06-03-2018, 11:20 PM | #176 |
Re: Jesses' 48 PU
Clamped my piece to the cab and hammered a bit more until I was happy with the Fitment.
Semper Fi Check out my project: http://67-72chevytrucks.com/vboard/s...d.php?t=559086 |
06-03-2018, 11:23 PM | #177 |
Re: Jesses' 48 PU
Took it to my Harbor Freight shrink and stretcher set and carefully made adjustments until I felt it was right.
06-03-2018, 11:25 PM | #178 |
Re: Jesses' 48 PU
Measure once, twice, three times a lady...lol... And cut once, spot weld.
06-03-2018, 11:27 PM | #179 |
Re: Jesses' 48 PU
06-03-2018, 11:27 PM | #180 |
Re: Jesses' 48 PU
06-03-2018, 11:31 PM | #181 |
Re: Jesses' 48 PU
I have to admit that I surprised myself. Feels good to accomplish this without having the fancy expensive tools. Did it just like my old man taught me... I was really afraid to tackle these patches...but where there is a will, there is a way...
06-04-2018, 09:29 AM | #182 |
Re: Jesses' 48 PU
Very nice job on the repair...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
06-04-2018, 09:56 AM | #183 |
Re: Jesses' 48 PU
Very nice work!!! It's great when a job turns out better than you thought it would.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
06-13-2018, 09:19 AM | #184 |
Re: Jesses' 48 PU
Looks like a solid repair. Hopefully when I take my glass out of the cab I don't find the same educational "gems." haha
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
06-13-2018, 11:41 AM | #185 |
Re: Jesses' 48 PU
Wow, I'm bringing my stuff to your house! Nice job.
07-22-2019, 10:07 PM | #186 |
Re: Jesses' 48 PU
Hello everyone... It's been a long time since I post any pics. Truth is, I haven't worked on my truck since I last posted an update. Due to my busy schedule, travels, family etc... I have been walking by my project hoping I would have time. My garage got so cluttered, it took a weekend to clean and organize so I could work. Finally I put everything and everyone off and got back on it. I had the motor mounts welded in and needed the trans cross member, so that's where I started. I pulled the cab off, mocked up the tranny, set engine at 3 degrees and realized It sat to high and I needed to fix it as it was taking up too much cab space. I figured out that when I first grafted the S10 clip, for some reason I did it wrong, so I cut it off and rewelded it level. I boxed in the frame with 3/16 metal half way back. Once that was done I started on the trans cross member.
Here is how I initially grafted the clip, 2.5 inches higher that the frame. Guess I thought it was a shortcut to drop the truck.
07-22-2019, 10:10 PM | #187 |
Re: Jesses' 48 PU
I cut, fitted and mocked up the trans cross member
07-22-2019, 10:14 PM | #188 |
Re: Jesses' 48 PU
07-22-2019, 10:18 PM | #189 |
Re: Jesses' 48 PU
Mig welded 4"x 4" 3/16 metal at the ends, drilled 4 x 7/16 holes so I can bolt it to the frame.
07-22-2019, 10:26 PM | #190 |
Re: Jesses' 48 PU
Used a 7/16 center punch to mark my holes, used a step bit to drill my holes. I used flange nuts, so when I drilled the holes, I went far enough to counter sink the nut flush and welded it. This way my nuts are centered.
I got this idea from "Idaho Fabricator" a young man on YouTube.
07-22-2019, 10:28 PM | #191 |
Re: Jesses' 48 PU
07-22-2019, 10:31 PM | #192 |
Re: Jesses' 48 PU
Perfect fit.. Screwed in like butta.
Semper Fi Check out my project: http://67-72chevytrucks.com/vboard/s...d.php?t=559086 Last edited by Jesse49chevy; 07-23-2019 at 01:12 PM. |
07-22-2019, 10:34 PM | #193 |
Re: Jesses' 48 PU
Finally, motor and tranny mounted.
07-22-2019, 10:46 PM | #194 |
Re: Jesses' 48 PU
Motor mounts welded in. I pushed the engine back 2 inches and dropped it as low as possible.
07-22-2019, 10:47 PM | #195 |
Re: Jesses' 48 PU
07-22-2019, 10:49 PM | #196 |
Re: Jesses' 48 PU
07-23-2019, 08:12 AM | #197 |
Re: Jesses' 48 PU
Nice work again.
I saw Idaho Fabricator's YouTube and he does some great work.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
07-23-2019, 01:16 PM | #198 |
Re: Jesses' 48 PU
Thanks 8man.... It's nice to get away from the office and burn some welds, turn some wrenches. Keep fixing mistakes or changing my mind, seems I'll never get her done, but don't care how long it takes...I'm having fun and challenging my skills.
07-24-2019, 01:51 PM | #199 |
Re: Jesses' 48 PU
5 minutes a day and you'll get her done eventually. Maybe try and work on a few big things to get closer to driving and get excited again. Sometimes when you're in the weeds on the build, it seems like it will never get done.
08-04-2019, 06:38 PM | #200 |
Re: Jesses' 48 PU
Got a little bit more done today. I bought the driveshaft and as I suspected it hit the rear crossmember. So that means I have to remove it and add another one further back. Only issue with that is that I have center cab mounts in the rear so I had to figure out how to deal with that. I decided to build rear cab mounts!!
I see all the S10 swaps and how they build them so, I think I can do that. Pulled the truck out of the garage, pulled the cab off, first thing......figure out where and how the cab would be secured.
Semper Fi Check out my project: http://67-72chevytrucks.com/vboard/s...d.php?t=559086 Last edited by Jesse49chevy; 08-04-2019 at 07:35 PM. |
