06-11-2015, 12:12 AM | #276 |
Re: Post Pics of your Static Drops!!
Camaro sub frame front end (4 inch drop). CPP 5" drop coils for the rear.
Low6Four '64 SWB |
06-11-2015, 02:46 PM | #277 |
Looks sweet low6four
06-16-2015, 12:41 PM | #278 |
CPP 3/5 with 1 coil cut up front. Adjustable track bar and rear shock relocation kit. After the 1 coil removal up front she was resting on rubber stops so out the stops came. She rides good and I might remove the front stop perch for some more travel.
06-17-2015, 10:19 AM | #279 |
Here's another shot.
Chief US Coast Guard Ret. 1963 SWB Fleetside Chevy L6 230 1962 Cadillac Coupe Deville 390 |
06-19-2015, 11:59 AM | #280 | |
Posted via Mobile Device |
06-19-2015, 12:09 PM | #281 |
If by "stock drop spindle" you mean that will work with drum brakes the answer is no you will have to convert to disks if you want drop spindles otherwise Johnboy63 is correct.
06-19-2015, 12:24 PM | #282 |
thats a looker for sure texas
06-20-2015, 09:28 AM | #283 |
Thanks, jondoh. I might get the 2" blocks for the rear to really bring her down.
06-23-2015, 07:10 PM | #284 |
my sons '63...we swapped control arms, spindles, and springs, (1 1/2 coils cut off) from my '86...removed 4 leafs from the rear springs...ordered a flip kit and c-notch, and hopefully get dropped spindles soon. currently it's dropped 2 inches in the front and probably the same in the back.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
06-24-2015, 01:57 PM | #285 |
I like that stance Moose. I'd like to get my 61 close to that.
06-25-2015, 10:54 PM | #286 |
Still got a lot to do. It has 3-5 coil spring drop with 20's
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
06-26-2015, 11:25 PM | #287 |
06-27-2015, 09:02 AM | #288 |
No. I have a lot of clearance.
08-28-2015, 09:43 AM | #289 |
Don't think I ever added mine to the mix. My 64, dubbed the "Mule"
4.5/6 drop 245/60x15 & 275/60x15
08-28-2015, 10:51 AM | #290 |
Stance, wheels and tires are perfect!! That's where I want mine to end up.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
08-28-2015, 02:58 PM | #291 |
08-28-2015, 04:03 PM | #292 |
My 66 with a 1-3" drop. F: 235x70x15 R: 255x70x15
1966 Chevy C10 SWB |
08-28-2015, 04:27 PM | #293 |
ECE 4/6 drop 255/55/17 front 265/55/18 rear
At my worst I'm at my best |
08-28-2015, 06:02 PM | #294 |
Nice truck!!!!....and the 55-56 caps are a nice touch, plus the stance is perfect also.
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
08-29-2015, 12:22 PM | #295 |
That 62 is perfect!
84 GMC One ton 4x4 454 4 speed 62 Chevy C10 short fleet plus about 13 previous gm trucks from 1960 to 2000 |
09-03-2015, 09:15 AM | #296 |
64 built for autocross and daily goofing off. NoLimit Wide Ride up front with cab and front clip dropped an extra inch over frame. Rear frame rails kicked up 5" with custom mounted coil overs. Probably about 7" up front and 9-10" out back.
Love all these trucks, good job everyone!
Kent DRIVE IT HARD, DRIVE IT OFTEN! Short video of Black Betty & a friends 48 Panhead done by my kid. https://www.youtube.com/watch?v=8DlAdfwDQa8 |
09-25-2015, 09:10 PM | #297 |
3.5/5 ece
09-30-2015, 08:34 PM | #298 | |
im on 26.5 tires on 16"rims plan to do CPP Grand slam kit with 5/7 also have a set of 22' GM Transports to go on next few weeks , which I am really excited about. anyway, here is my ride so far, not quite done, but getting there. oh and its a 63, original short wide, not a cut long box |
10-06-2015, 03:05 AM | #299 |
Budget drop: Cut 1 & 1/2 coils up front and put in jeep TJ coils in rear
64 Chevy C-10 2004 VW Jetta GLI VR6 2006 Suzuki GSXR 600 |
10-06-2015, 04:25 PM | #300 |
Went with 3" cpp springs up front and 4" out back. Decided to cut one coil up front. Also removed bump stop perches but left steer stop. Rides decent and I like the look better. Sat too high up front initially.
