Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 05-21-2017, 09:41 PM   #1
1960chevypanel
Need pinion & yoke for Chevy 12 bolt
Anyone have a 12 bolt for parts? Missing some things on this one..
1960chevypanel is offline   Reply With Quote
Old 05-22-2017, 07:48 AM   #2
PGSigns
PGSigns's Avatar
Re: Need pinion & yoke for Chevy 12 bolt
I have some stuff. Do you have a list of what you need?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-22-2017, 09:39 PM   #3
1960chevypanel
Forgot to post pics, here's what I've got
Old 05-23-2017, 12:53 AM   #4
Captainfab
60-66 Nut
You can not just put a pinion gear in there. The pinion gear and ring gear must be used as a matched set. You will have to buy a set of ring and pinion gears. And of course the yoke, bearings and seals.
Old 05-23-2017, 07:16 AM   #5
PGSigns
PGSigns's Avatar
I would pull it out and clean it good. The look at what condition the carrier and axles are in. Then you can make a list of what you will need. You may as well put all new bearings in it and if you are planning a gear swap now is the time to do it.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 05-23-2017, 03:51 PM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
http://www.quickperformance.com/GM-1...t_p_20451.html
After thinking about this you have much more to do than just replace the bearing and yoke. You have to set shims and stuff.
Oh boy.
Old 05-23-2017, 07:42 PM   #7
63frankintruck
I have a yoke from my 63, and new set of gears for a 63 12 bolt if your interested. You would then need to probably purchase bearings and have someone install for you.
63frankintruck is offline   Reply With Quote
