09-18-2013, 12:12 AM | #1 |
2wd 4speed to K10 Blazer/Jimmy
anyone ever done this before Advanced Adapters does not sell the conversion kit anymore. anyone know of a way? I thought about the old transfer that uses 3 drive shafts but don't know if it would hold up to the 350 motor? I would like to be able to bolt it to the 205 transfer that is in now? any thoughts? thanks....Pale
09-20-2013, 12:48 PM | #2 |
Re: 2wd 4speed to K10 Blazer/Jimmy
Easiest would be to just find the correct sm465 with transfer case adapter. These can usually be found cheaply.
Second easiest would be to install a divorced np205 with correct side drop for your application. Posted via Mobile Device
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
09-20-2013, 04:56 PM | #3 |
can I use the 2wd 4 speed with this Divorced 205 I have a truck 4 speed already hooked to a 205? thanks....Pale
10-06-2013, 08:36 PM | #4 |
late to this. all you need is the factory adapter and sleeve. remove the rear junk off thr 2wd trans and cut the threads off the main shaft. reassemble with 4wd adapter.
