 PM | #5 | |
Never paid any attention to that but the motors themselves are the same up into the late '70's. LockDoc
09-12-2014, 04:54 PM | #6 |
Yeah mine says mfg. 03-1967. Cool huh? Good to know for guys going date correct on their trucks
1967custom |
09-17-2014, 09:09 PM | #7 |
you can have them rebulit
09-17-2014, 11:35 PM | #8 |
You can? I bet a small engine shop could. The motor works well. Just the cage was all chewed up
1967custom |
09-18-2014, 06:00 AM | #9 |
It's seems a common place for mice to make a nest. Mine was way so bad it smelled and rotted the interior air box also chewed up the cage. I had to clean and replaced everything. If I recall the cage was 5 to 6 inches round.
09-23-2014, 03:21 PM | #10 |
It is to my understanding that heater cab squirrel cages are plastic and AC cabs are steel
09-23-2014, 05:34 PM | #11 |
Yeah that makes sense. Ive never had an ac cab though
1967custom |
