Old 12-30-2014, 09:40 PM   #26
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: 1961 Crew Max
well the crew cab showed up this morning. overall its what i expected. looks like the drivers door of the four is the only one that will need to be replaced. all other front sheet metal and bed will be replaced. still looking to find a donor truck. looks like rockers on both sides will be replaced with the drivers side being the worst. thinking i can cut the entire floor from the d-max donor and make it fit. tunnel is very tall and size is within 1/2" front to back and side to side. as far as new suspension goes im still looking into it. CHIZZLER
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 12-30-2014, 09:51 PM   #27
Advanced Design
Advanced Design's Avatar
Re: 1961 Crew Max
That is cool! Tagging along.
Advanced Design is offline   Reply With Quote
Old 12-31-2014, 01:12 AM   #28
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 1961 Crew Max
here is what I had made for the floor in my crew...
I guess it depends on how your floor braces are, and which frame you are using.....
Old 12-31-2014, 01:29 AM   #29
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
is that a crew you are building? any more pics?
61-crew cab D-max
Old 12-31-2014, 11:20 AM   #30
66farmer
66farmer's Avatar
Re: 1961 Crew Max
Where did the truck come from?
66farmer is offline   Reply With Quote
Old 12-31-2014, 11:26 AM   #31
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: 1961 Crew Max
Looks like a great project to follow.
Steve
1997 Tahoe LT 4D 2WD (DD)
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-01-2015, 12:58 AM   #32
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
I got it from a guy in northern california. He has 2 more. Truck originally came from colorado and was a forestry service rig.
61-crew cab D-max
Old 01-01-2015, 02:51 AM   #33
amueller454
amueller454's Avatar
Re: 1961 Crew Max
looking forward to this project! So SICK
1960 short bed fleetside factory 4x4
1960 panel 454 NV4500 Daily driver
1961 Short Bed BBW Fleetside 5.3 th400 swap in process
amueller454 is offline   Reply With Quote
Old 01-01-2015, 09:13 PM   #34
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
Re: 1961 Crew Max
Very Cool CHIZZLER,
You and jonzcustomshop both have your work cut out on these Crew Cabs. Good to see these are being saved. It would be nice to know how many of each year 60-66 still exist. I will be following along on this build.
66Gilbert is offline   Reply With Quote
Old 01-04-2015, 08:56 PM   #35
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
well guys got a little more done today. got all the sheet metal off the front. got most of the floors cleaned. the drivers side pillar is not connected to the floor section. can any of you crew cab guys pull a tape and get me a measurement at floor line from pillar to pillar. i want to x-brace the inside before i start cutting. thanks CHIZZLER.
61-crew cab D-max
Old 01-04-2015, 09:24 PM   #36
jonzcustomshop
1961 crewcab
Re: 1961 Crew Max
my pillars are not attached either!
this might work:
run your measurement from the inside edge of the door jamb-where the weather strip mounts-, right where the lower striker hits, on the back portion of the cab, and then match that up with the center pillars.
Old 01-04-2015, 09:37 PM   #37
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
thanks for the advise. i will take a look at that and check the measurement. thanks
61-crew cab D-max
Old 01-04-2015, 09:38 PM   #38
brimc
brimc's Avatar
Re: 1961 Crew Max
This is a cool idea. Following along.
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 01-05-2015, 10:09 AM   #39
joe dirt
joe dirt's Avatar
Re: 1961 Crew Max
awesome build so far!
joe dirt is offline   Reply With Quote
Old 01-06-2015, 10:07 PM   #40
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Well guys today was a good/bad day working on the truck. Motor came out just fine but realized to keep the oil pan above the frame the d-max would be past the hood. Now if i went with a medium static drop or kept it a 4x4 i could get away with the pan hanging down. I have a 4x4 duramax crew cab now and am not looking for another 4x4. For those of you that have seen my other trucks understand the stance im looking for. Very low and fast with great suspension parts. I figured i should make something out of the front sheet metal rather than scrap it so i made this to hang on the shop. Thanks CHIZZLER.
61-crew cab D-max
Old 01-06-2015, 10:25 PM   #41
flashed
Re: 1961 Crew Max
Im in for the rest of this one .
flashed is offline   Reply With Quote
Old 01-07-2015, 01:37 AM   #42
Captainfab
60-66 Nut
Re: 1961 Crew Max
This truck is built for a different purpose, but it does have a Duramax. I thought it might give you some ideas on what to do to make it fit.
http://67-72chevytrucks.com/vboard/s...hlight=Duramax
Old 01-07-2015, 03:13 AM   #43
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
thanks for the link. I've read through that one. He is using a scott's hotrods coil over front crossmember. now that the motor is out i will take more measurements with using a dry sump pan at about 4" tall. Lots of $$$$$ for one of those.
61-crew cab D-max
Old 01-07-2015, 03:15 AM   #44
joe dirt
joe dirt's Avatar
Re: 1961 Crew Max
If ya need any help with the wiring i have done a few nasty conversions in the past..i could possibly help..im in gresham
Old 01-07-2015, 08:35 PM   #45
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 1961 Crew Max
72DuraBurb's burb is decently low with no hood mods, and a compound turbo'd Dmax. I bet you can get it in there without a high dollar dry sump oil pan. Here's a link to his thread. He went back to the factory front suspension after the first year he had it together too.
http://www.67-72chevytrucks.com/vboa...hlight=duramax
Ryan
1969 Chevy milk truck
Old 01-07-2015, 09:07 PM   #46
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
He did a great job. I've been through his build many times. It looks like the factory pan for the d-max. Im not giving up yet guys. Just have to do some more measuring now that the old motor is out. The dry sump would be the last resort.
61-crew cab D-max
Old 01-07-2015, 09:23 PM   #47
Bomp
Bomp's Avatar
Re: 1961 Crew Max
Im in.
If ever the chance presented itself I'd be there in a minute to check out this project live.
Bomp is offline   Reply With Quote
Old 01-08-2015, 11:00 PM   #48
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Well today i was able to do a little more measuring. I used my 66 gmc hood and believe it or not there is bit more room. the 61 hood drops down in the middle and has a brace on the bottom right in the middle. The 66 hood kicks up like a cowl would and has the bracing off to the sides. Measuring the d-max from bottom of stock oil pan to top of the motor it comes in at 38". Now if i ditch the stock pan at 9" and run a ppe pan it will reduce that by 5" coming in at 33". So measuring not touching the bottom of the hood to the bottom of the frame i came up with 32 1/2". Also With the hood in place from the bottom of the frame arches to the new front crossmember it can't be more than 6" tall to the top where the new oil pan would sit. So now i think were dealing with about 3" short. 1" for the motor and about 2" for new crossmember thickness. Yah its that close.
61-crew cab D-max
Old 01-08-2015, 11:22 PM   #49
HotRodHorder
HotRodHorder's Avatar
Re: 1961 Crew Max
Can always move the hood braces if it helps the cause.
71 Chevy SW (done&done)
86 Chevy 4x4 (featured in 'Four Wheeler' in 1992)
67 Harley Shovel w/ factory sidecar
41 Ford PU Rat shop truck (bagged straight axle-chevy motor)
63 Nova SS (project has stroker,muncie)
27 Hudson sedan Rat (project-chop,channel,500 cadillac)
HotRodHorder is offline   Reply With Quote
Old 01-16-2015, 04:05 PM   #50
chase@ridetech
chase@ridetech's Avatar
Re: 1961 Crew Max
i have been wanting to build and early to mid 60's crew for so long, i will be tagging along!
chase@ridetech is offline   Reply With Quote
