Old 11-20-2018, 01:12 PM   #1
v30crewcab
v30crewcab's Avatar
driver side wiring by battery? 71
got a 71 that someone has done some special stuff to. trying to figure out how the wiring is supposed to be over by the battery and the junction block. the wire comin over to feed the junction block has a metal tab in the middle of it, that looks like it is supposed to be on a stud, but its black taped up. anyone got a pic of that area on their truck? not even sure what to search!
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 11-20-2018, 04:24 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: driver side wiring by battery? 71
Someone has evidently replaced the fuseable link wire with a regular wire at some time, or spliced the original wire. The only wires that should be connected to the junction block are a 12 ga Red power wire, the black 16 ga fuseable link wire from the battery, and an 18 ga black wire with a 4 amp inline fuse in it for the amp gauge, it goes directly to the firewall connector..
LockDoc
Leon
Old 11-20-2018, 05:06 PM   #3
v30crewcab
v30crewcab's Avatar
this is what I have going on. the wire at the top goes over to the batt positive.
71 longbed 5.3 4l80
Old 11-20-2018, 05:25 PM   #4
LockDoc
LockDoc's Avatar
That is messed up. Not sure what the connector is. The brown wire looks to be to big to be a fusible link but not sure. Someone has cut the 4 amp fuse out of the small black wire and used the Red splice connector to tie the wires back together. The wire that goes to the battery should be the fusible link, not a plain wire....
LockDoc
Leon
Old 11-20-2018, 05:34 PM   #5
v30crewcab
v30crewcab's Avatar
guess I'll have to find a diagram and wire it all back in. fun fun.
71 longbed 5.3 4l80
Old 11-20-2018, 05:56 PM   #6
DA71Grande
DA71Grande's Avatar
I had that dam thing on mine also it was wrapped in black tape and was causing a short. still have no clue what it was for.
Doug
71 Sierra Grande C25
16 Sierra 2500HD All Terrain
23 Chevy Tahoe Z71
https://paypal.me/digdug7131?locale.x=en_US
DA71Grande is offline   Reply With Quote
Old 11-20-2018, 07:08 PM   #7
sKnNyPpY
sKnNyPpY's Avatar
I've bought black/brown 16 ga fuseable link wires from my local big box parts store (Advan** Auto) Mine was a hod-podge too.
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 11-20-2018, 08:20 PM   #8
LockDoc
LockDoc's Avatar
Here is a link to the wiring diagrams.
http://67-72chevytrucks.com/vboard/s...d.php?t=185856
Underneath the small ones there is a link to larger ones. Just be careful, the windshield wiper wiring is wrong on them.
LockDoc
Leon
Old 11-20-2018, 09:44 PM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is the engine bay wiring with the fender junction on the top.
Doc is right about the wiper wiring on the diagram but your harness
is most likely OK.
The fusible link is rated at 16 gauge 30 amp.
The lower red wire in your pic is the battery charging wire from the alternator, regulator, cab, junction, and it is 12 gauge.
If you have the gauge dash, you will have the small 18 gauge black wire for the battery charge indicator with the funny shaped fuse holder. If you have the light warning dash you will not have that wire and fuse holder.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
