03-23-2019, 03:09 PM | #1 |
63 GMC throttle pedal conversion
Hey what's up guys , I'm in need of some help. Has anyone done a gas pedal conversion. If you have please get back with me. Please. I need direction.
03-23-2019, 05:34 PM | #2 |
Moderator
Re: 63 GMC throttle pedal conversion
Conversion to what?
03-23-2019, 06:35 PM | #3 |
Are you wanting a cable style gas pedal?
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-24-2019, 12:52 AM | #4 |
Are you talking about something like this?
03-24-2019, 08:33 AM | #5 |
Yes, I'm looking to go cable.
After talking to the tech department at cpp ( classic performance products ), I found out that there wasn't no information on a 63 GMC throttle pedal conversion, so I had to figure out something, so I removed the original throttle assembly that was bolted to the side of the transmission tunnel. I found a flat spot next to that area and mocked up my lokar pedal and marked a line around the base of the mounting surface, then I put the plate that mounts to the firewall over the line that I marked around the base of the pedal to marke the 2 holes that needed to be drilled for the installation. Worked out perfectly. Thanks for all y'alls responses. |
