Old 06-05-2013, 03:12 PM   #51
1966chevy
1966chevy's Avatar
Re: 1966 chevy truck engine swap to LS1
A/C is charged and now working great! Thanks to Old Air Products.
more pictures of my truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=467956
1966chevy is offline   Reply With Quote
Old 07-18-2013, 09:02 AM   #52
earl84
VERY nice work! I feel silly asking a question about your clock when there is so much other good stuff going on here, but I have my dash cluster apart right now and that thing intrigues me. How does the time get set on the clock? Both initially and if it should ever get out of whack? Also, how did you go from having what appears to be the time set knob in the middle of the hands to a smooth appearance? Just grind it off with a Dremel or something?
earl84 is offline   Reply With Quote
Old 07-18-2013, 09:26 AM   #53
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
That Ls1 Looks Really Good in that Bay!!!! Sweet!!!
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 07-18-2013, 10:45 AM   #54
JWheeler331
JWheeler331's Avatar
Very nice build.
JWheeler331 is offline   Reply With Quote
Old 08-23-2013, 02:05 PM   #55
tinydb84
tinydb84's Avatar
Awesome swap I dont know how I missed it. I just got a 66 and am in San Jose as well. What area are you in?
David
Instagram: myfabguy
Old 08-23-2013, 02:26 PM   #56
mr andrerson
quality work all around!!
mr andrerson is offline   Reply With Quote
Old 08-24-2013, 12:38 PM   #57
1966chevy
1966chevy's Avatar
Willow Glen Area
Old 08-24-2013, 12:51 PM   #58
1966chevy
1966chevy's Avatar
Here are some pictures of the jig I built to create the Fresh air vent covers behind the speaker kickers. This seals the outside vent off from debris coming into the cab. I used a gasket between the metal and plastic. On the kicker, I moved the speaker holes up to the vent opening and closed up the old speaker holes at the bottom. You can see a very little bit left of the circle which I didn't use enough filler in the picture on the drivers side.
See the pictures above for the Cowl Vent closed of as well.
Old 08-24-2013, 12:52 PM   #59
1966chevy
1966chevy's Avatar
Old 08-24-2013, 01:20 PM   #60
tinydb84
tinydb84's Avatar
Originally Posted by 1966chevy View Post
Willow Glen Area
Cool. I'm near campbell. When I get mine going again we will have to meet up
David
Instagram: myfabguy
Old 08-24-2013, 01:50 PM   #61
Snailed
Snailed's Avatar
Nice job on all the details! It looks very tidy considering how much of it is customized.
Snailed is offline   Reply With Quote
Old 08-24-2013, 09:35 PM   #62
1966chevy
1966chevy's Avatar
There is a car show in downtown Willow Glen Sept 8th I will be there, come check out the show.
Old 08-24-2013, 09:48 PM   #63
1966chevy
1966chevy's Avatar
The knob is on the top right side of the clock not in the middle of the clock. I wanted a clean look. So for this clock I had to drill a hole and notch the gauge bezel to fit the knob. The clock came out of a 80's Volvo. Already quartz!
Old 08-25-2013, 09:23 AM   #64
earl84
Oh, wow, I can't believe I didn't see that! Almost makes me look like an idiot, but not the first time for that, haha. Thanks for the information.
Old 08-26-2013, 06:02 PM   #65
billysbowties
billysbowties's Avatar
I really like the clock it looks great, in post 24 you said the clock came from a 73 volvo and then in post 63 you said it came from a 80's model, I really want to find one of these do you know for sure which one it came out of, and also what is the tach out of.
Thanks for any info you could pass along.
billysbowties is offline   Reply With Quote
Old 08-26-2013, 07:18 PM   #66
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
What seats did you use?
BTW, The build looks great!!
Steve
1997 Tahoe LT 4D 2WD (DD)
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-11-2013, 10:00 PM   #67
1966chevy
1966chevy's Avatar
I could do some more research on this year but i did this conversion over 10 years ago. I believe it was from 73 to 80 Volvo wagon. I went to the wrecker and pulled about 5 of them out. I will have to do some further checking, and let you know.
Old 09-11-2013, 10:07 PM   #68
1966chevy
1966chevy's Avatar
2001 Dodge 1500, 2500 Truck. I believe they are still using them in the same truck today. Just have to spend more for the newer ones. My are none powered but it would have been cool to use a set that were powered and heated. I had to modify the frame mounts a bit (shorten the legs & weld on new mounts) for a level install.
Old 09-11-2013, 10:23 PM   #69
1966chevy
1966chevy's Avatar
Ok I found out what I did. I used the face of a non quartz clock from a 1960-70's 140-240 Volvo clock. I put the face on a 1986-1993 factory quartz Volvo 240 clock cluster. I looked eBay right now there are two (2) that I saw on there. Check these item out #281163234650 #290974871422
Old 09-12-2013, 10:55 PM   #70
billysbowties
Thanks for the info on the clock, what did the clock come out of.
Old 09-12-2013, 10:56 PM   #71
billysbowties
Sorry about that last post, I meant what did the tach come out of.
Thanks again.
Old 09-13-2013, 10:56 AM   #72
1966chevy
1966chevy's Avatar
Thanks again.
Stock reproduction Tach for 64-66 chevy truck. http://www.truckandcarshop.com/
Old 09-14-2013, 09:33 PM   #73
billysbowties
Thanks for that information.
Old 10-14-2013, 11:36 AM   #74
1966chevy
1966chevy's Avatar
Here is my custom door panels to cover the work I did to get the one piece glass installed. I built them out of Plastic PVC purchased at Tap Plastics. Glued together with PVC glue purchased at OSH, sanded with a belt sander and hand sanded. I added side to flare the edges like a new vehicle today. I also foamed the inside of the panel to build up the backing and sound. This pushed the panel out to make the door panel flat, due to the door having a slight bow. The Handle cranks lineup and work great. NoteL: The window crake is power using the stock handle, to give it that factory looks. Here are the pictures.
Old 10-14-2013, 12:19 PM   #75
1966chevy
1966chevy's Avatar
Here are some pictures.
